Question about GE 169137 Classic 4-Slice Toaster
Replacement parts knob that lowers the toast on the left side in broken
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
www.dummies.com/how-to/content/how-to-fix-a-broken-toaster.html
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
https://www.youtube.com/watch?v=QKiJkpuHy-Q
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
Nothing works except toast position.
Probably a burnt out element. See this video if you want to fix it
Jan 05, 2016 | Kitchen Appliances - Others
How do I change time and date on timex indiglo
  • How to Set Dial Indiglo Watches
    • 1Pinch the winding knob on the right side of the watch between your thumb and forefinger.
    • 2 Pull the knob out from the watch slowly until it clicks into the first position.
    • 3Turn the knob to move the hour and minute hand to set the time. Move the knob clockwise to move the settings forward and counterclockwise to move them backwards.
    • 4 Pull the knob out further until it clicks into the second position. In the second position (the one furthest from the face), turn the knob to set the calendar, if your Indiglo has one. Turn the knob clockwise to move the settings forward and counterclockwise to move them backward. Push the knob back in to the watch face when you are done.
    How to Set Digital Indigo Watches
    • 1 Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
    • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
    • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
    • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Read more : http://www.ehow.com/how_5758168_set-timex-indiglo.html
    Mar 31, 2015 | Timex Indiglo Watches
    Why does my toaster ony toast one side of the bread
    Because the nichrome wire on one side of the toast has broken.
    Its time to get a new toaster.
    Mar 17, 2015 | Baking
    We have two of the same Dualit Mini Oven's and the same knob on both has broken. It is the Function Dial for Bake, Broil, Convection and Toasting. How do I go about getting these Knobs. The units we bought...
    Well you could try to hold whoever you bought this from to their warrenty. You can buy the knobs on ebay and have them shipped to your house. To replace the knob just carefully pry the old knob off evenly on both sides and the push the new knob on.
    Jan 06, 2011 | Dualit CTS4E 4-Slice Toaster
    The lever to push down the toast will not lock in to start the toastng cycle
    Inside the toaster (behind the toast, bagel, etc. Buttons) there is a magnet, this needs to be clean for the taster to lock. First, unplug the unit. Now remove the cap on the thumb lever and the four screws at the bottom, separate the toaster. Now you will see the magnet, remove any debris with a dry towel or with your finger tip. After properly re-assembled this should work.
    Dec 20, 2009 | Oster 6330 4-Slice Toaster
    Ge wpsq3120t2ww I have a broken control knob, how do i replace this?
    Knob(s) on left side of machine just pull off. Make sure the metal D clip comes off too. Push new knob on.
    Timer knob: Pull knob out and remove nylon clip off back side of knob. (use a thin screwdriver to push it off, or a thin needle nose plier to pull if off) then knob pulls off easy. Push new knob on with clip already in place. Easy.
    Jul 08, 2009 | GE Profile WPSR3120WWW
    Left side dont work
    The holder is a bimetallic strip that heats up and opens when it reaches a preset temperature based on the darkness setting. It should latch onto the toast loading mechanism when cold and then snap open when it reaches a certain temperature. The darkness setting knob adjusts the point at which it opens. Probably either the release mechanism is broken or bent or the setting knob is broken. You can disassemble it when unplugged by removing the screws on the bottom and prying off the toast loading knobs by placing a ruler wrapped in cloth against the housing and prying the knobs off with a large screwdriver carefully going back and forth from side to side. If the knobs break or won't go back on use a high temperature epoxy to reassemble. You have a good side to compare the bad side to. Look for differences from one side to the other as the toast loader lever goes down and as the darkness knob is rotated. You may just have something blocking the mechanism. After working on it, plug it in outside to a ground-fault protected outlet on a fireproof surface before attempting to use it.
    Oct 25, 2007 | Waring WCT708 4-Slice Toaster
    Duraband 4 slice toaster manual model # TS-5221
    if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
    ok...
    if u need instructions on how to use a toaster...here goes:
    When:
    A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
    Where:
    Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
    How:
    To toast bread in a toaster, follow these instructions:
    1. Place slices of toast, one each, in the slots on the top of the toaster.
    2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
    3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
    4. When the toast is finished, the slices will “pop” up automatically.
    5. Remove the toast from the toaster.
    WARNING:
    If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
    *For further safety, it is recommended that the toaster be unplugged after each use.
    I wish u luck and happy toasting.
    Oct 14, 2007 | Kitchen Appliances - Others
    GE 169137 Classic 4-Slice Toaster Logo
    61 people viewed this question
    Top GE Kitchen Appliances - Others Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Sal De
    Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
