Question about HP Pavilion dv7-1130us laptop
Chaning the DV7 screen
I have a broken screen and want to change it, but I cant remove the plastic housing at the bottom of the screen as it is connected to the main body. does any one have any ideas please?
  • farzad_moshf May 21, 2009
    I can get the top part off easily, but the bottom doent shift, and I am worried that forcing it will break the bezel at the bottom.
    Also, I cant remove the screws of the LCD until the bezel is removed ..... kinda catch 22
    Problem Solver:
  • 12 Answers
Once you remove the screw covers and screws from the front lcd bezel you will need to pry the bezel off the rest of the way. Use a nylon pry bar, or small screwdriver to get behind it. The lcd is cracked already and useless to you, so your best to pry off that from the inside. The top will come off relatively easy, but it may be a little tougher at the bottom near the palmrest.
Posted on May 21, 2009
  • ecstrat286 May 21, 2009
    The bottom will come as long as you have the screws on the side out. Its a lot more tough then getting the top off. I like to come down the side from the top and have a pry bar in between.
2005 Lincoln LS V6 Ash Tray stays open, wont close
Pop out the ashtray. Remove the ashtray assembly (the housing). if you flip the ashtray over and look at the bottom you can see a small spot where a piece of plastic has broken off (this should be obvious). In the ashtray housing there is the latch mechanism with the broken "nipple" probably stuck inside of the mechanism. Get the plastic piece out and discard it. Reinstall the housing only.
Now, get a TINY ( I mean really small, like 4mm long and maybe 1/4-1/2mm diameter) screw handy. Drill a slightly smaller hole right through the ashtray where the piece of plastic was before it broke off. screw in the screw from the TOP of the ashtray so it only pokes out of the bottom 1.5 MMor so. Put the ashtray in. If it still doesn't "catch" screw the screw in a little further so it sticks out the bottom a little more. If it binds you've ******* the screw in too far so back it off. You get the drift.
This takes about 30 minutes. It's hard to explain but once you look at the bottom of the ashtray you'll understand the concept. Hope this helps somebody out there.
May 07, 2016 | Lincoln Cars & Trucks
Replacing cracked screen
Insert your plastic pry tool into the seam in the side of your touch and run it along the length of the device to release the back panel from the front.
If your replacement screen did not come with a plastic pry tool, then a small flat-head screwdriver will also work.
Remove the square battery from the motherboard in the front housing by running the pry tool along the sides of it and gently pulling up.
Remove the small piece of black tape from the bottom of the front housing to expose three screws.
Remove the three screws using your small Phillips-head screwdriver. Remove the small screw near the top of the battery connector ribbon as well.
Remove the metal cover from the bottom of the front housing with the plastic pry tool.
This will expose the ribbon that connects the screen to the front housing and motherboard.
Flip the screen-connector ribbon up and gently pop it out. Then remove the two screws at the top of the front housing and disconnect the one other screen-connector ribbon.
This will release a thin metal board at the top of the housing that guards the screen. Pull the metal board out carefully.
Remove the 16 small screws from the side of the screen.
Once the screws are removed, the LCD screen will be free of the housing.
Gently remove the screen and replace it with the new one.
Replace the screws and reassemble the iPod touch the same way you took it apart.
video http://www.bing.com/videos/search?q=how+to+replace+an+ipod+4g+screen&view=detail&mid=3843F00F64220E3352823843F00F64220E335282&first=0&qpvt=how+to+replace+an+ipod+4g+screen
Nov 05, 2013 | Apple iPod touch
How do i open dv7-1451nr?
Instructions
Shut the Pavilion dv7 down and close the screen. After unplugging all cables from the computer, turn it over and remove the battery.
Unscrew the six Phillips-head screws holding the large T-shaped panel to the bottom of the Pavilion dv7. Remove the panel and set it aside.
Remove the keyboard locking screw--marked by a keyboard-shaped icon--from the top part of the compartment exposed when you removed the T-shaped panel. Reserve the screw.
Remove the black Phillips-head screw from next to the wireless adapter inside the T-shaped compartment. This screw holds the Pavilion dv7 optical drive in place.
5
Pull the Pavilion dv7 optical drive gently out of its bay, and then remove the two Phillips-head screws from inside the empty drive bay. Reserve the screws.
6
Remove the Phillips-head screw next to the circular intake fan vent in the corner of the Pavilion dv7.
7
Remove the five Phillips-head screws from inside the empty battery compartment. You should now have removed 16 screws in all. Turn the Pavilion dv7 over and open the screen.
8
Insert a spudger or other flat plastic tool into the seam between the speaker grille and computer casing on the right side of the Pavilion dv7. Gently pry up to begin removing the speaker grille from the computer. As you do this, move the spudger to a new location to pry different areas until the grille is completely disconnected. Mind the ribbon cable connecting the center of the speaker grille to the logic board, and do not lift the grille any higher from the computer than the cable allows.
