Question about Toys
Helicopter slides sideways on takeoff to
On take off helicopter moves to the left instead of going straight up
  • 37 Answers
All helicopters do even real ones you need to add a little collective.
If you have a 2 channel toy then the mainshaft may be bent or the flybar jammed.
Posted on May 27, 2014
1 blade appears to rotate slower than the other 3, so when i try to takeoff and hover it just flips out. Is this defective or a setting issue?
Presuming you are referring to a remote controlled helicopter I have seen many hit something or crash and the set screw for the blade to the shaft has come loose or left the building. If so the repair is frustrating but achievable with diligence and a bit of determination.
Dec 04, 2016 | Miscellaneous
Helicopter swerves right at speed
Hang it from a sting attached to the rotor shaft and see if it hangs level. It sounds to me like it is off balance.
Mar 07, 2014 | WL Toys WL V912 MAX 4CH FP RC Helicopter...
Brookstone Helicopter Cloud DSS
In general, the main rotor in an R/C helicopter only tips forward and backwards of vertical center. Direction is determined by the tail rotor. If the entire machine is tilting right, even if the rotor doesn't appear to be, check the motor mount, and or gear train of the main rotor in the fuselage. The main rotor shaft in the fuselage should be exactly vertical relative to the helicopter deck and with trim tabs centered. If your model has the two small fans, one on either side of the fuselage, try replacing the propeller on the right one, even if it looks OK and check for lint or hair on motor shafts. Again, this is a general answer from my own experience. Hope it helps.
Dec 04, 2013 | Electronics - Others
How to find my potentiometer
It is on the hand controller the two buttons on top of the hand grips keep pressing the button until it stops spinning use whichever button left or right depending on the direction of the spin.
Kind regards, Julian
rccontrolfreak.co.uk
Jan 05, 2013 | SYMA Toys industrial SYMA S009 Micro...
What is the tail rotor in helicopters?
The tail rotor is a piece at the back of the helicopter that keeps the helicopter from spinning by blowing air sideways. It also helps the helicopter to turn.
Aug 29, 2012 | Champion Sport & Outdoor - Others
Why would my sway bar keep sliding to the right instead of staying centered?
Only way that can happen is if whatever it's attached to is moving sideways. Check all diff mounts, track bar and bushings.
Nov 10, 2009 | 2000 Jeep Wrangler
Leaning left on takeoff
needs to be adjusted in the radio
May 11, 2009 | Axial Syma 9086 Helicopter
My Havoc Heli is really hard to control and I need help.
You have to keep tapping the right trim button. Keep tapping it until it stops spinning. If the spinning stops and it just turns, Use the the left right moving analog un til it flies straight.
Mar 15, 2009 | Air Hogs Havoc Heli Helicopters
Toto Dartmouth toilet flapper/chain design flaw
Your right this is a poor design. Space was the main reason for this and functionality was sacrificed. However, you can get a replacement rod at a major plumbing store. You could rig it by attaching a stem to the valve assembly. Allow the chain or rubber piece to slide over it. It is kind of like putting a permanent finger in the path of the chain to give it a "direct" lift up. This would then force the chain to go up instead of at an angle.
Jan 23, 2009 | Toto Dartmouth 2pc. E/F Toilet ...
Tail rotar
Yes - it matters for any heli.
The main rotor creates drag which makes the heli want to spin - the tail rotor pulls the heli in the opposite direction to compensate and keep it steady.
Look at the angle of the main rotor in regard to the direction it turns - you'll see how it 'pulls' upward. The tail rotor will need to 'pull' sideways, according to whichever direction the tail rotor is spinning.
I'm assuming you're reattaching a tail rotor or rewiring a motor?
Nov 19, 2008 | RC Airwolf Rc Electric Helicopter Body...
Toys Logo
267 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
