Question about Yamaha 81 82 83 Virago Xv 750 Xv750 Engine Motor Stator Cover Generator
The motorbike start spluttering after +- 25 km of ongoing driving.
I did clean and reset the carbs but after driving continious for plus minus 25 km it start s-pluttering
    Problem Solver:
  • 9 Answers
Is your fuel cap vented if not will cause a vaccum in the tank which will restrict the amount of fuel to your carbs! and cause weird things to happen !
Posted on Jan 01, 2014
  • Jan Cronje Jan 01, 2014
    Thanks. I will try it cause as far as i can see it aint vented.
How can I set my DELL E2210Hc monitor to reset to factory default
To help you reset default settings of Dell monitor, please find the instructions step-by-step given below:
- Press the 'Menu' button on the monitor panel.
- Press 'Plus(+) or Minus(-)' button to move to 'Menu Settings'.
- Again press the 'Menu' button.
- Press 'Plus(+) or Minus(-)' button to move to 'Factory Reset'.
- Again press the 'Menu' button 'Twice to Reset'.
- Press 'Plus(+) or Minus(-)' button to move to 'Exit Menu'.
GuruAid.com
Jun 05, 2016 | Dell Computers & Internet
Shortcuts for complex multiplication
Example: 25 times 48 is the same as 50 times 24 is the same as 100 times 12, which is 1200.
Example: 19 times 32 is the same as (20 times 32) minus (1 times 32) which is 640 minus 32 which is 608.
Example: 'ab' times 'cd' is the same as 'a*c' plus 'b*d' plus 'a*c' plus 'b*d'.
Oct 23, 2014 | Computers & Internet
Starts but mis fires
I know it sounds too simple but the aircleaner element is worth checking. Even if it looks only a little grey still replace it. Are the spark plugs fouling?? If so I would do the air filter replacement.
Nov 29, 2013 | Motorcycles
Blue halo on mitsubishi dlp
The caps on the power board are replaceable by a ten year old who can solder.
If 1000uf @ 10 volts go to a higher rated voltage cap say 25 volts which is why all the original ones went south.
Each cap has a -minus and a +plus on one side===pretty simple to do with only two leads each and a plus and minus marked on the part and on the board.
Do not swap parts from another junk board...waste of time and effort.
hope you get it going
Mar 06, 2012 | Mitsubishi WD-52525 52" Rear Projection...
Motorbike not running smooth
The carburator prolly needs to be cleaned out. Try some carb cleaner through the gas tank first.
Apr 28, 2010 | 2007 Suzuki GSX 1400
8 YEARS WITH THIS PROBLEM PLEASE HELP!!!
idle jet in carb may be blocked.
Mar 09, 2010 | 1994 Suzuki DR 800 S
Unable to read cds /dvds, made by me, of my photos. It will play pre recorded DVDs. ie Palin set. can see files but then computer hangs. Running Vista. Similar occurs on my desktop but I get the blue...
lost of things could be happening ,depending on optical drive manufacturer,file type,plus or minus dvd/cd blank disk and burning software and how you are burning the media,all can cause malfunctions,but if playing a disc causes blue screen of death,then i would first uninstall display adapter driver on graphics card,and restart,when computer finds new hardware,click cancel,go to dell support and get newest driver,and software,reinstall..some optical drives like minus discs,some like plus discs,depending on the drive,if its a combo drive and will read and write both plus and minus discs,then the problem is how you are burning them,or the laser is dirty or drive is malfunctioning.if you arent allready using nero burning software,then i would reccomend it,i have been doing this a long time,had my days of problems,,not anymore,i dont work for nero nor am i paid by them to say this, but i am a computer repair tech with 25+years experience,save yourself hours of pain and wasted blank discs,and purchase it,user friendly ,easy to use ,and advanced drive speed tools ,allow max preformance on any computer,read instructions ,discs must be burned with correct file type for device that plays them back ,disc at once or track at once settings ,matter,also using the slowest burning speed,creates a higher quality disc,but takes longer,post comments if you have more questions ,aloha from maui todd0708
Nov 13, 2009 | Dell Dimension 2400 PC Desktop
Our Whirlpool gas range does not stay lit. This is the first gas range and it is new and it constantly lights itself during cooking. Is this normal?
this is called cycling and it is totaly normal
gas ranges have a plus or minus 25 degree swing to set temp
it will turn on at -25 degrees
and turn off at +25 this is what maintains propertemp
Oct 05, 2009 | Kitchen Ranges
Tire pressure reset will not reset
Labatche822,
The process for resetting your Tire Pressure Monitor (TPM) is below.
Good luck, let me know.
Regards.
To reset (calibrate) the system:
1. Turn the ignition switch to RUN.
2. Press the GAGE INFO button on the DIC until
TIRE PRESSURE appears on the display.
3. Press and hold the DIC RESET button for about five
seconds. After five seconds, the display will show
TIRE PRESSURE RESET. If TIRE PRESSURE
RESET does not appear on the display after about
five seconds, see your dealer for service. After you
release the DIC RESET button, TIRE PRESSURE
NORMAL will appear on the display.
The system completes the calibration process during
driving. During the first 10 to 25 miles (15 to 40 km) of
driving, the system will not alert you if a tire is high or
low. After 25 to 100 miles (40 to 160 km), the
system will only alert you about pressure differences of
12 psi (85 kPa) or more. After about 100 miles (160 km)
of driving, the system will alert you if one tire is
10 psi (69 kPa) different from the other three tires.
May 04, 2009 | 1999 Buick Park Avenue
Yamaha 81 82 83 Virago Xv 750 Xv750 Engine Motor Stator Cover Generator Logo
82 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
