Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint wdl520 aquarius not switching on! - Hotpoint Aquarius WD63 Front Load Washer/Dryer
  • 108 Answers
Hi if you are getting no power at all and fuse in plug good i would check interlock that is were door locks in next is control panel usually interlock is cause
Posted on Feb 17, 2014
  • 155 Answers
SOURCE: washer dryer
check out this link
http://www.washerhelp.co.uk/washing-machine-usage.html
good luck
thanks.
Posted on Oct 26, 2008
  • 109 Answers
SOURCE: hotpoint aquarius WDL520 all lights flashing not
There should be a small door at the front bottom of the machine, open it and unscrew the plunger. try that first as there could be a blockage.
The machine will not spin until the water is drained out.
Posted on Jun 17, 2009
reddyanantha
  • 205 Answers
SOURCE: hotpoint aquarius wd440. Flashing lights
hello mam please check the timer switch.
Posted on Oct 04, 2009
barkencoa
  • 3463 Answers
SOURCE: i need a manual for an aquarius wdl520
You should be able to download the user manual from the following site.
WWW.HOTPOINT SERVICE.CO.UK
In the menu, click on>>
Hotpoint user instructions.
Then in the search box enter your model number
Please rate my solution.
Thankyou.
Posted on Jan 28, 2010
  • 6277 Answers
SOURCE: Washing machine Hotpoint Aquarius WDL520
Probably a blocked filter/drain motor/pump!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 05, 2011
How do i clean Hotpoint aquarius WDL520
Run clear no soap water threw 2 or 3 times then should be fine
CLR if you have rust stains rinse good
Dec 03, 2014 | Hotpoint Washing Machines
I need to a manual for hotpoint aquarius WDL520 washer dryer
you can download the instruction manual from here.
Hope this helps, thanks for using fixya.
Nov 08, 2011 | Hotpoint Aquarius WD640 Front Load...
I NEED A MANUAL FOR HOTPOINT AQUARIUS WDL520G
You should be able to download the user manual from the following site: hotpointservice.co.uk/pages/manual
Or directly download from this link: Hotpoint/Laundry/WDL520 (pdf)
Hope helps.
Sep 25, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
Hi, I have a Hotpoint Aquarius 7kg WDL520 washing machine. I have just went to open the door to hang out a wash I did earlier. The door is locked and no power seems to be in the washing machine as...
Does it have a separate drawer for the detergent and softener? sometimes opening that will unlock the door. It sounds like it was overloaded and blew an interior circut
Oct 21, 2010 | Washing Machines
I need a manual for an aquarius wdl520
Thankyou.
Jan 28, 2010 | Hotpoint Washing Machines
Where can I download a copy of User Operating
check the hotpoint web site some manuals available
Nov 11, 2009 | Washing Machines
Hotpoint aquarius WDL520 all lights flashing not spinning water still in bowl cant find instructions only bought it at xmas
Jun 17, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
71 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
