Question about Dell LATITUDE Computers & Internet
No bootable device found
No boot sector on internal hard drive..... no bootable devices?
3 Suggested Answers
  • 31 Answers
SOURCE: no boot sector on internal hard drive
If the bios or setup utility can't detect your hard drive then this can be a physical problem. I suggest that you reseat or tighten the cable connecting your hard drive to the motherboard. You need to open the hard drive panel then unplug and replug the hard drive cable.
Posted on Jun 10, 2009
  • 916 Answers
SOURCE: Won't turn on
No bootable device usually means that your hard drive has failed. It is either not connected properly to the computer or the drive needs to be replaced.
Posted on Oct 27, 2009
HP 255 How do I setup bootable disk ? I have tried esc and seled internal cd-dvd room but it doesn't work
On the HP System, you'll need to press the escape key as the system is starting up, and then hit F9 to get to Boot Device Options. Once there, you can set the boot order. After you've set the boot order, you'll also need to make sure that you have bootable files in the device that you've selected as the first boot device.
For example, if you've set the first boot device as CD-ROM drive, and the second is the Hard Disk Drive, then you'll have to make sure that there's a bootable CD/DVD in the drive when you start the system. If no bootable files are found on the first boot device, it'll automatically check the next boot device, which is the Hard disk and start booting from the Hard disk.
GuruAid
May 18, 2014 | Computers & Internet
No boot sector on internal hard drive. No bootable
A boot sector is a sector of a hard disk that contains booting programs stored in the other part of the hard disk. You boot sector might have been deleted or corrupted and you can't logon until you repair or recover the boot sector. To do this you must have your OS cd. Boot from OS cd the follow below steps...
Windows Vista
1. Insert the installation disc.
2. Restart your computer
3. If prompted, press any key to start Windows from the installation disc.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7.
On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Boot from you hard disk then you're done!
Regards,
Jeep Brainy
Jul 29, 2009 | Dell Inspiron 6000 Notebook
Get message internal hard disk drive not
This may mean that your computer is trying to boot from a non-bootable drive. Try hitting f12 when you restart the computer and select which drive would have your OS on it. You want to change the boot sequence to diskette drive as your 1st choice. The order should be Diskette Drive, Internal HDD, USB storage Device, CD/DVD drive.
Apr 08, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
Operating system not found dell inspiron
There are some possibilities:
1. There is a bootable device (such as USB flash drive) attached to this laptop, but the device does not have proper operating system,
2. There is a media in the DVD drive, and it does not contain proper bootable system,
3. The hard drive is dead, so the laptop does not find any bootable device,
4. The hdd boot sector is damaged,
5. The required boot files are missing or damaged.
You can check:
- 1 & 2: check the laptop and the dvd tray,
- 3, 4 & 5: Check using DVD reinstallation media. It will check and try to install an operating system, so it will detect the previous operating system. There is an option to repair the previous operating system, so you need to read the available options. If you have valuable data in this hard drive, then you need to take out the hard drive and copy the data to the other data storage.
Mar 01, 2014 | Computers & Internet
No boot sector on internal hardware
There are several causes for this. First make sure the Bios recognizes the Hard Drive as the Primary Hard Drive. Second, double check to be sure the drive is properly seated and connected . If these are both done and set properly your drive has either been erased or lost it's master boot record due to a Virus or Error. You can try using the Windows recovery system to recover the boot sector but I would simply use system recovery and format the drive and reload it to factory specification.
Nov 12, 2011 | Dell Latitude 110L Notebook
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Won't turn on
Oct 27, 2009 | Dell Inspiron 1521 Laptop
No boot sector on internal hard drive no bootable device-f2 for setup utility
Jun 10, 2009 | Dell Inspiron 6000 Notebook
"no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
Jan 02, 2009 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
142 people viewed this question
Alun Cox
