Question about Rotora 2003 PONTIAC SUNFIRE RP.05060.1 Brake Pads - Ceramic
Where is the relay - Rotora 2003 PONTIAC SUNFIRE RP.05060.1 Brake Pads - Ceramic
96 windstar eec wiring scematic
Find another relay with an identical part number(maybe the fuel pump relay)& swap it in place of the suspect EEC relay.See if the buzzing quits.If it does,the EEC relay is bad.There might be a ac WOT cutout relay or fan relay with an identical part number that you can use instead of the fuel pump relay.The fuel pump relay & EEC relay will both have to be in place in order for the engine to start.A relay should click when you turn the key on,but it shouldn't make a buzzing noise.BTW-the EEC relay is energized when you turn the key on and then it supplies ignition on power to the computer,injectors,solenoids and fuel pump relay.Therefore, if the EEC relay is defective, these components are Not going to work.If you don't hear the fuel pump prime when the key is first turned on,that's a sign the EEC relay is bad.One of the injector wires should have battery voltage, if the EEC relay is powering up.If your vehicle doesn't have a matching relay to the EEC relay(except for the fuel pump relay)just pull the FP relay out and slide it into place of the suspect EEC relay for testing purposes.If the buzzing noise stops,then replace the relay because there's no way to test if the car will start without having both relays in place.
Oct 11, 2015 | 1996 Ford Windstar
What relays are in the Maxifuse/Relay Center?
Depends on vehicle but generally a hi-lo cooling fan relay, fuel pump relay, starter relay,fuel injector relay, a/c relay and on certain models hi& low beam headlight relays.
Nov 02, 2014 | 1999 Oldsmobile 88
Flashers not working
possible relay fault ? check all fuses not just the one thats for stated device
Mar 08, 2013 | 2002 Volvo S60
What on the land rover 3.9 (1996) does the 60amp circuit operate, on mine the fused area wiring etc has burnt out. Wether there is a connection, but I now have no heated sceen, no interior lidht and no...
RL1 Front Wiper Control Relay RL2 ABS Power Relay RL3 Air Suspension Power Relay RL4 Right Heated Front Screen Relay RL5 Left Heated Front Screen Relay RL6 Auxiliary Power 1 Relay RL7 Auxiliary Power 2 Relay RL8 Front Wiper Interval Relay RL9 Horn Relay RL10 Spare Relay RL11 Headlamps Wash/Wipe Relay RL12 Fuel Pump Relay RL13 A/C Condenser Fan 1 Relay RL14 A/C Condenser Fan 2 Relay RL15 Ignition Relay RL16 Starter Relay RL17 ABS Pump Relay RL18 A/C Control Relay RL19 Engine Main Control Relay RL20 Air Suspension Compressor Relay
Aug 23, 2011 | Land Rover Discovery Cars & Trucks
2000 ford explorer, fuse box don't show me what fuses are for
There are two fuse boxes. A baqttery junction box under the hood on the drivers side and one inside on drivers side. Good luck.
Fuse/Relay
Location
Fuse Amp
Rating
Power Distribution Box
Description
1 60A** I/P Fuse Panel
2 40A** Blower Motor Relay
3 50A** 4 Wheel Anti-Lock Brake System
(4WABS) Module
4 30A** Power Windows, Power Moon
Roof, Power Seat
5 50A** Ignition Switch, Starter Relay
6 20A** Transfer Case Relay
7 - Not Used
8 20A** Air Suspension
9 40A** Air Suspension
10 30A** PCM Power Relay
1 10A* A/C Relay
2 30A* Heated Seats
3 30A* Heated Backlight
4 15A* Fog Lamps and Daytime Running
Lamps
5 4 3 2 1
10 9 8 7 6
12 11 10 9
8 7 6 5
4 3 2 1
15 14 13
2 1 1
9
6
10
8
7
5
175
MEGAFUSE
Roadside emergencies
197
Fuse/Relay
Location
Fuse Amp
Rating
Description
5 - Not Used
6 10A* Powertrain Control Module
7 30A* 4 Wheel Anti-Lock System
(4WABS) Module
8 15A* Rear Wiper Motor
9 20A* Fuel Pump Relay and RAP
Module
10 15A* Horn Relay
11 15A* Parklamps Relay and Mainlight
Switch
12 30A* Mainlight Switch and
Multifunction Switch
13 15A* Heated Oxygen Sensor, EGR
Vacuum Regulator, EVR Solenoid,
Camshaft Position (CMP) Sensor,
Canister Vent Solenoid
14 30A* Generator/Voltage Regulator
15 - Not Used
1 - Wiper Park Relay
2 - A/C Relay
3 - Wiper High/Low Relay
4 - PCM Power Relay
5 - Fuel Pump Relay
6 - Starter Relay
7 - Horn Relay
8 - Rear Wipe Down Relay
9 - Blower Motor Relay
10 - Rear Wipe Up Relay
1 - Not Used
1 - DRL Diode
2 - Electronic Engine Controls Diode
Apr 06, 2011 | 2000 Ford Explorer
I have a 2004 Ford Mustang. What does the relay FOAB-14B192-AA control and where is the starter relay.
