Tv no sound no picture
Tv working fine yesterday. When turned on today, no picture no sound but cable box is working
dutchman05
  • 487 Answers
SOURCE: LG LCD/DVD TV no sound on TV - DVD works fine with sound!!!!
HERE is the servce manual for this TV
Posted on Jun 21, 2008
  • 93 Answers
SOURCE: Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Posted on Nov 06, 2008
SOURCE: Samsung LCD tv - Turns on and off by itself.
Not sure if this is the same problem, but I just moved and set up my Samsung 40" LCD and it has been going off and on by itself with the worst yesterday every 2-3 minutes. After speaking with a friend of mine who is not in the Tv business but just has good common sense, I determined it was likely a bad power strip. The bottom line is I replaced the crappy power strip (which was fully loaded with all 6 outlets in use) with the higher quality one I had in the other room. The problem is gone. I suspect the power strip was failing or real bad quality........try plugging the tv directly into the wall outlet first. hope this helped.
Posted on Sep 18, 2009
vinnyq
  • 157 Answers
SOURCE: sound doesn't work on television
Sounds like there was a power surge that caused the audio processor in the TV to go out. This is fixed by replacing the main board.
The power supply board in the TV should also be checked as that could have been damaged as well. These are usually the first to go out from a power surge. Get a good surge protector to help prevent this in the future.
Posted on Oct 07, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Yamaha HTR-5063 is connected with new LG smart TV with HDMI. Today no picture or sound on TV. How to fix it ?
First, you need to identify which box the problem is in. Does the TV work with other inputs? If not, problem in TV. If it does, then the problem is in the Yamaha.
Once you know where the problem is, you can proceed to fixing what's broken.
Jul 10, 2015 | Yamaha HTR-5063 Receiver
Sound okay on tv but no sound on bluray player
Make sure the audio inputs are on the same input as the video cable.
Dec 29, 2014 | Audio Players & Recorders
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Televison & Video
Soound but no picture
Disconnect the A/V cables from the TV and the system and then reconnect them this should work.
Apr 26, 2010 | Sony PlayStation 2 Slimline Console
TV sound but no picture
Can you tell me which Cable box you are using?Which model/region?
The possibility is that the HDCP handshake could not have happend correctly and hence the issue. Try to connect to different HDMI input of TV from Cable box. If possible change the resolution of cable box and check video
Nov 01, 2009 | Philips 50PFP5332D 50 in. Plasma...
Samsung LCD -no picture/sound from any input source-Cable,DVD,PS3
Use the menu button in the front screen of your tv.Maybe your remote control need a battery.
Jul 24, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Green screen with sound from cable, but picture is fine with Wii
That would be my solution. The trouble is either in the box or your connecting cables. Verify this by connecting the cable directly to the set. Then try a new set of connecting cables, or call the cable provider to replace the box.
Feb 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
347 people viewed this question
Top Televison & Video Experts
