Question about Refrigerators
Fridge not cooling, freezer is ok.
I have an LG fridge freezer. model gr359sq. The freezer is fine but the fridge is not cooling. I have checked the fan which is working fine, i have defrosted completely but has made no difference. I am stuck as to what the problem may be. I've also cleaned the coils etc. When i took the fridge temperature control out of the back of the fridge compartment, there didnt appear to be any electrical wires connected to this. (how does it control the fan?) Is there any way i can test the pcb or control sensors to locate the fault? This fridge is just 2 years old.
  • richard_rich May 21, 2009
    Thanks for your reply.
    It does look like you described but I just cant figure out the functionallity of this. How does it actually control the temperature?
    It is a dial with a thin pipe that dissapears into an insulated compartment which detaches from the fridge.
    From what i gather, there is no way it can possibly communicate with the fan or pcb to tell it the temperature should be increased or decreased as there are no wires connecting this unit to the rest of the fridge.
    How do I bypass the theremostat then? I have read that i need to reconnect wires but there are no wires to reconnect.
    Thanks for all your help.
    Richard
    I have opened the control again and there are no wires connected.
    I have done a self test with the button on the PCB and this lights up the vaction and quick freeze buttons. It also turns all 5 temperature lights on and makes two beeps.
    I have downloaded this manual but it's not making sense to me.
    http://fileshare.eshop.bg/downloadsm/360...
  • 42 Answers
Its usually a bulb of heat sensitive Gas then a long thin pipe that eventually connects to thermostate switch, bypass this switch to seee if that could be the faulty part. Good Luck , the Yeti
Posted on May 20, 2009
  • Yetimagic May 21, 2009
    Take the unit to bits with the dial, there you will see the wires, its a simple switch that just turns the compressor on or off or the fan on or off, dont get a shock! the Yeti
    behind the dial are the wires you need to bypass, the Yeti
LG 262SQA Model fridge cannot cool
That does not look like an LG model number, but regardless, it sounds like the defrost system is not working, allowing frost to build up and block air flow over the cooling coils in the freezer (where all the cooling for the entire refrigerator takes place). Take back panel off inside freezer, melt frost / ice with a hair blower. Test for continuity through defrost heater and replace if "open". If it was OK, problem could be deftost control, or as simple as a door not fully closed at some time, allowing excessive frost build up.
Nov 18, 2011 | LG Refrigerators
The fridgerator won't get cool. Freezer works just fine. But the fridgerator stopped working. The model number is LSC27931ST
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | LG Refrigerators
My Lg Gn-205SQA refridgerator has a problem: the freezer is ok, but hte fridge is not cool
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 15, 2011 | LG Refrigerators
Refrigerator section not cooling: >60F Freezer has been ok. No obstructions to air flow. diagnostic codes displayed are: Refrigerator ER and Freezer section DH Model: LRFC21755 please...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 28, 2010 | LG LRFC-21755 Bottom Freezer Refrigerator
Fridge not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
47sdt
Jun 24, 2010 | LG LRSC21934 Side by Side Refrigerator
Hi, I have an LG refrigerator, the top freezer works fine but the fridge section has stopped cooling, I turned the unit off and next morning there was a large puddle of water on the floor, when I turned it...
When the fridge is not cooling that means the fan are not working or not working properly, need to replace or check if their is an ice bothering the fan to turn. ok
Feb 15, 2010 | Refrigerators
Our LG GR359SQ Fridge Freezer, the fridge has stopped cooling. Everything else seems to still work, freezer, lights etc. But the fridge is warm. Any thoughts?
Make sure the the evaporator fan is running and circulation is getting to the fridge side. Remove anything that could be blocking the vent that brings in the air from the freezer to the fridge. Make sure that no frost is building up in the back of the freezer. If there is frost, then the timer can be going bad.
Jul 12, 2009 | Refrigerators
Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Jul 22, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Refrigerators Logo
282 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
