Question about Honeywell "R8184G4074 Oil Burner Control, 30 Seconds"
Keeps on tripping out - Honeywell "R8184G4074 Oil Burner Control, 30 Seconds"
  • 40 Answers
The cad eye . the little photo cell flame detector needs a good flame to signal that it is ok to keep running. if you do not have a good flame it will trip out. Check your filters for poor oil flow. your transformer for ignition current. ask yourself did you have a flame if yes did it sound or look normal. if yes clean the cad eye and try again. if still tripping replace the cad eye. if no flame or poor flame fix problem . check first do you have oil. at least 1/4 tank, are filters clean 1 in canister 1 in pump and 1 on the nozzle. do you have ignition if not get someone who knows what they are doing.
Posted on Nov 17, 2014
    Problem Solver:
  • 20 Answers
Check the right value tripper. kindly check the earth connection are proper
GKM
Posted on Jan 07, 2014
My hotpiont cooker c358ewh keeps tripping the electric every time I turn cooker on. Everything else works. It started when I self cleaned my oven. Can you help please
It's tripping because to much amperage is going to it, this tripping is a safety to let you know you have a problem.
Feb 10, 2015 | Ovens
Belling Synergie single oven keeps tripping the electric box
Tripping is common when a cable is exposed / burn / damage causing the tripping.
Sep 06, 2014 | Ovens
4 Plate stove (hob), when switching on one of the plates it keeps tripping all the power. I have replaced the switch however problem persists. Secondly remaining 3 plates only seem to reach a low...
I would suggest you replace the hotplate that keeps tripping the supply, this hopefully will solve the prob you are experiencing with the other plates.
Sep 23, 2010 | Ovens
Fuse keeps tripping have checked and removed the inner bulb but cooker still trips the fuse, Fan and elements appear to be working
insulation breakdown on fan element will need replacing when heats up tracking down to earth tripping your rcd.
Jan 07, 2010 | Neff B1421 Electric Single Oven
My Belling E641 keeps tripping out. Now the trip
You evidently have an earth fault on the cooker i.e one of the heating elements has failed and the trip switch is operating to prevent you getting a shock.
Most likely it is one of the radiant rings that is at fault but it could also be an oven element.
There is no easy way to tell without checking with a multi-meter for earth continuity between each element and the cooker frame, you can do this with the power off and the meter set to resistance or continuity test.
There should be no reading between healthy elements and earth but a faulty element will normally show a reading when the probe touches the cooker frame.
Dec 30, 2009 | Belling Ovens
Zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
Dec 26, 2009 | Zanussi ZBF260 Electric Single Oven
Zanussi 360 just tripped and now keeps tripping
You will probably find that it is the oven element that needs replacing, located at rear of oven compartment behind rear panel.
Please rate my solution.
Thanks.
Nov 11, 2009 | Zanussi ZBF360 Electric Single Oven
Double oven keeps tripping circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Oct 24, 2009 | Jenn-Air JJW9830D Electric Double Oven
Honeywell "R8184G4074 Oil Burner Control, 30 Seconds" Logo
118 people viewed this question
Top Honeywell Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Honeywell Oven Expert? Answer questions, earn points and help others
