Question about Continental Mercedes Benz 2001 E320 Aux Fan Belt
Engine cranks but won t start
Was driving one day and it just cutoff. tried restarting it, the car cranks but it won't just start. on two occasions after sitting for a while it started for a second, and then shut off again.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 52 Answers
Check your fuel pressure at fuel rail with fuel pressure gauge. Pump is getting hot and quits working due to age. Replace fuel pump,strainer,and fuel filter and it should solve your problem. (Fuel pressure is 30-40 psi)
Posted on Jan 01, 2014
    New Friend:
I went to start my car but it doesnt go. it winds over but nothing ?
Posted on Mar 19, 2014
My car quit while highway driving; now it wont restart. could this be an alternater problem?
The alternator only keeps the battery charged. So if the battery is dead, then yes the alternator could be at fault.
If the engine cranks but does not start, then the alternator is not involved.
And the anti-theft system would not kill the engine, only prevent it from starting.
Sep 03, 2015 | 1999 Mercury Cougar
2000 olds alero cranks then makes a metal grinding sound and won't start
You need to have your flywheel: replaced.Your starter motor engages against the fly wheel at the back of the motor. Every time your motor stops it tends to be in the same few positions (just the way things work) so there is more stress on some parts of your fly wheel than others. Because of this the teeth wear out on the fly wheel which means the starter can correctly engage on the fly wheel which is the grinding noise.
Jan 18, 2013 | 2000 Oldsmobile Alero
Car won't start after accident
well its possible a fuel shutoff could be in the trunk i never new they had cutoff switches on them
Dec 05, 2012 | 2000 Toyota Celica
Car starts fine after sitting awhile. If you drive awhile then stop and try to restart it won't.
Check the electronics,cam sensor or crank sensor these are the culprits.
Aug 19, 2012 | 2006 Chevrolet Aveo
1990 jaguar xj6. Car wont start. may be electrical.
not sure if any off this will help you o The starter won't crank. If nothing happens when you turn the ignition key to the "Start" position, it means that the starter motor doesn't turn over the engine. Most commonly this could be caused by a dead battery; here is How to check the battery. ... The ignition switch could be bad - it's a common problem.13 Aug 2013
Why a car won't start - troubleshooting tips - Samarins.com
www.samarins.com/diagnose/ut...or try this link. Car wont start Google Search
Oct 20, 2017 | 1990 Jaguar XJ6
2005 Dodge Grand Caravan won't start
Make sure the battery has a full charge. If it cranks good but won't start, have a helper crank it while you visually check for spark at the spark plugs. If spark everywhere, use a gage and check proper fuel pressure, also, check fuel injector pulse. If your missing everything, check cam and crank sensors.
With engine cranking check primary voltage to coil and fuel injectors, brown wire with white tracer. If no voltage leads back to asd relay. I'm not saying that relay is faulty. You can see fuse for that relay, that fuse circuit is hot all the time. The computer grounds the control side of relay if it sees proper cam and crank signals.
Apr 19, 2017 | Cars & Trucks
2001 ford taurus car starts fine drive it for awhile then shut it off and it wont start let it sit and it will start battery is fine
Does it crank?If you shut it off and you restart after a few minutes and it cranks but won't start or starts and runs rough the injectors are leaking and flooding the engine. Need better description
Dec 07, 2011 | 2001 Ford Taurus
Have a '94 S-10 Blazer Tahoe 4X4 and it starts
My suspicion is a starter going bad. Sometimes when starters get old and worn they will start good when the engine is cold but not when the engine is warmed up. Did you perhaps notice that lately is seemed to drag when you tried starting, especially warm or it seemed to crank a little slower? I'd replace the starter. Hope this helps.
Aug 14, 2011 | 1994 Chevrolet S-10 Blazer
93 wagon stalled while running & now engines cranks-no start
Doubt it's the fuel switch, check the timing belt
Aug 23, 2009 | 1993 Ford Escort 4 Door
Continental Mercedes Benz 2001 E320 Aux Fan Belt Logo
413 people viewed this question
Top Continental Heating & Cooling Experts
Tim Whalen
Donni Steen
Are you a Continental Heating and Cooling Expert? Answer questions, earn points and help others
