Question about Jetway N2PAP Ultra Motherboard
Hardware connection diagram - Jetway N2PAP Ultra Motherboard
CRT VGA cable pin color problem. I can not get which pin connect where
Refer its connection diagram. The user manual might help you. If not, contact any service technician.
Nov 25, 2014 | Philips Televison & Video
Diagram
Look closely at the motherboard. They are usually clearly marked what goes where.
Sep 05, 2014 | Compaq 361633-001
Diagram of k8vga-m diagram
1) http://www.biostar-usa.com/mbdetails.asp?model=k8vga-m
2) http://www.biostar-usa.com/mbdownloads.asp?model=K8VGA-M
Link in number 1 above is for BIOS Support, and the K8VGA-M mobo.
Link in number 2 is the download page, which has the Motherboard User Manual. (K8VGA-Mmanual.pdf)
For additional questions post in a Comment.
Regards,
joecoolvette
Aug 30, 2012 | Computers & Internet
Hoqw do we connect power cables on this motherboard e.g power led hdd led
make sure you have the manual of that motherboard so you have a guide for the diagram where to connect the jumpers
Feb 22, 2011 | IBM (02R4087) Motherboard
I WANT CKT DIAGRAM OF SIMPLE CALLING BELL
http://en.wikivisual.com/index.php/Doorbell
Here is circuit diagram for 24 volt AC call bell system.
Made with off-the-shelf parts from hardware store.
Connect transformer to box with 120Volts
Box with 120Volt ac can be any wall box with receptacle.
Home doorbell system have this kind of box-and-transformer located in attic or basement or utility room ... you can tap into same transformer and use it for both doorbell and call bell.
12V AC and 24V AV transformers are sold in doorbell department of hardware store.
Buy doorbell button in same department.
Buy bell to match voltage of transformer (for example, 24Volt DC bell will not work with AC transformer)
Thermostat wire is sold in electric department of hardware store.
Add a comment if you need more help.
Nov 26, 2010 | Cycling
Diagram how to connect dell inspiron laptop 9400 and record tv programs
If you have the right Hardware (Digital TV tuner card) it will have come with the software needed.
If you dont yet have tv tuner card, thats what you need
Jul 18, 2010 | Dell Inspiron E1705, Intel Core 2 Duo...
Linksys router is connected to laptop computer but shows a red X io diagram from router to computer.
The red X actually means the hardware is disconnected. Meaning, there is no cable plugged into the computer, so it thinks.
One way to see if your hardware is working is to go to Start -- Run, type "cmd", then type "ping 127.0.0.1". There is a space between "ping" and "127".
If you are not getting replies or "Request Timed Out" at any time, the NIC card has failed.
This is when you need to buy a USB Ethernet port if you find out you have a hardware failure.
Hope that helps in any way :).
Jan 12, 2010 | Linksys Wireless-G WRT54G Router
How to wire a 2-pole switch?
You should have 3 connections on the switch, double pole,single throw.The brass colored connections are hot and the silver is neutral.You should have a diagram that came with the switch.The switch should also be marked if you look close enough.If you are still not sure , I would go to the nearest hardware store with the switch, and look for the same one in the box and at the diagram. Hope this helped you out.
Good Luck,
Shastalaker7
PS 2-Hot to Hot terminals, and 1-silver, and ground, green.
Nov 06, 2009 | Heating & Cooling
I have intel dg31 chip set , i didnt got a serial port with it so i put a anothewr serial port on it (one which was in ma old pc) but when i connect serial port with ma hardware it doesnt detect hardware....
Who is the manufactor of the serial port your adding in and also did you confirm with the motherboard manufacture that adding another serial port is possible. You may just be missing drivers or not have it setup properly. It will not come up as found new hardware. This is something that will need to be done manually. If you can confirm all this your motherboard diagram should tell you were to plug it in and how to from there on it should just work unless something is turned off or miss configured.
Mar 17, 2009 | Intel DG31PR Motherboard
Jetway N2PAP Ultra Motherboard Logo
13 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Computer Links
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
