Question about Dometic Rooftop RV Air Conditioner
Charging freon r22 - Dometic Rooftop RV Air Conditioner
    Genius:
  • Dometic Master
  • 1,363 Answers
You would have to install line tap valve to charge unit.
Posted on Aug 17, 2015
Which gas are refill in 210 whirlpool fridge
Hello Arushdeep Singh,
I have tried to find a "210" whirlpool,..
Sadly only finding some vague references to a
17 cubic foot OLD TIME refrigerator... (?).
The good news: If indeed you are speaking of
an "OLD TIME" unit more than 3o years ago
your gas is Freon R22...
The bad news is that is BANNED and your
choices are varied... interesting and all fairly
expensive.... (hideously expensive).
Sorry that is all I can relate on a MODEL 210.
(Lot of R22 scams going on out there... be careful).
((of course)).
30 pound canisters sell for under $800 US Dollars.
R22 FREON REFRIGERANT 15 oz CAN UNUSED eBay
May 14, 2017 | Whirlpool Refrigerators
Bad condenser unit GOODMAN
it is a 3 ton condensor you still can buy r22 freon condensors new but they have nitrogen charge and its expensive to charge I recommend to go with 3 ton goodman condensor which is new 410a puron and also change indoor coil and flush the line set so you dont endure the high cost of new copper lines these new systems come with 10 years warranty and the r22 systems come with only five years
Feb 26, 2013 | Heating & Cooling
I have a goodman Model CKL 36-1K . It says Factory Charge oz R22 . Does that mean it uses R22 freon? The guy who sold it to me says it uses 410a and was only 2 or 3 years old. The serial # is 040637071 ....
Hello, the unit is a 3 ton and was built in 2004. 0z R22 stands for R-22 refrigerant. Not sure why he told you 410a but if the unit says R-22 than that must be used.
Jul 06, 2012 | Goodman CKL36AR36 Air Conditioner
How to add freon to a coleman mach model# 8633-876 serial # 089817583 do you suggest r12,or r22 freon type. is this a easy procedure or does it take a ac person? the problem is it not cooling to full...
It's R-22 and you need to be licensed to handle it, if you're not a A/C service technician or fimiliar with charging an A/C system, then it is best to have a Coleman Service Technician to charge it for you.
Aug 29, 2010 | Coleman Mach 15 Air Conditioner
How do you add freon to a mitsubishi split system
If its R22 you have to have a license to buy it. But outside unit on the larger copper line will be an access will look like a 3/8 copper fitting with a cap on it there is also one on the small line. You will need a tank of r22 and a set of gauges. If the compressor is running you add freon til the large copper line starts to sweat. The small line (high side) should not slug or have the gage on it jump this means its overful or has air contamination in it. Always add thru the larger line.good luck
Aug 12, 2010 | Mitsubishi Heating & Cooling
I need t recharge the freon. It takes R22. Where do I charge this system? I pulled the roof cap off and cannot find and caps to recharge the system
AC's routinely are sold/installed without charging valves.
So, unless your unit has been worked on/serviced in the past it will not have any place to charge with freon.
Note: unless you've developed a 'leak,' it is unlikely that you've lost any freon, and in the event that you have - it will take a Service Tech to install valves and charge your unit correctly.
I would call a Service Tech to assist.
hope this helps.
Jun 07, 2010 | Dometic Rooftop RV Air Conditioner
Who to added R22 freon to my a/c condenser unit and what hose on my gages need to be connected to hight pressure and lowe pressure
the red hose connects to smaller line...usually 3/8's....the blue connects to larger that has black insulation. The yellow to tank of freon. The unit must be running to put in blue hose. If unit nit running put in red hose. Must be done by someone with EPA 68 license
May 10, 2010 | Whirlwind FH-778 Air Conditioner
What should refrigerant gauges read when charging walk in freezer?
Depends on what kind of refrigerant its works, if is an old unit probably is charged with R12 or R22 newer ones work with R404 ;for R12 presures should be around 20psi on the low side and 160 on the high side ,for R22 about 60 and 250 and for R404 50 and 350 ;you have to look at the condensing unit tag to find out what type of freon its uses ,or look at the expansion valve at the evaporator coil.
Jul 31, 2009 | Everest Refrigeration Freezers
CAN R12 BE ADDED TO AN AC HOME UNIT USING R22.UNIT IS RUNNING BUT NOT COOLING
No, R12 and R22 are not compatible freons. You need to recharge with R22.
Jun 30, 2009 | Whirlwind FH-778 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
41 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
