Question about Carrier Heating & Cooling
Blower will not start up when on AC
When on ac Carrier unit will not start main blower?
    New Friend:
    Problem Solver:
  • 13 Answers
If I understand correctly when you switch no the blower doesn't come on ? it normally will take up to a minute in some cases if it does not start this mean there is not enough gas in the system as the blower will only start up if the pipe sensor is activated by gas tempreture.
Posted on Aug 01, 2013
    Guru:
  • 1,524 Answers
Switch it to auto. If it works, change the sub-base of the thermostat.
Posted on May 20, 2009
I HAVE CARRIER AC MODEL NO. 38HQR18UP30-03, WHEN START THE AC ONLY THE INSIDE BLOWER IS STARTING OUTSIDE UNIT FAN AND COMPRESSOR DOESNT START.....
It could be a number of things. Check breaker panel inside your house for flipped breakers. Check for bad fuses and check your capacitors. But only if you know how to use a multimeter and shut the power off first and understand how to de energize the capacitor. Otherwise call an electrician of hvac professional. Otherwise doing so can be deadly if your are unsure of electricity
May 17, 2016 | Carrier Heating & Cooling
Was running ac. Now blower won't come on for ac or heat. Error code 24 is displayed. Please advise. Would a blown fuse at ac unit cause blower to stop all together
It could be your capacitor. I had a fan capacitor go out on one of my 3 units last year and it cost close to $300 for an AC company to come out and fix it. I watched them fix it and it's something that you can do yourself if you know what you're doing and are careful to hook it up right. I have three AC units and another capacitor went out this year and I found a kit with detailed instructions with pictures and phone support at hvacrepairkits.com. It saved me over $200 on the capacitor replacement.
Aug 14, 2011 | Carrier 38CKC036 Air Conditioner
My ac unit is in the attic is this normal
Do yu mean the compressor unit is in the atticor the indoor blower unit. If its the indoor blower unit thats fine though kinda hard to work on but it keeps the noise down. If its the compressor unit.. Hm mmm Not the best place for it . hard to work on and noisy I'll bet
Aug 09, 2011 | Carrier 38CKC024 Air Conditioner
Carrier central AC/Heat system repeats "Replace
Try unplugging the unit and waiting a few which many times resets the board.
Aug 03, 2011 | Heating & Cooling
Need schematic for carrier furnace/ac. A butcher
There should be a schematic inside where the blower is or in the main elec. panel on unit
Oct 02, 2009 | Heating & Cooling
Blower never stops. AC outside jammed to stay on???
You need to call someone who truely knows what they're doing. From your decription, the person you had out should not be working on units. You have a problem most likely caused be the person that installed the new motor and these units are not designed to be worked on by the homeowner. There are hazards that could cause damage or injury.
Aug 18, 2009 | Goodman CLJ36AR42 Air Conditioner
My blower blew a 3 amp fuse..i replaced it....the blower is running...but the ac wont kick back on
why did fuse blow thats what i would figure out? check for power at compressor it maybe locked up(you haft to reverse polarity to unlock)!! :)
Jul 05, 2009 | Heating & Cooling
AC unit turns on blower doesn't come on
The thermostat is the controller.
Jun 19, 2009 | Heating & Cooling
BLOWER MOTOR PROBLEM
If the thermostat isnt set to fan on, and the temp in the house is ok, there is probabily a fan off delay in the units circuit board thats defective.
Dec 30, 2008 | Carrier 38CKC036 Air Conditioner
Problem with carrier heat pump
Check the relays on the main board of your blower/furnace. If one is stuck, then the unit will not change from ac to heat. You may need to replace the entire board.
Dec 11, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
124 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
