Question about Compaq Presario 2170US Notebook
How do remove the hard drive in my 2170us so I can replace it
I found a copy of the user manual online and tried to follow the instructions for removing the hard drive, but nothing I do allows me to remove the tray from the base of the computer. There are no screws where it says to find them for me to remove and it holds fast. I'm afraid of breaking the tray drawer if I force it out. I even removed every screw I could find on the base of the laptop and it still didn't come out. Yes, I did removed the battery.
    Problem Solver:
  • 7 Answers
Can you post some photos of that?
Posted on Jan 01, 2014
  • 63 Answers
SOURCE: laptop won,t start up.
Possibility that the HD is toast. You can try to put a new HD in and reinstall the OS if you have the install disks. But the expense may not be worth it. $100 for a HD and another $120 for an OS. The one you have looks like its pretty old and it just might be time for a new laptop.
Posted on Aug 21, 2007
shaky120
  • 310 Answers
SOURCE: How to remove case from acer aspire 9300
Hi, your best bet is to remove the keyboard first, you will find other screws underneath which hold in the bottom section.
Have a good new year
John
Posted on Dec 29, 2007
  • 236 Answers
SOURCE: Compaq Presario R3000 not booting up
set the bios/cmos to boot first of your CD drive. get your support discs and restore to original. your hard drive OS has failed and needs to be re-installed. the problem maybe is that when you do that option you will get all your data erased. your solution to that since you can still get the data on the drive when used as external is to back it up. then full restore your system.
if you dont have your restore kit, you can use your Windows OS to fix it, repair option when you boot from CD.
Posted on Apr 02, 2008
geokohler
  • 304 Answers
SOURCE: Replacing CD-RW/DVD Drive
I own a Presario F730US. I have had it apart many times and it is a difficult case to open. There are several ribbon cables that are easily damaged if you are not very careful. You have to pop up the speaker cover panel as there are case screws under it as well. Once inside you will see the screws that retain the optical drive. Once you remove them it will slide right out and the new one will slide right in. I can not overstate how careful you have to be. If you are not 100% sure of yourself I would recomend that you take it to a repair shop and let a qualified tech assist you. The screws you need to get to are under the keyboard. The whole laptop does not need to be disassembled to swap the drive. Once you pop the speaker bazel and the keyboard you are home free. If you need more help feel free to ask.
George
Posted on Aug 04, 2008
  • 4 Answers
SOURCE: Acer 5720Z removing rear cover to access RAM
just did this one myself and the cover is a real pain and theres a good risk of breaking it. the secret is to get bit of a curve going across the panel so that the clips around the side pull away from the case
thanx for heads up guys
Posted on Aug 15, 2008
How to install memory
Unplug the laptop from the power supply. Remove the battery. Locate your user manual (hard copy or printed from the internet for your laptop's make and model). Now, open the bottom of the laptop, locate the memory bank and follow instructions for memory installation provided by your laptop manufacturer in the user manual.
Aug 25, 2014 | Computers & Internet
Hard drive problem detected instructed to check users manual but cannot locate manual everything is very slow...Is it time for a new cpu? Computer will turn itself to a black screen with the...
Hi do you here any noise from the hard drive?
If so you should backup your data and buy a new hard drive, install it on your pc and install windows and all of your programs again. This is because the noise you hear means that your hard drive is getting broken
Let us know if you solved your problem
Mar 06, 2011 | Gateway E-6000 PC Desktop
Where to obtain a user manualfor the GZHD320BEK model
Here is a pdf copy of the user/instruction manual for your device if you have not already found it.
http://www.northamber.com/CNETimages/USER_MANUAL/8DD82CFA-2EED-48A9-A1E9-8D38F90AF202.pdf
Thanks!
Brandon
Nov 18, 2010 | JVC GZHD320 Everio High Definition (Black)...
1 of 2 hard drives just disconected
Turn the power on your laptop off and remove the battery. If you have it connected to an electrical outlet, disconnect that too before you proceed with anything else!
At the bottom of your laptop, you should see some sort of indication where your hard drive should be. Typically marked by a cylinder or something of that sort. Unscrew the panel and carefully remove the hard drive that could be loose, and then put it back. Repeat the process, for the sake of it, on the second hard drive. They should be together. More information can be found on Toshiba's website, and your User Guide that came with the laptop.
If you do not have the User Guide, Toshiba's website will have a copy online for you to read. I hope this helps you.
Nov 07, 2009 | Toshiba Qosmio F55-Q502 Laptop
Is there diagram to show where the hard drive is acer 5315 if so can i replace it sata 160gb to replace the 1gb
The hard drive on this model is located on the left side of the laptop, underneath the memory card reader.
Oct 21, 2009 | Acer Aspire 5315 Notebook
Where is the hard drive located ?
moz-screenshot.jpgplease copy and paste the link below to access the user manual.
search hard drive as key word for easy reading.
http://www.elhvb.com/mobokive/edwin/laptops/Compaq/Compaq%20Presario/Compaq%20Presario%201230-1250.pdf
Apr 16, 2009 | HP Compaq Presario 2200 Notebook
Cruzer Micro 8GB flash drive - no user manual
Plug it into the USB port. Press Windows-E to bring up the Explorer window, or start My Computer and open the removable drive.
You can then drag&drop files to/from the flash drive just as you do on the hard drive.
Feb 22, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SINGER SIMPLE 3116
Cope and paste the following link into your web browser. You can order a hard copy of the manual or download a free copy onto your computer.
http://www.singerco.com/accessories/manuals.html?man_model_no=3116
Hope this helps! :o)
Mar 25, 2008 | Singer 3116 Simple
Compaq Presario 2170US Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
