Question about Amazon Kindle Paperwhite
I can not connect my kinle paper white to my home hub a nd i am using the password supplied
Have used password but it comes up as incorrect
    Scholar:
  • 88 Answers
No. You are probably typing in the Router Password. This is NOT what you need.
There is another reference that is called your Wireless Network SSID
and under that is the KEY or WAP or something else.
That KEY is what you type in when prompted for wi-fi password (confusing, but that's life)
Rememeber it is case specific - if it says F it means F and not f
Posted on Jan 21, 2014
My kindle won't access the WI-Fi
Go to settings and turn on wifi access.
Oct 08, 2016 | Amazon Kindle Fire HD
How to get connected to wi fi
To connect to a Wi-Fi network with a hidden SSID, select Add Wi-Fi network from the settings. Then manually type in your SSID and password, and select your network security type. Select Save when finished. Now you can browse the web through your Wi-Fi router or connect to other network devices
Sep 18, 2016 | Amazon Kindle Touch Screen Wi-fi W/...
I'm having trouble connecting my new Kindle to my wi-fi
trouble connecting my new Kindle to my wi-fi Mary, Check the attached links,instruction and guides to get kindle connected, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Can Connect Kindle 5th Generation to Wi Fi
Fix Kindle HD WIFI problem EASY
kindle won connect with wi fi
12 major Kindle Fire problems and how to fix them
Aug 03, 2016 | Amazon Kindle Paperwhite
No longer will connect with WIFI although all other electronics are on the WIFI
Amazon.com: Customer Discussions: kindle won't connect with wi-fi
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.May 7, 2012 - If it will connect there, then the issue is not your Kindle but the network..... I just received a Kindle Fire HD as a gift and was able to connect to the ... It used to say "obtaining IP address" but it no longer says that, so I know there ... My Kindle will not stay ...
Oct 24, 2013
Kindle Fire HD 7" WiFi Not working
May 28, 2013
kindle fire hd connects to wifi ...
Jan 5, 2013
New Fire HD drops wifi!
Sep 19, 2012
More results from www.amazon.com
Amazon.com Help: Can't Connect to Wi-Fi
Dec 20, 2015 | Amazon Kindle Fire HD
My kindle touch wont connect to my wi fi keeps saying incorrect password when i have not changed anything
Can you connect other devices to your wifi using the same password?
If so, it is the Kindle at fault.
Go to your wifi connections in Settings and remove your connection (I think it may say "forget").
Turn off your Kindle by holding down the power button for a full 30 seconds.
Restart your Kindle and connect to wifi, re-entering the password on the back of your router.
Mar 04, 2015 | Tablets & eReaders
My kindle wi-fi keeps kicking out. I have G3 and never had to put in a specific wi-fi source. Now it continually asks me to connect, and won't even accept a proper on our home wi-fi router.
Your kindle has a sim card installed for 3G (lifetime licence paid by amazon and paid for on purchase price on the unit) but that is not related to the wi-fi function on your kindle. Your wi-fi service needs to be logged in to with the same password as you use to log any computer on to your router when at home or whatever wi-fi password is required when elsewhere (e.g a bus, train or restaurant).
Dec 05, 2014 | Amazon Kindle Model D00901 Tablet Reader...
Why does my tablet keep saying authentication problem when trying to connect to wifi
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Dec 30, 2012 | Archos Arnova 10 4GB 4)
My kindle keeps asking for a wi-fi password for sky37606
If sky37606 is your own wi-fi service then the password is normally on a typed label stuck to the wi-fi router itself along with the SSID of the wi-fi network which should be sky37606 in confirmation you are connecting to the correct network.
If sky37606 is not your own wi-fi then you will either need to contact the owner or administrator of that network or select a different wi-fi network to connect to as described in the Kindle Support web pages for your device.
Dec 27, 2011 | Amazon Kindle Wireless Reading Device
Kindle will not charge from out let or computer
Please clarify: what charger did you use to connect to an outlet? The Kindle 3 comes with an USB cable to charge from a PC or Mac computer and no charger outside for many countries outside the US (for other countries an external charger is available from Amazon as optional accessory). Use of a different charger (e.g. mobile phone charger with USB connector) is not supported, not recommended and may fry your Kindle if a wrong voltage is hooked to it.
Things you can try:
  1. Use a different outlet to charge the Kindle.
  2. If you use the supplied USB cable to connect to a PC, make sure its firmly seated on both ends. Connect to a powered USB port directly on your computer. Some external USB hubs do not come with a separate power supply (external power supply is mandatory for an USB 2.0 hub, some cheap models are sold without one anyway) and are not suited to charge anything. Just to make sure, disconnect any other USB device except mouse / keyboard to check if the USB port in use is not burdened by too much drain.
  3. The Kindle power LED should glow amber while charging and green if the device is fully charged.
  4. Give the Kindle a reset pressing Home --> Menu --> Settings --> Menu and select "Restart." If the charge light is on but the device is still not charging, contact Amazon customer service.
  5. If the charge light does not light, the AC adapter or cable needs to be replaced.
  6. Contact Amazon customer support for any warranty issues.
Jan 01, 2011 | Amazon Kindle 3G
Amazon Kindle Paperwhite Logo
Top Amazon Tablets & eReaders Experts
Lesley Cameron
Lesley Cameron
castletech
castletech
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
