Question about Walgreens By Homedics Automatic Blood Pressure Monitor 1ea
Bulb leaks rubber is cracked. where can I get new bulb
I need help on how to change a headlight bulb on my 2000 toyota tundra
  • 1 Open the Tundra's hood and locate the back of the headlight assembly inside the engine compartment.
  • 2 Unplug the electrical connector from the assembly and remove the rubber cover from the bulb socket.
  • 3 Release the retaining spring to loosen the old bulb, and then pull it directly out of the socket. Carefully dispose of the bulb to prevent it from cracking or shattering.
  • 4 Align the tabs of the new bulb with the cutouts of the mounting hole. Then, carefully press the bulb into the socket until it's secure.
  • 5 Install the rubber cover in its original position and reattach the electrical connector to the headlight assembly. Make sure the rubber cover is fastened to the socket before continuing.
  • 6 Start your Tundra's engine and test the headlights to make sure they work before closing the hood.
Jul 30, 2011 | 2002 Toyota Tundra
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
When I'm pumping it up the ball sticks and will not inflate. I hear air coming out from the ball you squeeze.
If this is happening when the finger valve is closed, there is a leak either in the rubber tubing or the inflation bulb. Try putting soapy water on the tubing and then on the bulb. Squeeze the bulb with just your thumb and forefinger, so that you can see any air bubbles. If the leak is in the rubber tubing, you may be able to repair it with a couple of laps of vinyl tape. If the bulb is leaking, that will have to be replaced.
Hope this helps you solve the problem.
Mar 18, 2011 | Health & Beauty
2005 Toyota Corolla - both headlight lenses are fogging and will cost $1,000 CAD to replace. Is headlight lense fogging unusual?
You might want to check if the lense is sealed properly. The seal might be cracked and be letting moisture in. Also check where the bulb goes in too...There's usually a rubber seal on that too.
Dec 07, 2010 | 2005 Toyota Corolla
Primer bulb will not take in the fuel in it seems block
A fuel system inspection is needed here. You need to check the intank fuel filter,(make sure its not clogged) the condition of the fuel lines,(soft, not brittle with no tears or cracks) ,the ventin the gas cap,(little rubber tube must allow air in). Foremost, check the condition of the bulb itself:sets in (primer base assembly) that has very small check valves inside it controlling the inflow and outflow of fuel. There cannot be any air leaks as the bulb on the carb and one mounted remotely from the carb depend on a vacuum effect to operate correctly. So some disassembly and acute inspection will be required.
Nov 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Fuel leaks bulb not priming.
If you have a leak the bulb will not prime. Over time the either the rubber on the primer bulb gets a pin hole in it requiring bulb replacement or one of the fuel lines cracks and introduces air into the lines. Unless the system is completely sealed the primer bulb will not work. Make sure all of the connections on the fuel lines are tight and correct the system leaks.
Thanks for choosing FixYa.
Kelly
Aug 27, 2010 | Ryobi Snap In Primer Bulb Pump 683974 ...
I need to remove the taillight on a 2005 Dodge grand Caravan and install a new one. What are the steps needed to perform the task?
Open tailgate. Remove the 2 taillight housing screws, using a trim tool or screwdriver. Turn the taillight housing towards the outside of the van to disengage the retaining hook(tab). To remove the bulb squeeze the tabs on the bulb then pull straight out. When doing this check the rubber grommet the tab goes in replace if cracked or worn. this causes leaks if bad
Nov 03, 2009 | 2004 Chrysler Voyager
Primer Button
This part is sold as an assembly Part# 530038874
Undo the screws holding the primer and note the fuel line location
as the new one will be identical.
Note the long and short tube connection under the primer bulb itself and the designated tube for each
Jun 04, 2009 | Garden
Headlight out 97 Nissan Sentra
should just be the bulb. Open you hood and look on the back of the head light. should be wires going into the housing. Grab the fitting the wires are going through and turn, then pull out the bulb
Jan 01, 2009 | 1997 Nissan Sentra
Walgreens By Homedics Automatic Blood Pressure Monitor 1ea Logo
23 people viewed this question
Top Walgreens Health & Beauty Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Walgreens Health and Beauty Expert? Answer questions, earn points and help others
