Question about KitchenAid Superba® Architect® KSRP22FSMS Stainless Steel Side by Side Refrigerator
I hear the switch click but unit doesnt always run, thawed my whole freezer? Spoiled my milk?
My unit stops running, I can hear the switch click, but then the unit will not run. Only sometimes, is so bad that my freezer had thawed completely a couple times, and my fridge has spoiled my milk.
  • Hopeless L7 May 20, 2009
    the white box on the side of the compressor is the start switch, right? and the relay is the little black box behind the compressor?
    i might actually have KSRU25CRSS model, i cant find a manufacture sticker anywhere. im not sure if that makes a difference. thank you for the diagnoses,
    Guru:
  • 1,524 Answers
Two things. 1. Bad Relay   2. Bad Compressor
The clicking is the overload protector.
Posted on May 20, 2009
Maytag 51105349JA refrigerator top freezer snowing up and won't stop running
Defrost thermostat, defrost timer or defrost heating element is bad. Because of that the evaporator is clogged with ice and the cold air cannot get to the fresh food section. Therefore the thermostat control doesn't get cold enough to turn off the compressor. On the other hand the temperature thermostat may be bad and stuck inn the on position causing the ref to operate continuously thereby defeating the defrost cycle. Uplug the ref and allow it to thaw completely. (24hours). Then while its quiet... turn the thermostat to OFF or 0 and then to the coldest setting and listen for a click sound. No click sound means bad thermostat. Later after thawing plug in refrigerator and observe function after 2 hours and check for cold air flow to the fresh food section. If the refrigerator appears to be okay... the problem is a defrost issue. Most typically a defrost thermostat is bad, but when behind the freezer panel is a good time to perform an ohm/ continuity check on the defrost heating element.
Feb 08, 2014 | Maytag Refrigerators
Frezzer not Keeping things Forzen. I turned up the adjustment, and left it over night to adjust to new Temperature setting. I woke this morning to find everything almost completely Thawed. Fridge seems to...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Refrigerators
My refrigerator it stop working at all. what can be the problem?
few things we need to look at ...first is there any frost on the back wall of freezer. if there is you have a defrost issue either there is a bad heater,defrost terminator switch located on the evap coil or a defrost control... if no frost on back wall check to see that the indoor fan is running in the freezer section (you may have to hold door switch while you have it open to listen) if this is good move to back of unit take back lower panel off and gain access to compresssor is it running? are you or have you heard any clicking come from unit.is the fan in this area running ? place your hand over the compressor is it hot to touch and does it feel like it is running. sometimes the relay on the compressor fails you can remove it if you unplug unit does it rattle?
*** if the unit has ice on back wall of freezer you will have to remove shelves and back panel thaw unit out and check heater using a meter remove wire on each side and check continuity is it good? the defrost terminator is located on the top side of coil or incoming suction line on coil normally clips on and is what senses temperature and makes determination in defrost cycle. the defrost control on time sends power to the terminator switch if it is cold enough it will aloow power to go through to the heater and defrost on time... hope this helps find your problem repost with anymore questions..
Jan 13, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Kenmore model #65802 - freezor sometimes is completely thawed, other times seems to be freezing OK - fan is running. What could cause this?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Dec 14, 2010 | Refrigerators
Freezer cuts on every 3-4 minutes. stays on 8-10 seconds. some thawing occuring
If I understand you correctly the compressor is short cycling. The more it does this the worse it gets by causing the compressor to overheat. Sometimes the problem is because the condenser fan or evaporator fan being defective. Pull away from wall and remove cover over compressor unplug and feel top of compressor and if too hot to keep hand there keep unplugged but do examine the evaporator and condenser fan to eliminate them as a reason. The most likely reason is start relay and or start/run capacitor and sometimes a worn out compressor.
Overload relay click here=> 67002527
Run capacitor click here=> 65889-4
Location Click Here=> MBB1952GR Compressor Components
Parts in that photo are marked as 10 overload/relay, 11 is the run capacitor and 3 being condenser fan motor. Condenser and evaporator fan motors do not always stop completely when bad so make sure both run while compressor is running. If this has been helpful please rate if you have more questions please let me know, Thanks Sea Breeze
Dec 10, 2010 | Maytag MBB1952GR Bottom Freezer...
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
GE Freezer Not Freezing
I am not an expert, but if the defrost heater is not working, then maybe when it was unpluged the coils didn't completly unthaw. If not, the freezer still will not cool properly.
Mar 25, 2009 | GE 13.7 cu. ft. General Electric Upright...
Freezer only cool, fridge not cold as well
it sounds like the relay on the back of the unit may have gone bad.or the compressor has a leak in the line...call a tech out and have it checked...it may be cheaper to get a new fridge
Aug 22, 2008 | Kenmore 53642 / 53644 Side by Side...
Amana refirgerator/freezer combo not working properly
it sounds like a bad:
  • start switch (on the side of the compressor) or
  • compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
  • so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Jul 01, 2008 | Refrigerators
GIBSON DEEP FREEZE IS RUNNING BUT EVERYTHING IS THAWING OUT
Might try unplugging for a few hours and then plug it back in. There is a possibility that it slugged the compressor and there is a restriction in the line. Sometimes when the compressor fails to stop running in cold air the liquid gets back to the compressor. It can cause a bit of gunk to be picked up out of the oil and carried to the expansion line and plug up the line. Maybe turning it off will let the plug fall free and not replug the line. Worth a try anyway.....
Feb 07, 2008 | Freezers
KitchenAid Superba® Architect® KSRP22FSMS Stainless Steel Side by Side Refrigerator Logo
270 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
