Question about DeLonghi Heating & Cooling
Problem with thermostat
I bought a delonghi HVF 3031 fan heater yeterday.according to manual , in order to adjust thermostat, i turned thermostat knob to maximum position then I selected the power level. At desire temperature , i gently turned thermostat anti -clockwise till the click sound heared and fan turned off. The problem is it doesnt stArt automatically when temperature drops. I would be grateful if you can help with this issue.
  • 3 Answers
Try this. Do as you already did above, but this time turn the thermostat slightly clockwise till it comes on again, and leave it at that setting for a while. Does it control now?
Posted on Jan 01, 2014
  • 686 Answers
SOURCE: Adjust Delonghi oil heater thermostat
you can't
Posted on Mar 01, 2009
rowdy45176
  • 2176 Answers
SOURCE: button on wick adj. knob won't engage to remove or adjust
the wick could be dirty and or burnt not allowing for the know to be moved to the off position, I would suggest cleaning the wick or replacing before doing anything else.
Posted on Dec 08, 2009
  • 215 Answers
SOURCE: a/c and heater not turning on. Thermostat may be
Make sure the cover is on the furnance and secured properly, the next thing to check is the switch located on the side of the furnance it could have been accidently move to the off postion. If these two check out you will need to replace the thermostat.
Posted on Dec 14, 2009
  • 182 Answers
SOURCE: how to adjust a programmable thermostat I just
I am sending you this link which contains the users manual. I hope this helps.
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2210ES.pdf
Posted on Dec 29, 2010
richroth
  • 9472 Answers
SOURCE: My Laars Lite 2 Heater was heating the water, but
Here is the manual for your unit. Look at page 32 for troubleshooting the "temperature control circuit". There is also a wiring diagram and parts ordering list in case you need it.
Regards, Richard
Posted on Aug 03, 2011
Manual
There are several 'types' of electric air heaters. Some have solid-state control boards, others, bi-metalic strip, and open contacts. The most simple is a bi-metalic strip and an adjustment knob for the temperature. Turn knob to lowest setting, plug unit in, turn knob to full, then when room is comfortable, then adjust knob until you hear a click. now system will cycle on - off keeping the room at the temperature you set.
Apr 16, 2014 | Heating & Cooling
Thermostat Problem
The thermostat may have failed even though the unit is new.
Jan 01, 2014 | DeLonghi Heating & Cooling
How to light a pilot
Turn the knob on the gas valve t the PILOT position. Press down on the knob so that gas can get to the pilot. Light the pilot. Keep holding down the knob till the thermocouple gets hot enough to hold the safety magnet open and keep the pilot burning. Then move the knob to the ON position. Once that is done raise your thermostat setting till the heater comes on then adjust according to you comfort and party on Amigo!
Oct 27, 2012 | Heating & Cooling
I have a Lochinvar pool heater that on the dispaly is showing Air Pressure Switch Open. I looked at the manual and it talks about air flow from the supply vent and exhaust vent. Than it says about...
Hi and welcome to FixYa, I am Kelly.
Try this before taking anything apart to far:
The pressure switch is located in the front header, behind the
upper side jacket panel, above the water connections. When
required, the pressure switch can be reset with the following
procedure:
1. Clean filter and skimmer.
2. Start filter pump.
3. Set digital thermostat to highest setting.
4. Turn the adjustment knob on the pressure switch clockwise
until the combustion air fan in the front control panel turns
off. Fan will not turn off if system pressure exceeds 5 PSI.
5. Slowly turn the adjustment knob counter-clockwise until the
combustion air fan turns on. Turn knob an additional ΒΌ turn
counter-clockwise.
6. Turn filter pump off and on several times. The heater should
shut down immediately when the pump stops.
7. If the heater does not shut down immediately as the filter
pump stops, repeat steps 4, 5 and 6 until proper operation
is achieved.
8. Reset thermostat to desired temperature setting.
If after doing all of the above you still have the problem.... you can remove the switch and check for debris in the water passages. If you find debris remove it, reinstall the switch and repeat steps above.
- Still have the problem... Replace the switch.
Thanks for choosing FixYa,
Kelly
Mar 21, 2011 | Lochinvar ENERGY RITE 399000 BTU PROPANE...
My delonghi toaster oven knobs broke! as
Hi, you can purchase them on amazon. Here: Amazon com delonghi knobs. I think this was helpful, Have a nice day
Jun 12, 2009 | DeLonghi EO1260 1400 Watts Toaster Oven...
Delonghi TRD0715T heater
turn timer knob clockwise till arrow points to correct time (your time), there are plastic protrusions "ticks"around the knob, they move in and out, move them in for on, and out for off
select time sectors that you wish hearted to heat, each tick is 15 minutes, experiement and become profecient
Oct 27, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Vulcan oil heater
1. Check electricity is on.
2. Check oil is in the tank and valve turned on.
3. Switch the fan off at the bottom left hand corner.
4. Switch oil knob to No.1.
5. Set Air knob to No.3.
6. Operate re set button (right hand corner of heater under settings dial). Either press in until it clicks or if the pull out version pull out until it clicks.
Wait - ignition should take place in a few minutes and flames will appear on the left of the burner under the radiants.
You should get occasional yellow crests above the pure blue flame just visible below the top row of burner holes under the radiants.
After the red warning light goes out you can adjust to higher settings.
The radiants do not glow on low setting.
You can adjust the heater on to higher settings but this should be done gradually - no more than 2 settings at a time.
Some warnings:
* The unit must be correctly earthed.
* Do not use anything except heater oil.
* Never attempt to re-light the heater when it is hot.
* If the red light does not appear when the oil knob is switched on, immediately turn the oil knob off. Reasons include: Heater is too hot; Electric plug turned off; failure of ignition system.
Good luck - no responsibility taken for the advice (but it is largely copied from my Vulcan heaters instruction manual which I still have (installed in 1967).
Mar 26, 2008 | Heating & Cooling
Delonghi DR18T Timer Replacement
before you replace the timer, check and see if the timer has a battery in it. if it has, then change the battery. it will work fine.
Jan 25, 2008 | DeLonghi DR-18TG Oil Filled Radiator...
Heating & Cooling Logo
106 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
