Question about Lenovo IdeaPad Computers & Internet
My lenovo ideapad z500 monitor
Screen is not bright, how i can change it to be bright
    Champion:
  • 200 Answers
Type in model # on lenovo.com download the manual for the monitor usually just push button on monitor Menu move to brightness adjust to higher brightness
Posted on Jan 02, 2014
KingDWS
  • 1606 Answers
SOURCE: Lenovo S series ideapad will find my dlink router no network addr
Generally if you can see the D-Link then everything is trying to talk. Would have to know if the d-link is new out of the box or is part of an existing setup. If the d-link has been part of the network I would suggest that you don't have the security settings correct. If you right click on the network icon and look at the send received numbers. If received is zero then your problem is you don't have the security key (WEP or other type)) setup. If you are getting recieved numbers you may not have the DHCP setup in the d-link. DHCP assigns the numbers to the computer but the d-link has to have this turned on in some models others it is by default.
If both your laptop and dlink are not new and specifically about a year old then I would also suspect that the dlink has died or is dieing on you. If you have had periods of disconnects or slow jerky network acess then these are signs of the dlink having problems. The wireless part tends to go after a year or so while the wired portion probably still works. When they go they are annoying as they work then they won't and so on.
That is you next step to try is to plug in your laptop direct to the wired connection on the dlink to test if the problem is the wifi portion of the dlink. If it connects your problem is the wifi and you probably will have to replace the unit. Next plug it into the cable modem and see if the problem was in the dlink itself.
Posted on Jul 09, 2009
  • 38 Answers
SOURCE: Lenovo IdeaPad Y530 - 40512SU screen is dark
Have you installed the Lenovo EnergyCut drivers? Without it, laptop may not work properly and turns extra hot. Try letting it cool down before you try again.
Posted on Oct 28, 2009
SOURCE: Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
Posted on Jun 24, 2010
ErusTownsend
  • 592 Answers
SOURCE: Lenovo Ideapad- screen has begun
The screen control board coudl be goign bad. The heatsheild in the screen could be the cause. The cable that sends the signals to the screen could be bad. The graphic chip could be overheating or could be starting to detatch from the motherboard.This is not something you should look at yourself. It is best to be taken to a technician.
Posted on Mar 21, 2011
SOURCE: my lenovo ideapad y560's monitor
Hi thelzy,
I see that your Lenovo Y560 is having issues showing no Video, you mentioned that you only get a Black screen when booting.
I am assuming that there is still power on the machine but no video at all, Just to ask do you still see the Lenovo Splash screen? if not then we can try doing a power cycle on the machine.
* Remove the battery on the system unhook the Power Cord/AC adapter as well then press and hold down the power button of your Y560 Laptop for about 15 seconds then let go.
*After Doing the Power Cycle connect the AC Adapter again but leave the battery out for the time being then turn the compute ON, check to see if it will show the Lenovo Splash screen if it does then we're in progress and should show windows Loading up on the LCD screen.
*If it does not show the lenovo Splash screen then most probably the BIOS screen never showed as well on the issue.
*Connect the battery back n the machne turn it ON again check if it will show anything on the screen, if not then see below.
*We can try connecting an external mnitor to the system using a VGA connection it should show us the Screen on the external monitor if not then it means that Windows as well is not booting on your Laptop.
*Check the indicator Lights on the Laptop, one of the Lights will be a cylinder icon on the Laptop check if there is any activity from that light if there is no Light or any avtivity to any of the indicator lights then your Y560 is having issue with the Motherboard.
I hope this info Helps.
Have a nice day.
mvincentc
Posted on May 01, 2011
Lenovo Z400 bright ness issues
Is the brightness problem only when the battery is low?
May 23, 2014 | Lenovo IdeaPad Z500 Laptop Computer -...
Lenovo idea pad Z400
Try this if you have Windows 8.1:
https://forums.lenovo.com/t5/Lenovo-P-Y-and-Z-series/Z400-Adjusting-the-Brightness-in-Windows-8-1/ta-p/1303113
When I update Windows 8 to 8.1 Lenovo Z500 Series Laptop than My computer Brightness is decrease?Please give me solution
Try this:
May 13, 2014 | Lenovo IdeaPad Z500 Laptop Computer -...
Adjusting screen brightness on lenovo z500
Lenovo ideapad z500 hardisk partitioning and resize without losing okr
You can use partition softwares to partition the drive.
eg: Minitool Partition Wizard Home Edition(its free)
Partition WizardWindows PC and Server Disk Partition Management Software
Or,if you have the original Win 8 cd and product key,you can re-install Win 8 and during the process partition the hard disk. But doing this may result in losing all your data.
Apr 09, 2014 | Lenovo IdeaPad Z500 Laptop Computer -...
Turn off monitor computer insteadmy lenovo ideapad z500 monitor
Pressing the F key that has a screen logo will turn off the laptop display.
Jan 01, 2014 | Lenovo Computers & Internet
My lenovo z500 has a screen brightness issue. It very dim and it won't turn up no matter what I do?
Hi, I had this problem also and I don't know why, but Lenovo Ideapad Z500 seems to have some compatibilities issues with a new Intel video card.
So, what you need to do is rolling back the HD intel video card driver to the previous version OR go to the following path: D:\drivers\VGA\Intel\x64\9.17.10 and press Setup to install the old driver again.
That solved my problem. It's a shame that I can't upload this driver in my laptop.
Mar 18, 2013 | Lenovo IdeaPad Z500 Laptop Computer -...
Screen suddenly dimmed, will not get brighter
Your LCD screen is dying. The backlights can go over time. Other then try to replace the screen there is not much you can do. You can always run it off an external monitor if you are like most people and use it a desk most of the time anyhow.
Jan 12, 2013 | Lenovo IdeaPad Z500 Laptop Computer -...
Computers & Internet Logo
127 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
