Question about Whirlpool Washing Machines
Cantfind filter ? have bad smell
Wwdc 6210
Morphy Richards iron smells bad.
Do you use distilled water in your iron. The filters may have bacteria on them, especially if the filter does not get very hot. Bacteria thrives in dark, wet environments. The bacteria has moved away from the filter into the iron, so changing filters would not help much for very long. I would buy a new iron that does not use filters and only use distilled water in it. Distilled water stops mineral deposits from forming inside the iron.
Dec 05, 2015 | Morphy Richards Irons
Why does my whirpool wwdc 7410 not start cycle?
you may have a bad door switch. I would check that the wires are still connected to the switch and that they are not broken or damaged.
May 12, 2014 | Washing Machines
Air purifier filter smells bad
That's interesting... I doubt it is the filter if the new filter did the same. It might help if you take a fan and blow it through the area behind the filter, or maybe even spraying some Lysol in it, because my best guess is that something inside the purifier is what is causing the smell. Hope this helps!
Feb 24, 2014 | Blueair Air Purifiers
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Apr 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
How do I get rid of the bad smell coming from my filter queen
Change all 4 of the filters, and wash the dirt container with soap, water and a little bleach. The only other thing that would cause a bad smell would be the actual motor, but that would be more of a burning smell. Good luck!
Jan 25, 2012 | Filter Queen Majestic Canister Vacuum
Will the HP 6210 work with VOIP and Win 7?
HP Officejet 6210 All-in-One is not tested on VOIP connections when it was in manufactured. However these printers do work with VOIP connection.
If you are unable to get the printer working on VOIP connection, there are few ways to fix this.
1. Reduce the Fax speed of printer ( from Setup - Basic Fax Settings - Fax Speed ). Try to Fax
If this does not work, try the step below
2. VOIP is Digital technology and HP 6210 works on Analog Signals ( standard telephone line )
- You need a DSL Filter which converts the Digital Signals to Analog and vice versa. This filter is available at any departmental store or computer accessory shop
- Connect the DSL Filter to phone socket. Connect the printer telephone cable to Analog port of DSL Filter ( to Line 1 Extn port of printer )
Either of this should fix the solution. However there is another solution which may or may not be possible. It is to reduce the baud rate on your Cable connection ( though not recommended )
Regards,
Shawn
Jan 28, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Bad Smell
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and remove out the bad smell. Good luck!
Aug 31, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