9
Push both sides of the speaker grille cable lock forward until the cable slides easily out of the logic board connector. Set the speaker grille aside.
10
Remove the four Phillips-head retaining screws above the top row of the Pavilion dv7 keyboard. Lift the keyboard up and forward, and place it face-down on the palm rest.
11
Unlock the Pavilion dv7 keyboard cable connector using the same method as for the speaker grille connector. Slide the cable out of the connector, remove the keyboard and set it aside.
12
Place the new Pavilion dv7 keyboard upside-down on the palm rest. Slide the keyboard into the connector, close the lock and rotate the keyboard down into the computer. Replace the four Phillips-head screws.
13
Slide the speaker grille cable into the connector and close the cable lock. Push the speaker grille into its original position above the Pavilion dv7 keyboard. Press gently on all parts of the speaker grille until it is flush with the computer casing.
14
Close the screen and turn the computer over. Replace the five screws inside the battery compartment, the screw next to the intake fan vent, the two screws inside the empty optical drive bay and the screw inside the T-shaped compartment.
15
Replace the t-shaped panel on the bottom of the Pavilion dv7 and its six screws.
16
Slide the optical drive back into its bay and replace the securing screw.
Jan 10, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
My hp pavilion dv7 keeps running after the lid is closed
Change the settings in the Power section to shut-down when lid is closed. Power Settings, Advanced Settings, Change setting to shut-down when lid is closed.
Oct 29, 2012 | HP Pavillion Dv7-6165us 17.3" Amd...
IPod touch-shattered screen, thou can still be used.can u replace the front screen?
yes it is but you will need some certain tools
video
hope this helps
http://www.ebay.com.au/itm/New-Touch-Screen-Digitizer-Glass-Replacement-iPod-Touch-4th-4-4G-Gen-White-/330783433649?pt=LH_DefaultDomain_0&hash=item4d043aa3b1
Au $11.54 + postage Au $2.95 worldwide
im not sure if this is the right one you need
you could get this on Ebay if you dont have an account you will need to create one
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Oct 10, 2012 | Audio Players & Recorders
My samsung dishwasher wont drain.
The draining is done by a small plastic impeller in the bottom of the dishwasher. Look for a screen in the bottom that is screwed down. Removing the screen should give you access to the impeller. In my case, a small piece of broken glass slipped past the screen and jambed the plastic impeller.
Aug 26, 2012 | Samsung Dishwashers
Chaning timing belt
It's a three peice cover that bolts to the front of the motor,it looks like the middle or bottom peice needs to come off first,it may help to remove the front passenger side tire,there are often holes covered with rubber holes on the inner fender that allow easier access to some of the components on the front of the motor.Has you husband ever done a timing belt before?
May 15, 2009 | 1997 Ford Escort
How to remove the tail lights from a 2003 murano
Here's the step by step procedure from the beginning.
  1. Carefully remove the black one inch wide plastic molding strip that runs along the interior side of the tail light. This can be pried off carefully without breaking the plastic clips that hold it in place.
  2. Using a 10mm socket, remove the two bolts that you see which secure the tail light housing.
  3. The tail light housing is also held in place with three or four plastic clips which can be broken rather easily if you don't do this next step carefully. Begin prying the plastic tail light using a plastic putty knife or screwdriver. The top clip comes out pretty easily and so does the bottom one.
  4. On a cold winter day, the middle clip is the one that can break rather easily so gently rock the tail light or wait for warm weather when the plastic isn't brittle.
  5. Once the tail light "bucket" is removed it's a simple matter to replace the bulbs.
Oct 03, 2008 | 2003 Nissan Murano
AOC lm929 monitor
AOC LM929 or Envision EN-7100 removal instructions:
DANGER!!! UNPLUG and allow the monitor to discharge before servicing.
with a small flat head screwdriver, insert into the edge and pop open the small plastic
pieces that surround where the stand connects to the monitor. put plastic pieces aside.
lay monitor on soft flat surface front side DOWN. with a phillips head screwdriver,
remove 4 screws in the center that hold on the stand. put stand and screws aside.
lay monitor on soft flat surface front side UP. insert flat head screwdriver into the
side edge of the grey plastic and turn screw driver so the plastic surrounding the
screen edge pops up exposing an area surrounding the screen. put plastic rectangle
piece aside.
slide out plastic buttons piece from the side and put aside.
with a phillips head screwdriver, remove 8 screws (4 on top and 4 on bottom) that hold
the screen assembly to the back housing. now lift screen assembly out of the plastic
housing. put back plastic housing and screws aside AND lay the monitor screen with the
FRONT side down on a flat soft surface.
with a phillips head screwdriver, remove 2 screws that hold on the metal electronics
cover. slide the cover down and remove. put the cover and screws aside.
USE CAUTION!!! Some components may still contain a charge.
check fuse... whatever...
Aug 29, 2008 | Computers & Internet
HP Pavilion dv7-1130us laptop Logo
1,084 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
