Question about Acer Aspire Computers & Internet
Says wireless not enable
My acer az5771 has suddenly lost wireless connection and the system says that the wireless is not enabled on the computer . How do I enable it is there a switch that may have been turned off?
  • 3 Answers
Look on your laptop at the top keys f3 there should be what looks like a radio soundwave looking antenna hit fuction key and the that key that should turn your wifi system on
Posted on Jan 01, 2014
  • 7 Answers
SOURCE: Wireless Lan on HP Pavilion M1000
Surely you can find out if you have a wireless network card installed . For this you can goto device manager and under network adapters look for any wireless adapter.
Heres How you check device manager.
  • Right-click My Computer then select Properties
  • Select the Hardware tab
  • Click the Device Manager button
  • Alternative solution: invoke devmgmt.msc
  • Alternative solution #2: Device Manager is part of the Computer Management, which also includes Event Viewer, Services Manager, Disk Management, as well as many other things. Right-Click My Computer then select Manage to start Computer Management, or invoke compmgmt.msc.
Picture of device manager and random wireless adapter
http://www.cisco.com/warp/public/102/wlan/xpleap_02.gif
Also I am not too sure about what system you are using and whats the operating system you are using.
Posted on Dec 20, 2007
  • 64 Answers
SOURCE: my Toshiba SP6000 cannot enable
Hi Alirahmani26,
From what I've gathered here, you're trying to use a wireless card on your laptop to connect to the Internet through your desktop computer. Are you using a wireless router somewhere in there? Or are you wanting to connect to the Internet FROM your laptop THROUGH your desktop computer? If the latter, are you planning to connect the laptop with a Cat-5 cable or with the wireless connection?
Ben
Posted on Mar 21, 2008
WeListen2You
  • 538 Answers
SOURCE: when trying to enable my
ok..enable the wireless..three switches so to speak..
physical switch on side..check
network setting in control panel switch..check.
actual wireless card switch ...check..
get all three..you should be there..
Posted on Oct 09, 2008
  • 644 Answers
SOURCE: Is the Dell Vostro 200 wireless enabled?
Most desktop pc's dont come with any wireless adapters, so i think yes youll need to purchase a wireless card.
Posted on Jan 22, 2010
  • 324 Answers
SOURCE: DHCP is not enabled for
dynamic host configuration protocol, (DHCP) sounds like the service has been disabled, you might want to run a system restore, with me not knowing your OS, or what the reason was, i can only tell you to system restore and use those settings, with confidence, plus its kindof advanced to actually start enabling and disabling services
Posted on Sep 19, 2010
My acer has lost its wireless connection
I would surely recommend the one to better take the acer to a mechanic as handling it on your own may cause problematic issues to the same.
http://mhelpdesk.com/field-service-management-software/
Jan 01, 2014 | Acer Aspire AZ5771-UR30P All-in-one PC...
Enable wireless capability
Certain models of Acer desktop computers are designed with wireless capabilities.
These capabilities can be added to an Acer desktop system that does not connect wirelessly with either an internal or external wireless card, depending on the computer's configuration.
When the wireless connection is not working properly, you can troubleshoot the issue yourself.
The troubleshooting process eliminates the problems that may be preventing the Acer desktop computer from connecting wirelessly.
Check to see if any other computers at the same location are able to connect wirelessly.
The issue may reside with the wireless router or access point.
Power cycling the router or access point may resolve this issue.
Verify that the wireless adapter is enabled.
Click the "Start" button, then "Control Panel."
Click "Network and Sharing Center," then "Change Adapter Settings."
If the wireless adapter is disabled, right-click on it and select "Enable."
Connect to the proper wireless network.
The Acer may be attempting to the connect to the wrong wireless network, or it may have lost its connection to the correct network.
Click the wireless network icon in the task bar.
Click the proper wireless network, then click "Connect."
Enter the network password (or WEP key) if prompted.
May 26, 2013 | Acer Aspire Computers & Internet
Had to do system restore, now it says to undo changes, cannot enable broadcom radiio on acer wireless laptop
Connect to the internet by connecting a Ethernet Cable to the Laptop and the Wireless Access Point/router. Open the Device Manager, Network Adapters, Click on the wireless adapter, is it enabled? yes or no? Yes, update driver. reboot laptop. Is your Wireless Access Point securied? unplug the wireless access point , wait for 30 seconds or so, plug in, wait for selftest, reboot laptop. You didn't supply the Laptop Make, Model or the OS you are using?
Jan 15, 2013 | Computers & Internet
Acer Aspire 5733 Wireless connection lost
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
How do I enable the wireless on my Acer Aspire one?
Open control panel scroll down to Internet connections and click to display. Right click wireless wizard then click choose enable. After this you will be prompted with a box that will show you that the computer has detected wifi connection in the surrounding.
Jun 22, 2009 | Acer Aspire One PC Notebook
Cannot enable wireless on my Acer Aspire 5612WLMi
First, does the modem show up in the device manager (without an exclamation mark or an "x". In other words, does the computer see the card and is it not reporting any problems.
Second, do you see the wireless connection when you go into My Network Places and Network Connections?
Third, does the wireless connection icon appear in the system tray?
Art
Jan 15, 2009 | Acer Computers & Internet
Wireless connection to my laptop
you can't partially wipe your system
do you want to format
open control panel network connections see if network shows then right click then enable if you don't see enable then click repair
check devices see if your wireless still shows maybe needs updated
let me know if you are connected you may need to reinstall driver
i can help
Dec 27, 2008 | Acer Aspire 6930-6771 Laptop
Wireless switch
Although the wireless switch on your Acer does turn on/off your wireless card, you will also need to make sure that your operating system (Windows) has the wireless card enabled.
Do the following:
  1. Go to Control Panel (Start -> Control Panel)
  2. Double-click Network Connections
  3. Right-click on Wireless Network Connection / WLAN (you can tell it is disabled if the icon is greyed)
  4. Click on "Enable" (if you see Disable, your network is already enabled)
You should check the bottom-right-hand area of your screen (in the menu bar) for your wireless icon. If this is not appearing, you'll have to go into Network Connections again and do the following:
  1. Right-click on Wireless Network Connection (your wireless network adapter)
  2. Select Properties
  3. Click the checkbox that says "Show icon in notification area when connected"
  4. Now click on the Wireless Networks tab (at the top of this dialogue box)
  5. Scan for a network and connect to it.
Nov 25, 2008 | Acer Aspire 3610 Notebook
Acer wireless switch
try using the acer epower settings to enable the wlan
Sep 16, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