Engine compartment fuse/relay box
#24 is starter relay (24 is the starter relay)
#31 is low speed cooling fan relay
#29 is fuel pump relay
#25 is A/C Clutch relay
#23 is blower motor relay
#30 is PCM relay (engine computer)
I/P fuse panel
#34 battery saver relay
#35 Driver's unlock relay
#36 rear defrost relay
#37 interior lamp relay
#38 one touch window down relay
#39 accessory delay relay this should help you out the question with the FOAB-14B192-aa look what number it came out of on fuse box then match it up it will tell you what its for happy holiday
Dec 12, 2010 | 1999 Ford Taurus
Sunroof will not work
Power is supplied to the Power windows and sunroof through the power window circuit breaker. That circuit breaker is supplied power through the RAP (retained accessory power) Relay, the RAP relay also supplies power to the radio. The RAP relay is also fuse protected by the RAP fuse in the under hood fuse block. The RAP relay is energized by the BCM body control module.
The RAP relay is responsible for the radio and windows working after the igntion is turned off.
The first place to check would be the RAP fuse in the under hood fuse block and then the RAP relay in the Body fuse block.
A list of the BODY relay block located on the left side of the dash to the right of the interior fuse block is below:
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay(1) Park Lamp Relay
(7) Door Lock Relay
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay (1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 10, 2010 | 2000 Chevrolet Blazer
My 1999 dodge intrepid is stuck in low gear code p1768 is what i am looking for
Dodge: Relay always off (relays are stuck open) Dodge: Relay always off (relays are stuck open) Dodge: Relay always off (relays are stuck open) Dodge: Relay always off (relays are stuck open) Dodge: Relay always off (relays are stuck open) Dodge: Relay always off (relays are stuck open) Dodge: Relay always off (relays are stuck open) Dodge: Relay always off (relays are stuck open)
P1768 TCM (tranny control module) relay output always off
Okay what it means is that the PCM (engine computer) is not seeing the relay for the TCM
turn on. Can be as simple as a new relay, should be in the fuse panel next to the battery under the hood, switch if you can with another identical relay and see if it makes any difference, If it doesn't then you probaly have a broken wire somewhere in the harness between the PCM/fusebox area on the drivers side .
Apr 14, 2010 | 1999 Dodge Intrepid
A/C Control Relay
There are several relays for the A/C system on these. Using the reverse of the lid of the fuse/relay plate box it will show you the positioning of the relays but not the description;
I've added in the description so hopefully will help you!
Relay 9 - Heater blower relay
Relay 10 - Heated rear window relay
Relay 13 - A/C condenser blower motor relay
Relay 14 - A/C compressor clutch relay
Relay 15 - A/C condenser blower motor relay
There is no relay itself for the A/C control, however there are a couple of fuses for this. If you need I can supply you with the fuse position and exact function within the AC system.
Out of curiousity whats the problem with your AC?
Hope this helps
May 12, 2009 | 2007 BMW 525xi Sedan
Rotora 2003 PONTIAC SUNFIRE RP.05060.1 Brake Pads - Ceramic Logo
44 people viewed this question
Top Rotora Computers & Internet Experts
jeff5may32
Adam Truesdale
Tim Marx
Tim Marx
Are you a Rotora Computer and Internet Expert? Answer questions, earn points and help others
