Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
2009 60 hp Yamaha starts readily runs 4 sec. stops. Has been sitting in hot climate for 2 years. It has very few hours on it. Less than 50.
    Sergeant:
  • 456 Answers
Clean carbs,jets must be blocked,obviously running on fuel from choke
Posted on Jan 02, 2014
How can you get a washer smelling good?
First of all this mainly happens when you use cold water washing, the plastic bowl(s) become slightly porous over time & the dirt from clothes adhere to the area between the inner & outer bowls.
To clean & remove smell.
1. Put washer on hot wash, high level & let it fill with HOT water.
2. Stop washer, put in an old towel.
3. Add a bucket of hot water (This allows the water level to be above the scum mark inside machine.
4. Add washing soda to the bowl (double the amount it says on the packet).
5. Start washer & allow to run to the end of the first wash cycle.
6. Stop washer & allow to sit for a few hours.
7. After the few hours, start washer & allow it to run the rest of the full cycle.
you can do the same procedure with Vinegar.
you may have to repeat procedure a few times.
TO PREVENT THIS FROM HAPPENING AGAIN YOU NEED TO DO THIS PROCEDURE ONCE EVERY 3 MONTHS.
The worst case scenario, you will have get a technician to remove the inner bowl & manually clean these areas.
Apr 27, 2014 | Haier HLP21E Top Load Washer
Shallow water pump keeps stopping
new pump --not big enough for the job
old pump --motor windings problem, faulty start run capacitor
I suspect that as the motor is 1/2 hp if will run good when there is a need for water but under pressure the pressure switch is set to high so the motor overloads and gets hot
Mar 24, 2017 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
Exhaust pipe glows red hot at a steady low rev and at start up instantly hot also little sparks come of it when revving the throttle.
The timing is set wrong OR You cannot let these 4strokes sit and idle.They all do it.They need to be ridden to get the air flowing over them to keep things cool.30 secs. idle at start and after a ride,idle for 10 secs. then shut it down.The sparks will probably be carbon build up inside the motor.You get it hot and they break away and come out through the pipe.All the 4strokes are a HP motor and will get hot if you sit and let it run.Hope this helps
Feb 16, 2011 | 2004 Yamaha WR 450 F
What is the recomended oil for a 2000 yamaha v star 1100
Any oil with a JASO MA motorcycle rating. 10w-40 for colder climate or 20w-50 hot climate. Never use any oil that says "Energy Conserving" on the label it will shorten the life of your wet clutch and transmission gears. Synthetic oil will run cooler and shift easier when hot.
Aug 31, 2010 | 2000 Yamaha V Star 1100 Classic
I have a Yamaha Vstar Classic-650. When i try to start it all i get is a buzzing sound. The bike has been sitting for a few months, but I have always been able to start it up from except for now... can...
The buzzing is caused by a flat battery. or dirty corroded battery terminals.
If the battery is a few years old and has been sitting for a while it often pays to get a new one.
Running a less than perfect battery and or jump starting may cause other problems as it may overstress the charging system.
Jun 06, 2010 | 2007 Yamaha V Star Classic
Yamaha TW 200 starts but won't run.
If the bike has sat for a long period of time without being run - the gas that is sitting in the carb(s) will shellac.. Then the carb(s) would need to be cleaned and "rebuilt"..
Sep 14, 2009 | 2001 Yamaha TW 200
Yamaha 50 hp motor oil red and green oil sensor lights are on
The engine will self destruct if you continue to run it without the proper oil mixture. Some oil systems have to purged of air if ran dry. Seek professional assisstance.
Aug 21, 2009 | Bass Pro Boating
I have a 1976 75 hp 2 stroke evinrude that is overheating. Just got it running after sitting for two years.
In the bottom of the engine is a rubber impeller/water pump. It is in the housing above the prop, not hard to change. Basic tools a six pack and about an hour. The part will cost you about $20, and you can order it from NAPA parts store. They will be about 50% less than a boat shop. Good Luck
May 16, 2009 | Boating
Car not starting after car runs for a while and weather is hot
have the starter tested because it sounds like a bad solenoid in the starter and it makes it get hot so it won't start
Apr 26, 2009 | 1991 Lincoln Town Car
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
88 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
