Question about Bosch Tassimo TAS4511UC Coffee Maker
Tassimo lid will not open, how do I open without breaking it?
Lid will not open after using.
My tassimo lid wont open and cant get my disc out
My tassimo lid won't open I put the milk pod in for a latte it made a noise and some milk spilt out and it won't open turned the machine off for a few days n the lid still won't open is it now broken ? As only had it for a few months
Jun 12, 2017 | Coffee Makers & Espresso Machines
Why won't lid close?
Hi,my friend had one of these and they sied that if the coffee pots are not inserted or they are the wrong ones his lid didnt close iver,hope this was some help.
Sep 17, 2016 | Braun Tassimo Espresso Machine/Coffee...
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
Yellow and red light on but nothing happening?
I have a Tassimo. The machine reads a bar code on the coffee cartridge that you put in before pressing brew button. You open the dispenser lid, place a cartridge in with the printing facing down. If you notice, the label has a bar code on it. There is a small rectangular window on the machine that you can see when you open up the dispenser lid. Make sure that the window is clean. If there is debris covering it, the machine wont be able to read the bar code and therefore will not know how to dispense for the specific cartridge you put in.
As for the manual, I found one on the Bosch website to download.
Good luck.
Jan 09, 2014 | Bosch Tassimo TAS4011GB Coffee Maker
Lid won't close
Take the disc out, hold the disc holder down flat, then close the lid. Open up and will work as normal. If this works for you, please visit sun-light. co.uk
Dec 20, 2012 | Bosch Tassimo T20 Brewer Color Kit
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
My whirlpool top load washer won't drain and spin
This is likely to be a problem with the lid switch.the lid switch is activated by the lid stricker when you lower the lid.these machines will normally fill & wash without needing the lid closed but when it gets to spinning & draining the lid must be closed,so the machine is acting as though the lid is open.the lid has probably been dropped or slammed shut & this can break the lid switch from where it mounts with 2 phillips head screws.
May 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Braun Tassimo 3107 lost instructions
where do i get instructions on how to use the braun tassimo 3107
Dec 29, 2008 | Braun Tassimo Espresso Machine/Coffee...
Tassimo Goes Right From Auto to Standby
I called Tassimo customer service and they helped me solve the problem. The sensors need to be reset
1) unplug machine
2) Before turning on, push and hold the START button
3) Release the START button after the machine is on
4) Insert T-disc and close lid
5) when it goes to AUTO , press START
this fixed my problem
Dec 31, 2007 | Braun Tassimo Espresso Machine/Coffee...
Tassimo
Mine sometimes does this but cleaning the barcode reader at the top of the machine (small glass panel) fixed it. Also make sure the water container is seated correctly. If these dont fix it try pushing the water container left right/back front while there is a disc in the machine-mine has started to only work if I push the fitted water container backwards when "brewing".Its out of warranty now so I will make do until it breaks completely. Regards Nicki
May 09, 2007 | Braun Tassimo Espresso Machine/Coffee...
Bosch Tassimo TAS4511UC Coffee Maker Logo
1,158 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Donald Currie III
Level 1 Expert
ray gallant
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
