Question about Sony BRAVIA Televison & Video
Restart sony tv - BRAVIA Sony Televison & Video
I have a sony bravia 46'' lcd 2x hdmi tv when I GO THRU MORE THEN ABOUT 10 CHANELS KIND OF QUICKLY the tv goes to a green screen and stays on a green screen until i restart the tv is this norm
I find it unlikely this is normal.
I am not a betting man but..........
What I would do is invest the time to contact Sony customer service and talk to someone who can access their database.
They like other major companies keep extensive records of every complaint recorded---see if anyone else had this issue.
Sony has had some beauties---Recently an issue where heat warps the door made of plastic in front of the lamp resulted not in a free part but free repair and or replacement of the 3-4 year old sets involved.
let me know if you have questions
Mar 16, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
How to connect to a sony tv
If your laptop has an HDMI port you can buy an HDMI cable and connect to your Sony TV. Most TVs now come with an HDMI cable
Once connected your TV should show the screen from your laptop if not
press Function and F5 buttons simultaneously! Alternatively you can restart your computer!
Still problem! Go to control panel and click on display and choose Sony TV good luck!
Sep 24, 2011 | Toshiba Satellite Pro L300 Notebook
My Sony Bravia KDL-52nx800 restarts every 10 to 20 minutes. I switched electrical outlets and made sure that all connections are secure but the problem persists. Thanks, Nat
A Sony that Restarts would be a overheating issue within the TV decoder witch is a common issue with some Bravia line TV's.
Many people wall mount these Tv's but not thinking of ventilation witch brings a major concern.
Now after relocating the tv and making sure there is plenty of ventilation , you still have issues with restarts you may want to have this repaired.
Allot of people tried to software update there tv and rare instances this has settled the restarting issue, you most certainly can try that here is the link
There are a couple causes and one major one is ventilation witch you can most certainly give a shot. The software update is also recommended in this case as well.
I sure hope this is "very helpful" to you, Do wish you luck on your issue
Rulds2008
Jul 16, 2011 | Televison & Video
Sony wega engine 3lcd. turns itself off
It must be dlp tv that use lamp, is it?
If its true then replace lamp in tv that reached to end of its working life span and causing problem.
Your question shows it is CRT tv but symptom says it would be dlp tv.
Let me know if you have additional question about tv.
Jul 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
HDTV, projection tv, tv shuts off by itself, green light blinks, tv restarts, red light doesn't light up, any thoughts?
good day. your tv has a defect . you need a qualified technician to fix your problem. but for the best is to consult your problem to sony servive center.
Jun 24, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Sony trinitron tv loses picture but sound remains
Check solder joints on high voltage transformer and also on Q 502 transistor, this is a common problem for sony
Mar 13, 2010 | Sony Televison & Video
Tv keeps self restarting after about 30 - 45
When lamp in TV become weak in result and consume more current then its rating , TV gets that symptom, on for few seconds/ minutes, shuts down and turns on itself.
Please replace lamp in TV as procedure is written in user manual of TV and its easy.
Let me know if you have further question.
Thanks.
Dec 13, 2009 | Sony KDS-R50XBR1 50" HDTV
Tv is shutting down then restarting.
How old is this TV, if its more then 2 years old and have not replaced lamp yet then its problem of weak lamp. Please replace its lamp and always purchase Sony original lamp for smooth TV function.
Mar 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Sony vaio Pcv v300g tv tuner device failed to open
Install the Driver manually, the automatic installation of the driver is not installing the drivers properly, that is why when you restart the system it is not able to identify the device. for this uninstall the driver restart your system then install the driver manually.
Feb 12, 2008 | Sony VAIO PCV-V200G PC Desktop
Televison & Video Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
