Question about Sewing Machines
Is the test stitch fabric the same as the actual item you need to sew, if not you might need to change the needle. also check the stitch length to make sure it's set correctly.
Posted on Jan 01, 2014
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Posted on Dec 10, 2007
SOURCE: Brother vx790, my stitches are reversed ( top is on botom & bottom is on top )
It sounds like your tensions are out of adjustment. Your upper tension should be between 3-5 and make sure the tension in your bobbin case is not too tight as well. Pull the thread through the bobbin case and make sure it comes out with a small amount of resistance. If no resistance, tighten the tension just a bit, if too much resistance, loosen it just a small bit at a time.
Posted on Feb 12, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
SOURCE: singer futura beeping every 8 stitches can you
Make sure your thread goes under the plate of the carrousel. If not the machine think is not threaded and it beeps. Thread the machine with your left hand and Pull the thread with your other hand to make sure it "clicks" to every part of the machine.
Another important detail is to add thread nets to your spool. After some used the tension of the machine is affected and the nets help the slippery thread to be pulled by the machine correctly and avoiding the beeping.
Posted on Feb 19, 2010
Jul 05, 2017 | Sewing Machines
Jan 05, 2017 | Singer Sewing Machines
Jul 30, 2016 | Singer Sewing Machines
Mar 13, 2013 | Singer CE-100 Futura Computerized Sewing...
Jan 06, 2013 | Singer 1507
Jul 12, 2011 | Singer Sewing Machines
Sep 20, 2010 | Singer CE-200 Quantum Futura Computerized...
Mar 27, 2010 | Sewing Machines
Mar 16, 2010 | Singer CE-200 Quantum Futura Computerized...
Sep 23, 2009 | Singer CE-100 Futura Computerized Sewing...
52 people viewed this question
