Question about Samsung Luggage & Travel
Samsung Charger is not working?
I've issue with charging my phone Today in the eve the charger fluctuated many times and now it's not working what can be the possible reason for it?
alexdcd
  • 17 Answers
SOURCE: Htc touch charging port stop working
It may be caused by dirt ingress in the port, check for dust and clean out with a soft fine paintbrush (like an artist brush) soaked in pure alchohol, or vodka! Short of that solution, purchase a charger of ebay and place battery in the rear to charge.-
http://cgi.ebay.co.uk/DESKTOP-CRADLE-CHARGER-for-HTC-TOUCH_W0QQitemZ130204421069QQcmdZViewItem?hash=item130204421069&_trksid=p3286.c81.m63.l1177#ebayphotohosting
Kind Regards, ACD
Posted on Mar 14, 2008
nightlisa
  • 102 Answers
SOURCE: Samsung glyde - no response to charging
Find someone else with a glyde and ask them if you can trade them batteries for a day to see if it's a bad battery. ( you can usually buy a battery for $5 on ebay, or up to $20 in your carrier cell phone store)
If the problem follows your old battery, toss it and buy another battery.
And if neither swapping out the charger and the battert solve your problem then its the phone itself. I have called in to our cell companies before and let them know we have a phone that will not hold a charge no matter what battery or charger I use... and they usually replace free it under warranty as long as the phone is less than 12 months old, and the white squares in the battery compartment are still white. (Pink Red means oops! water got in there) and then you’re only getting them to cover replacement if you have cell phone insurance
Posted on Jan 07, 2010
SOURCE: my samsung metro pcs phone wont hold a charge and
there i no need troubling yourself further, the problem with your phone is the charging port, the charging port of your phone is bad that is why, your phone battery cannot hold charge.
Change the charging port of your phone and your phone will charge and hold charge.
Regards.
Posted on Apr 26, 2010
SOURCE: my samsung gravity 3 won'ty charge in car
This problem cannot be fixed. You'd have to return your Gravity 3 and exchange it for another model. It's a known problem with Samsung and should acknowledge it and recall this product (or fix it with a software update free of charge). I spent a whole day at different T-Mobile stores and finally a rep showed me the technical bulletin on it and exchanged the phone.
Posted on Sep 14, 2010
russjw24
SOURCE: my huawei ascend m860 wont
OK.. try this.
Take out the BATTERY.
Plug the phone in to charge (without battery)
Wait a few seconds, then turn the phone on (while plugged in)
If it starts... put the battery in and put the back back on. (leaving it plugged in)
Wait for it to charge.
It may take awhile for it to look like it's charging. Mine took like 10 minutes before it removed the "X" on the battery icon.
Posted on Aug 27, 2012
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
My samsung corby cannot be charge..how can i solve this problem?
I would try charging it with a different charger. its more likely that the charger itself is the issue. If not then the issue could be with the phone. Try a hard reset of the phone ( pulling the battery) and then put battery back in and plug in charger. try moving it around if no connection issue could be with the charger or the charging port on the phone.
Oct 19, 2012 | Samsung GT S3850 Corby II
Samsung gt-c6712 charging solution
My Samsung GT-c6712 mobile is having charging issue. when i connect the charger sometimes it workes and othertime doesn't. same charger works for others mobile, charger is ok. i am using for last 15 months,i bought @ 6600 price means 6600/15 =440Rs per month. many times when i am listening songs and if i make a call it hangs, i need to remove battery to restart it. instead of keeping attention on diff new functionlity these people should rectify common issues and improve basic functionality.
Aug 03, 2012 | Samsung Gt-C6712
Champ 3303i battery not charging
The battery or charger may be defective
Mar 29, 2017 | Cell Phones
Hi, i've had my Samsung genio touch for over a year now and i've had no problem untill now, the phone will not charge up, i've tried putting the charger in a different socket and taking the...
a possible battery or charger problem.
check if you can charge using a diff. charger,if you can?then the charger is the problem,replace it.
but if you can charge w/a diff. battery?replace the battery. :)
Sep 09, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
My Samsung Blackjack II won't charge.
Return to the carrier for warranty repair.
If you are out of warranty there are some options you can choose from
1. Get repaired
2. New phone
3. external charging source
The external battery charger runs about 20 dollars on ebay with an extra battery.
Check out the following link to find more about these options
Samsung BlackJack II Battery charging problems
Jul 02, 2009 | Samsung BlackJack II Smartphone
Samsung SGH E840 won't charge with charger
I just have the same issue and unfortunately I can see the phone's plug it's messed up. I can see a pin inside came of the connector and it's pushed all the way in the back. Used original Samsung charger only!!<!-- from fixya rte -->
Feb 02, 2009 | Samsung SGH-E840 Smartphone
Samsung D900i
It is probably the charging port. It seems to be a common issue with this model of phone.
If it is the charger port on th eD900, You have 3 options.
1. get it repaired, under warranty if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay
For more information and links to the parts check the following link below.
Samsung SGH-D900 will not charge problem
Aug 29, 2008 | Samsung D900i Cell Phone
Phone not charging
If the new charger is also not working then surely it's the problem of that charger port (valve). It must have been damaged.U need to get it fixed from the hardware vendor.
Oct 05, 2007 | Samsung SCH-a870 Cellular Phone
Luggage & Travel Logo
51 people viewed this question
Top Samsung Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you a Samsung Luggage and Travel Expert? Answer questions, earn points and help others
