Question about Armitron Watches
I have Armitron 20/4660sv with 4 hands (date, time 24 hrs,day,) but i dont seem to balance them. help!
SOURCE: WATCHES
i hope this helps....
the top right says st/stp....tells you the year
the bottom right is the light...
the top left is the reset....
and the bottom left is mode...alarm, stop watch,and time 2
Posted on Dec 01, 2008
escapement
  • 2334 Answers
SOURCE: 24 hr utc display is not synchronised with the rest of the watch.
Here is the link to get full instructions how to set or reset your watch (paste it into your browser):
http://www.citizenwatch.com/CUK/English/technicalinfo.asp?caliber=C650&ModelNumber=JR3060-59F
Choose: Interactive Settings Instructions.
You need a pair of speakers or earphones connected to your PC as all instructions are visible and audible.
Do not forget to rate, please.
Posted on Jan 06, 2009
escapement
  • 2334 Answers
SOURCE: CANNOT SET TIME OR DATE AND ALARM
Follow this link and find instructions:
http://www.armitron.com/watch_instructions.asp
Rate, please.
Posted on Mar 31, 2009
SOURCE: setting time and date
need the right time on my computer, need a time change
Posted on Jun 22, 2010
mcdevito75
  • 1970 Answers
SOURCE: How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Posted on Jul 21, 2010
How to set for 24 hrs.
Dec 29, 2015 | Watches
How do I set alarm on Armstrong 45/7041 watch? Did not come with instructions
A= reset
B= Mode
C= ST/STP
D= Light  (edl)
•SETTING TIME AND CALENDAR
1.For time telling mode, press 'B' three times. The seconds should start to flash. Press 'C' to zero out the seconds.
2. Press 'A' minutes will flash, press 'C' to set the minutes.(holding down C will advance the digits faster)
3. Press 'A' hours will flash, press 'C' to set hour.
4.Press 'A' date will flash, press 'C' to set the date.
5.Press 'A' month will flash, press 'C' to set month.
6.press 'A' The day of the week flashes, press 'C' to set day of the week.
7.Press 'B' to finish and it will return to the time.
IF ANYMORE QUESTIONS ABOUT SET FEATURES SUCH AS 'STOPWATCH, SPLIT TIME, SETTING 24 HOUR ALARM, ACTIVATING ALARM, OR SNOOZING THE ALARM'. FEEL FREE TO CONTACT ME @ vannabeltran8.sb@gmail.com WITH 'ARMITRON WATCH' IN SUBJECT BAR AND I WILL SEND YOU PICS OF THE MANUAL.
-Savannah:)
Feb 14, 2015 | Armitron 457004WHT Womens White Nylon...
Set the time on a 3-button Armitron All Sport 45/6963
I have the same watch. I've figured out how change in and out of 24 hour time.
1. press and hold "ST/STP" until the month/day screen is visible.
2. while holding "ST/STP", press "MODE". A 'p' visible below the month/day indicates 12 hour mode. The absence of a 'p' indicates 24 hour mode.
Manual for 4-button version is here, but all the directions are applicable. https://www.armitron.com/images/upload/XNAPE01.pdf
Nov 05, 2012 | Armitron Watches
Watch instructions for Armitron m721 (49/1009 GP) need to set time and date
Hi mandardani,
You can change the time and day of your Armitron watch by following the steps below.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
Jan 05, 2011 | Armitron 40/8125BLK Digital Sport Watch
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
How do i set the time on a armitron 45/6975 watch i lost instructions
Hi an_stocker0,
There is two pulls to set the time and date .First pull is for the day / date wind it in order to choose the right date number and second pull is for the time wind it until the desired time comes out. For better understanding follow this link for more information and instructions below. Feel free to ask whatever the results.
http://www.armitron.com/docs/Automatic%20Manual.pdf
Hope its may helps;
Regards, VOTIT
Dec 10, 2010 | Armitron Two Tone Sports Watch
Cant set the day and date on the Armitron 40/8106 watch - time is ok.
Hi madlugi,
You can easily change the day and date of your Armitron watch by following the steps below.
Hope it helps.
Dec 05, 2010 | Armitron 40/8125BLK Digital Sport Watch
How do i set the time and date on my watch?
This is direct link to all ARMITRON watch manuals/instructions: http://www.armitron.com/watch_instructions.asp
or
You can also try with this approach. This is for Armitron WR 330,but i believe this could also help you.
The following labels are on the inner ring of the watch; I've given their positions relative to where numbers would be on the face of an analog watch.
"ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
To set the time, date, and day of week:
Press and hold in the "MODE" button until the display starts flashing. (This is the alarm time.)
Press the "MODE" button again; the seconds begin flashing. Press "ADJ" to set them to zero.
Press the ""ST/STP" button to change what you want to set. The options appear in this order each time you press the "ST/STP" button: minutes, hour, month, day, day of week.
Use the "ADJ" button to change the value of the setting.
Touch "MODE" to save the settings and return to time mode.
Thanks for using Fixya. Please rate the solution.
Nov 06, 2010 | Armitron 165 watch
I bought a ladies armitron watch.. and can't reset time.. day etc is fine.. the symbols left hand side say 'set' 'mode' right hand side 'ADJ' 'AL' ... can you help.. Thanks Leanne
Thank you for contacting FixYa.
  • Look at your watch as if it were a clock face, even though it may be a digital. Most Armitron watches have four buttons around the perimeter of the watch. There will be a button at the 2 o'clock position; this will be button "A." There will also be a button at the 4 o'clock position. Consider this button "B." On the opposite side will be button "C" at the 8 o'clock position and button "D" at 10 o'clock.
  • Press the "D" button until the numbers begin to flash on your digital watch. Press and hold the "D" button again until the seconds begin to flash by themselves. Press the "B" button to advance the seconds. You may hold down the button in order to cycle through the numbers faster.
  • Hold down the "A" button in order to move on to setting the Armitron minutes. Once they begin flashing, press the "B" button just like you did to adjust the seconds. Press the "A" button one more time, and you will see the hours flash on your watch face. Hold down the "B" button and cycle through, making sure the a.m. and p.m. is correct.
  • Change the date on your Armitron watch by once again pressing the "A" button. This should cause your date to blink. Press the "B" button to change the days.
  • Cycle through the months by pressing the "A" button one final time and holding down the "B" button.
  • Aug 27, 2010 | Armitron Watches
    Jul 21, 2010 | Watches
    Watches Logo
    Top Armitron Watches Experts
    Ansel Alberto
    Ansel Alberto
    Michael Vincent Cruz
    Are you an Armitron Watch Expert? Answer questions, earn points and help others
