Sony pcg 281l
My son dropped this TV/computer. Now I have a black screen on the left side of the monitor. I now dont have a computer and only half screen on the tv. Can this be fixed? What is your best guess on what the problem might be? Thanks, Pat
  • 468 Answers
It is probably a broken backlight. This should be able to be fixed. It may be aconnector came partially loose when it was dropped. This shoild also be fairly easily fixed. Hope this helps.
Posted on Jan 01, 2014
scrodamoon
  • 659 Answers
SOURCE: using tv as moniter for games
Try setting the resolution on the desktop when you are on the tv I found that I had this problem before myself and the only way to make it bigger was adjusting my desktop resolution I had also made sure all my settings where correct on my tv as well but I think if you goto the advanced properties on your secoundary or primary if you are using that and adjust the resolution.
are you using VGA or SVIDEO?
Posted on Nov 30, 2008
  • 54 Answers
SOURCE: I have a single yellow
Let me guess, its an LCD? Unfortunately this has happened with blue lines to our customers.
Sorry, but chances are you wont be able to do anything yourself, best to take it to where you bought it from (or ring the manufacturer) to get a replacement (if its still under warranty), else you may need to purchase a new one.
Posted on Dec 16, 2008
Yomitako
  • 70 Answers
SOURCE: Monitor displays a black half circle 1.5 inch diameter in upper left conrner of screen.
Depending on the age of the monitor, this could be a symptom of a failing LCD display (or CRT tube, if you're using one of the older styled big ones). one way to test for sure though, is if you have access to another computer (whether it be desktop or laptop, shouldn't matter) and hook it up to that one and see if the same thing happens. If it does, then you know that your monitor is at fault. If you are within manufacturer's warranty you can usually get it repaired through your place of purchase, or directly with the manufacturer themselves, but if not, then repairs are usually not worth it, and will probably cost more than the monitor is currently worth.
Posted on May 07, 2009
  • 35 Answers
SOURCE: I have a verticle black area on the left side of my computer moni
make sure no other electronic items like T.V r near by n better don place mobiles close to monitor n also don keep speakers parallel to monitor front panel
Posted on Sep 18, 2009
kinkate18138
  • 117 Answers
SOURCE: looking for instruction manual for
PCG-281L is the hardware configuration code of the computer. Based on the configuration code the computer belongs to VGC-LT1 series computer model. From the below link you can download the Manuals and Specs for this series models:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=VGCLT10E&LOC=3
Thanks!!!!
Posted on Dec 19, 2010
How do I hookup an external monitor to my desktop sony vaio all in one touchscreen model PCG-281L
please see which cable is supported to your sony vaio touch screen is either hdmi or vga
Oct 20, 2016 | Sony Computers & Internet
Can i connect my playstaion3 to my laptop so i can play with this screen
No you cant this only has an external jack to use for a big tv the Laptop that is
Jan 02, 2014 | Sony Vaio Pcg-71c11l Laptop Screen 15.6...
Sony vaio pcg 281l personal computer
It seems that your OS has registry problem, there are only two ways to fix it:-
1) Re-install your Windows with Re-partition your drives (In that case you have to take backup of your all data.)
2) Start PC in Safe mode, then download a reliable program like i always use Reginout to fix my OS registry properly.
Thanks
Dec 31, 2013 | Sony VGC-LT16E VAIO 22" All-in-One Desktop...
Sony pcg-71315l mother board power on ok capslock ok but no display,15.6 screen ok.
Ether Vga Cable faulty or the screen or on board graphics or graphics card shot
Dec 26, 2013 | Sony Vaio Pcg-71315l Laptop Screen 15.6...
I can only get half a picture on my monitor
Do you experience the same issue write at the start-up Also notice if you can see any visiable changes on the part of the screen which is not showing the display? if nothing shows up. I suggest you take your laptop to a hardware shop as this may be due to the faulty cable or lose connection between the screen and the motherboard.
Sep 18, 2013 | Sony Vaio Pcg-71c11l Laptop Screen 15.6...
My sony Bravia kdl-46v5500 screen has colored lines on the left side then half the screen flicks black then the same left half side of the screen stays black then will go back to normal and then go...
These sets use for the most part two boards--each drives the screen on one side---also possible as suggested here the problem is inside the panel or where it connects to these boards--if inside the panel (the entire front screen unit) it is fatal as it cannot be got at and the display costs more than the set did new.
Oct 29, 2012 | Sony BRAVIA KDL46V5500 46 in TV
Does laptop have a reset button
dont think so but try system restore to earlier when it did work
Aug 12, 2012 | Sony Vaio Pcg-71c11l Laptop Screen 15.6...
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
Sony vaio lapto black screen
Please check that they have any LED blinking. If it not blinking it is hardware issue. need to contact local tech. if it blinking. Reboot the computer and taping F10 button while you rebooting the computer and run system recovery and follow by the steps.
Mar 17, 2012 | Sony VAIO PCG-7181L, PCG-7182L, PCG-7183L,...
Looking for instruction manual for sony vaio desktop model pcg-281L
Thanks!!!!
Dec 11, 2010 | Computers & Internet
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
