Question about KitchenAid KCO1005OB 1400 Watts Toaster Oven with Convection Cooking
Broken knob need new knob
Oster 6232 toaster oven.
trying to find a solution for a broken knob, i discovered that there aren't many decent options. so i took it upon myself to find one. my father actually recommended that i post the solution, seeing that there were so many with broken knobs. now this works on the timer knob on an oster 6232 toaster oven. it may work on the other knobs and possibly other models, but i cannot confirm that. the plastic stem of the knob that slips over the medal stem of the timer had broken. i crazy glued it back together and knew that there was no way in hell it would hold up with just glue. sorry for the lack of pics on this part. with the broken piece glued back in place, i went to home depot to find something/ anything that would securely slip over the stem of the knob. i tried all sorts of tubing. copper, pvc, steel and found nothing. in the plumbing isle with all the brass fittings and compression fittings, i found an "ander-lign compression nut" 5/8" OD w/ insert. part # A-304 961-P. 634052c.jpg
all you need is the brass flanged insert. if you can find it without the nut and compression ring, then more power to you. after buying this, slip the piece over the knob stem flanged end first. i used 5 minute opoxy to ensure it would stay in place. 7c9f2a3.jpg
i then used a cone shaped diamond bit in my dremel tool to notch out the two sides of the knob. 6be2e7e.jpg
just cut the brass down enough to match the notches in the stem of the knob. 0cdfdf7.jpg
and there you have it. sorry for the 2 blurry pics. hope this can help some of you.
Sep 15, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Knobs are broken. Need new ones
here is what i just did with mine that i bought used, i put some jb weld into the socket of the knob and i am waiting to see if it will be a success! it is an idea though. have to give me credit for trying. mine was the timer knob. jerry
Aug 23, 2009 | Oster 6071 Toaster Oven with Convection...
My timer knob is broken. How can I order only that part?
I would advise you to call Kitchenaid Customer Service. They would be able to send you a replacement timer knob at no cost. You may simply pull off the broken timer knob, and the new knob will snap in with ease.
Their toll free telephone number is 1800-541-6390.
Jun 16, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
My delonghi toaster oven knobs broke! as
Hi, you can purchase them on amazon. Here: Amazon com delonghi knobs. I think this was helpful, Have a nice day
Jun 12, 2009 | DeLonghi EO1260 1400 Watts Toaster Oven...
Knob to my toaster oven broken
Thanks for allowing me to help you with this problem. It took a while but I was able to find the information you need. Just click on this link:
www.euro-pro.com/europro/productdetail.aspx?pid=8093C938-4393-47B8-A9B5-9D606596B9CE(Euro-Pro+Base+Catalog)
Figure out what you need and place your order. If my information was helpful, please give me a good rating. Thanks for using FixYa!
Jan 28, 2009 | Euro-Pro EuroPro 6Slice Toaster Oven with...
TIMER KNOB IS BROKEN
I've had the same problem. I checked out the Kitchen Aid website, called the toll-free number listed on the site (800-541-6390), and talked to a very pleasant and helpful customer service representative. She said she would be sending a free replacement knob that would arrive in 7 to 10 days. It may sound ominous, but if ya can't fix ya, ya gotta replaceya!
Dec 03, 2008 | KitchenAid KCO1005OB 1400 Watts Toaster...
Time control knob for bravetti platinum pro convection oven
Thanks for allowing me to help you. The replacement knob is available from the following link:
www.euro-pro.com/europro/productdetail.aspx?pid=1D76CC6A-4A86-4D6B-8120-7DB204F16DF4(Euro-Pro+Base+Catalog)
You can also get a user's manual if you need one.
If you found my assistance valuable, please give me an appropriate rating. Thanks for using FixYa!
Oct 19, 2008 | Euro-Pro EP278 Bravetti Platinum 1500...
Need a knob for the oven broiler on a welbilt
I needed a new timer knob as weel. I contacted KitchenAid's customer satisfaction Center at 1-800-541-6390, and they sent a new one to me at no charge.
Jul 13, 2008 | Toaster Ovens
KitchenAid KCO1005OB 1400 Watts Toaster Oven with Convection Cooking Logo
75 people viewed this question
Top KitchenAid Toaster Ovens Experts
Think Crucial
Think Crucial
Tom Chichester
Are you a KitchenAid Toaster Oven Expert? Answer questions, earn points and help others
