Question about Breville VDF065 Halo Health Fryer
Paddle wont lock on - Breville VDF065 Halo Health Fryer
Drum paddles replace
Assuming the paddles are attached with nuts/bolts I would suggest using Locktite. If that is not an option, lock washers. If the paddles do not attach using nuts/bolts, invest in some high end epoxy.
Dec 16, 2013 | Washing Machines
I have a 05 neon that wont shift out of second gear. When I first crank and drive runs fine when I break or stop check engine comes on. I can reset it then it will shift but after five minutes light comes...
It could be due to malfunction of brake paddle switch. you have to check brake paddle switch. if brake paddle switch get choked it can be happen due to Peddle switch gives signal to ECU as a vehicle stopped.
Apr 15, 2013 | Cars & Trucks
I have a 2000 nissan pathfinder and the door wont unlock. It has central locking which wont work, when i put the key in the lock it wont turned so i am pretty up the creek without a paddle n locked out of...
this may be expensive but call a locksmith or if you have one of those long metal pieces with the hooks on the end trie that if you dontand plan to keep this car then you shold get one
Good Luck
Sep 06, 2012 | 2000 Nissan Pathfinder
Harmontec 210 dvd/tv When you turn it on it has a red paddle lock in the bottom right corner and it responds to nothing but on/off. The lady says she just bumped the remote a little and it went right into...
If the remote has a "Music" button press and hold this until the lock disappears. If the remote does not, press the "Display" button until the lock disappears. This seems to work with almost all of them with this problem.
Jul 27, 2011 | Televison & Video
Locked??
You will probably have to have your service provider help you with this ... Best thing to do after you get in is do a hard reset.
May 14, 2010 | RIM BlackBerry 7290
Locked??
You need the password to unlock it. If you bought it on ebay you should contact the seller.
Mar 25, 2010 | RIM BlackBerry 7290
LG wont dispence ice
hi there,
sounds like you have ice in the ice bucket. it's most likely that the ice paddle is jammed or broken. check around the ice door and paddle for anything visibly broken as well. you may have to replace the ice paddle.
Sep 30, 2008 | LG LFC25760 French Door Refrigerator
Breville VDF065 Halo Health Fryer Logo
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
