Question about HP Digital Sender 9250c scanner Printer
Power is working swtich on the scanner no display in the screen
Scanner cannot complete initialized only 3 led is on no display in the screen
  • 110 Answers
Hello Joel_umandal,
Please try the below steps ...
  1. While the printer is ON, unplug the power cord from back of the printer and from the power source.
  2. Wait for 30 seconds.
  3. Plug in the power cord directly to a wall outlet ( bypass the surge / power strip )
  4. The scanner should power ON automatically, if not then press the ON button to do so.
  5. Now try scanning , it should work.
Posted on Jan 02, 2014
3 Suggested Answers
  • 12 Answers
SOURCE: Coppier Problem
The trouble is that the scanner assembly can't find its "home" station. Here is the most common solution. There is a reflective white stipe under the scanner glass that the scanner looks for. If the stripe is dirty, or if the scanner mirrors are dirty, the scanner won't sense its location, and cause a "scanner error". A qualified technician should be able to clean the assembly. The other option is to replace the scanner assembly. I hope this helps.
Posted on Feb 28, 2007
  • 10 Answers
SOURCE: scanner bulb warming up message!!
Aqeel,
This is the problem with your scanner. If it is under warranty please take it to Hp Service center and they will replace it free for you.
Thanks
Posted on Aug 16, 2008
Clear a radio shack triple trunking scannrt
If the scanner's display locks up or does not work properly
after you connect a power source or install batteries, you
might need to initialize it.
This procedure clears all information you stored in the
scanner's memory. Initialize the scanner only when you
are sure the scanner is not working properly.
1. Turn off the scanner, then turn it on again. Multi-system
Trunking Scanner appears.
2. Press 0 while Multi-system Trunking Scanner appears.
3. Press 1.
4. Press ENT. Initializing please stand by. appears for about 5
seconds.
Do not turn off the scanner until the initalization is
complete. When the initialization is complete, M000
appears on the top line of the display. Bank 0 Ch 00
appears on the third line.
Notes
Notes
Mar 20, 2013 | Uniden Radio Communications
Radio shack pro-96 scanner screen blinks and loss of audio
3. Press 1.
seconds.
Notes
Notes
Jan 10, 2013 | Radio Shack Pro-96 Scanner
Can,t get scanner off all channels locked mode
Please try this!!
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
Hope this works.. Happy Scanning
Nov 20, 2012 | Radio Shack Pro-96 Scanner
I have a radio shack pro96 i can not reboot it to restall the v scannfolder what can i do i have tryed everything to wipe it clean
Sounds like the motherboard is corrupted. Please try these steps again. Thanks!! Happy Scanning!!
I need to ask you this. Normally one bank can't be closed.
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Apr 11, 2011 | Radio Shack Pro-2096 Base Scanner
Looking remove all stored channels from scanner and start over.
Initializing the scanner will erase all programmed information and return your scanner to its original factory settings. To initialize your scanner:
- Power the scanner OFF.
- Power the scanner ON. "Multi-system Trunking Scanner" appears on the display.
- Press 0 (zero) while the above message is displayed.
- Press 1.
- Press ENT. "Initializing please stand by" appears on the display.
DO NOT power the scanner OFF until the initializing process is complete and the display shows "M000 Bank0 Ch00"
Bill B.
Listening in professionally since the 60's
Mar 22, 2011 | Radio Shack Pro-2055 Base Scanner
I have A radio shack PRO-2096 and have not been able to use it in over A year. it reads all channels locked out. I can't unlock it.can someone please help me?
Please try this!!
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Jun 23, 2010 | Radio Shack Pro-2096 Base Scanner
Scanner problems Its stays on Auto-Scann and buttons dont work
Resetting or initializing the scanner may clear your problem.
To RESET the scanner:
- Turn the power OFF, then turn it ON again.
- Insert a pointed object (paper clip end, ballpoint pen tip, etc.) into the RESET opening on the side of the scanner, then press and release the button inside the opening.
If the above doesn't clear the problem, try the more drastic INITIALIZE procedure. NOTE: this step will erase all data that you have programmed into the scanner and restore it to original factory settings. To INITIALIZE the unit:
- Turn the scanner OFF then ON again. The scanner briefly displays the DSP boot version, then "Welcome to Digital Trunking" displays.
- Press "0". The scanner displays "System Tests Select Test Exits if no Key Press"
- Press "1". The scanner displays "Factory Unit Erase Memory ENTER if Yes CL to Exit"
- Press ENTER. The scanner displays "Initializing Clr Main Mem V-Scan is OK Please Wait"
- Do not power the scanner OFF until INITIALIZE is complete. When the process is complete the scanner will display "M0000" on the top line and "Bank 0 Ch 0" on the bottom line.
If neither of the above steps works for scanner I recommend that you take it to your nearest Radio shack and arrange certified repairs.
Need the manual for your scanner? You can download/print it here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-96/pro96.pdf
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Bill B
Apr 21, 2010 | Radio Shack Pro-96 Scanner
After I enter a frequencie the enter button doesnt work to enter
If all else fails, you can RESET or INITIALIZE the scannerto bring it back to normal operation.
To RESET:
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 then 1 while "Welcome to Dual Trunking" is displayed.
- "Initializing Please Wait" will appear for about 2 seconds.
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
Feb 19, 2010 | Radio Shack Pro-95 Handheld Scanner
My pro-2096 does not display any letters or
If all else fails, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
- Press 0 after the scanner completes its boot routine
- Press 1 after the menu appears
- Press ENT
BillB
Jan 22, 2010 | Radio Shack Pro-2096 Base Scanner
IT WON'T BUDGE. IT READS ALL CHANNELS LOCKED OUT. PLEASE HELP
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Hope this works happy scanning!!
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
HP Digital Sender 9250c scanner Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
