Question about Crafts & Hobbies
How to reheat rolls - Crafts & Hobbies
How to reheat a steamship round
Hello, John -
This web page from Cook's Illustrated [magazine] gives directions for reheating any kind of beef roast:
https://www.cooksillustrated.com/how_tos/9989-the-best-way-to-reheat-a-roast
If you wish to reheat the meat in a microwave oven, I recommend that you slice the meat first and not try to reheat the entire roast. Spread the sliced meat onto a microwave-safe plate and cover it with plastic wrap. If your microwave oven has a setting for "reheat", use that and run it for 1 minute. Check the meat to determine how warm it is. If it needs to be warmer, run the microwave for another 30 seconds and check for warmth. Repeat as necessary. Let the meat stand for 1 minute before serving.
Dec 27, 2017 | Cooking
How do I reheat mushroom ravioli?
put it in a pan and sit on stove top burner that is turned on or put in glass /plasticbowl and use microwave oven for about 2 minutes on hi
Mar 15, 2015 | Kitchen Appliances - Others
HOW DO YOU REHEAT THIN SLICED PRIMERIB WITHOUT DRYING OUT?
Reheat it in a baking dish with a little beef broth in the bottom. Also baste it with the broth before reheating.
Sep 26, 2014 | Dryers
How to reheat rolls
They can be reheated in an old pot Woodworkers for a hundred years or two used heated glue that way. You can reform them if you can create a set of molds.
Nov 28, 2013 | Crafts & Hobbies
Reheating rice
If the rice has been placed in the refrigerator after a meal, then it is OK to microwave to reheat the rice.
Cooked rice should not be left unrefrigerated for long periods.
Apr 06, 2013 | Microids Warm Up
Nokia 8250 no signal
if you recently accidentally drop your phone then you need to open it and reheat the cobba i.c or known as the audio i.c for some cellphone experts. you need to have the following things. hot air and a flux. first you need to put on a flux above the audio or cobba ic and reheat it using the hot air. set the hot air to its proper setting and slowly reheat the audio ic for 2 to 3 minutes. and then let it cool for 3 to 4 minutes and then close back your phone. then for sure it gonna have a signal.be careful of reheating the audio or cobba ic. since its sensitive and don't try to move it, just reheat it. coz if incase you move it, it will cause you phone to recieve a contact service error.
Jul 10, 2011 | Nokia 8250 Cellular Phone
Master mechanic glue gun 207 stopped working
There is a glue build up inside. Most likely in the feeding mechanism, try to heat it up, the unplug, and use like a paper rolled up to try to remove some of the glue. :)
Mar 25, 2010 | Crafts & Hobbies
Crafts & Hobbies Logo
52 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
