Question about Black Halo Projector Headlights - LHP-GLF92JM-TM
Headlights illuminate when brake pedal is pushed 2000 ford f 250
  • Spec-D Master
  • 17,328 Answers
Remove the bulbs from the brake light sockets and see if it still happens. If it does not, you have a bulb or socket that is bad. If it goes away, put one bulb back and test and then the other to see if it is the bulb.
Posted on Jan 12, 2015
Why does My 2000 ford windstar shake when I push on the brakes
It could be a warped brake rotor, or it could be a worn component in the suspension.
May 27, 2014 | 2000 Ford Windstar
I have a 2000 Dodge Durango and I keep blowing the fuse for instrument lights and tailights
hello same pronlem with my 98 durango but right turn signal!
what it was is the 4 pin connector for the tow package had the insulationripped off them i guess whe backing out of a steep driveway it sxrapped! so the headlights, turn signals, and brake circuits where grounding out! quick fix!
just cut and capped that mess!
good luck
Mar 02, 2013 | 2000 Dodge Durango
When headlight are on and hit the beake pedal only the 3rd brake light comes on the rest are stuck . When i release brake pedal it seems like i am driving with my brake light on . but my headlight off...
It may sound silly, but check your brake light bulbs to see if they have been installed incorrectly. Brake light bulbs have two filaments, one for tail light, and a brighter one for brake lights. On some cars if the bulb is installed wrong, the brighter filament will stay on for tail lights. The only other thing I can think of is the wrong bulbs have been installed.
Dec 25, 2010 | Toyota Camry Cars & Trucks
2000 Jeep Grand Cherokee, I had blinkers and flashers no brake lights, and after checking the bulbs in the light itself I dont have blinkers or flashers at all
Just no turn signals in the back now? Maybe didn't install the bulbs tight back into the asm? No brake lights...do the lights work with headlights on and just no illumination with the brake pedal depressed? Could be brake light switch.
Oct 01, 2010 | 2000 Jeep Grand Cherokee
I need good photos or instructions to change the brake light switch on a 1999 ford expedition
from autozone.com
f43af9d.gif Fig. 2 Brake pedal position switch removal- F-150, F-250, Expedition and Navigator; 1999-00 F-250SD, F-350, and F-Super Duty Models
  1. Disconnect the negative battery cable.
  2. Disconnect the brake pedal position switch.
  3. Remove the self-locking pin.
  4. Remove the brake pedal position switch from the brake master cylinder push rod.
  5. Remove the brake master cylinder push rod spacer.
  6. Remove the brake master cylinder push rod bushing.
  7. The installation is the reverse of the removal.
Sep 24, 2010 | 1999 Ford Expedition
My brakes lights stay on when my headlights are on, but the brake lights work fine when my headlights are off. Do you know what may be the problem?
This problem likely is the filaments touching in one of the dual filament bulbs used for the brake lights. Another sign of this would be the dash illumination lights coming on when the headlights are off and the brake pedal is pressed. The solution is to replace the defective bulb.
Feb 04, 2010 | 2000 Hyundai Elantra
I have a 2000 ford f 250 1-cyclinder booth brakes
It's at the top of the brake pedel. There is a switch that is held in place by two nuts, it has come loose, make sure that when you tighten it up, it is being pushed up by the pedle, the when you press your brake it completes a circuit. That willl turn your lights off
Aug 03, 2009 | 2000 Ford F250 Super Duty Crew Cabs
Brake Light Problem on 2000 Ford Expedition
sounds to me that the sensor is out there should be a little sensor behind the brake pedal adjust it foward .
Mar 23, 2009 | 2000 Ford Expedition
Electrical fault, Brake-light / Side light
hi simple one the brake light bulb replace the bulbs brake light filiment has gone on one side droped on to the lights circiut hence press brake light headlights come on and vise versa yates210456
Oct 05, 2008 | 2000 Ford Escort
2000 ford focus rear driving lights
Had this problem myself. Try replacing your brake light switch, they are not real expensive and can be changed in a matter of mineuts. It is located by following your brake pedal all the way up to the top, when you get there , there id a switch that when you push down on the brake it releases the button to put you brake lights on and when you take your foot off the brake itallows the switch to go back.
Jun 20, 2008 | 2000 Ford Focus
Black Halo Projector Headlights - LHP-GLF92JM-TM Logo
52 people viewed this question
Top Spec-D Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Spec-D Vehicle Part and Accessory Expert? Answer questions, earn points and help others
