Proscan television will not turn on
Television will no longer turn on by pressing the power button on televiosn or or remote. There is power to the tv because the steady red light is there. I got in yesterday by unplugging the power from the back of the tv and plugging back it. I had to do this multiple times because once the tv was on I didn't have any volume. When it cam on the screen display was not normal and had to "warm up" a couple of minutes for the normal display.
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. //
Posted on Jul 01, 2017
  • 208 Answers
SOURCE: Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Posted on Mar 29, 2008
  • 905 Answers
SOURCE: Remote's menu and input buttons, and television Input button not responding
well the problem sounds like it could be the IR sensor on the tv or somthing in that circut that is failing or the EPROM chip that controls : Vol up/down , Channel up/down , Power on/off ,Menu , Input selection , ect... is failing, thus this will trigger the protection circut to shut the tv down. this kind of a problem only gets worse and can dammage other components if not repaired soon so it will need testing to determine the exact cause
Posted on Oct 14, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
SOURCE: TLA-04011c 40in. LCD TV: Red light is on. TV
I have the same TV and I just replaced the Capacitors. It came with 2 10000UF 10V caps and I put in 2 1000UF 35Volt caps from radio shack. Its like brand new. There is even a video on how to change them on You Tube.
Posted on Nov 16, 2009
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
Proscan tv codes
I found this on ChaCha.
The most popular code to program a remote control to a ProScan TV is 10047 (Others: 10466, 11347, 11447). ! - See more at: http://www.chacha.com/question/what-is-the-code-to-program-a-remote-control-to-a-proscan-television#sthash.S9wE8CE0.dpuf
I hope this helps!
Jan 04, 2014 | Televison & Video
Don't know how to activate closed caption, and cannot find instructions
What is the TV source? For some sources (set top box), you may need to turn on the captions using the menus of the box.
Assuming you are using a source that gives captions that the TV can interpret, if you have the Proscan 26LA30Q remote, press the CC button to toggle through the caption options. Another route is to press Menu (either on the remote or the buttons on the side of the TV) then select the Feature submenu with the left/right arrows. Press Enter (menu when you use the buttons on the TV) then navigate to the Digital Closed Captions option. Here you can set the captions to on and adjust the size, style and color of the captions when they appear on-screen.
If you are using a universal remote, try the CC button. If it doesn't work, try another code for the Proscan TV on the remote. There are some codes that may not control all of the functions of the TV with the remote.
Crutchfield has the manual for the TV on the product site: http://www.crutchfield.com/S-Kaec3gBqVtM/p_68326LA30Q/Proscan-26LA30Q.html . The direct link is http://a248.e.akamai.net/pix.crutchfield.com/Manuals/683/68326LA30Q.PDF .
I hope this helps
Aug 18, 2011 | Proscan 26LA30Q 26 in. LCD Television
Programming comcast remote
the codes for the remote to access a Proscan TV are as follows: 11447, 10047, or 11347. I assume you know how to get into the remotes coding mode, but if you don't Here is how you go about it press setup, then press and hold the TV button until the light flashes then input one of the code sets, then if you get a confirming flash hit the power button if the TV turns off your golden if it didn't repeat the cycle with the next set of numbers I gave you. if after you have tried all three numbers you still can't get the TV to react to the remote you will need to call 1-800-COMCAST and speak to someone on their technical staff.
Dec 08, 2009 | Proscan 32LC30S60 LCD TV
Remote control doesn't work
What do you mean, it should turn on with the power button, try changin the batterys if not the IR unit is dead you can pick up a univeral remote at any radioshack..
Apr 22, 2009 | Proscan PS36109 36" TV
Convergance setting
Convergence procedure for Proscan chassis CTC188 is: 1) press and hold menu- press power- press vol.+.(P00 and V00 will be displayed 2) release menu- press vol+ and adjust until V80 appears. 3) press ch.+ and navigate using directional buttons on remote and tv button to save/exit. Hope this helps. If not e-mail me.
Apr 19, 2008 | Proscan PS60690 60" Rear Projection...
Remote Code
The code 11178 worked for us for our Comcast remote.
Lauren
Jan 13, 2008 | Proscan 26LA30Q 26 in. LCD Television
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Televison & Video Logo
Top Televison & Video Experts
