Question about GE Televison & Video
Picture tearing at bottom
Upgraded software for Samsung BD-E6100 Blu-Ray player when connected by HDMI cable to Techwood TV. When Blu-Ray player restarted a horizontal "tear" appeared at the bottom of the screen. Can the player update the TV settings via the HDMI cable? If so, how do I change the TV settings back? If not, then can someone help with the TV fault. Symptom is the same when there is no input to TV HDMI socket. Have also tried using SCART but that is the same. Thanks in anticipation.
    Problem Solver:
  • 7 Answers
Have you tried changing the output video settings of the Blueray player from NTSC to PAL or vice versa? Also check that Blueray has HDCP turned on or off, depending on your TV set.
What's the make and the model of the TV?
Posted on Jan 01, 2014
  • Wendy
    Wendy Jan 01, 2014
    The TV is a Techwood 32832 HD Digital 32".
5 Suggested Answers
  • 192 Answers
SOURCE: HDMI Input Failed
I've been seeing alot of this out in the field. The cable is thick and heavy, after awhile the HDMI connectiion inside the set comes apart and breaks from the main board. In my opinion the only difference between Component jacks and HDMI inputs is the thought of reducing the amount of wire mass in the back of the unit. It's more pleasing to the eye. If it's under any kind of warranty, call a servicer. The main PCB will need to be replaced. If it's not under warranty, use component input cables, you'll get the same performance from your set and save a few bucks.
Posted on Dec 25, 2006
jerryg50
  • 1689 Answers
SOURCE: RCA pix tearing horizontal lines
Get an ESR meter and check all the electrolytic capacitors in the set! I am sure you will find many decoupler and coupling capacitors that are on the edge or too high in ESR.
Jerry G.
Posted on May 25, 2008
SOURCE: HDMI port does not work on the KV-30SH420
I dont have a TV with HMDI input but i do have a computer moniter. To change i have to press a button that changes from VGA to HDMI. My computer supports HDMI and when i tried it, it works. Try looking in your manual for a way to switch input methods.
Posted on Jan 20, 2009
bernardlunda
  • 318 Answers
SOURCE: JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Posted on Apr 30, 2009
How does one stream netflix via Blu Ray wired to ISP through a tv?
First you have to hook up network cable to Blue Ray player and to router
Next update software in Blue Ray player by going thru your menu in blue ray player to settings
If you have your blue ray player with Netflix app then all
you do is click on app and log in.
And make sure HDMI cable is plugged into TV.
And that should work for you. Any problems write me back.
May 04, 2014 | Samsung BD-E5400 - Blu-ray disc player
How do I connect my Samsung BD-E5400 blu ray player to tv and watch netflix with a wired internet connection?
From the modem to the blu-ray use an ETHERNET cable. From the blu-ray to TV use an HDMI cable. They only fit in the right terminals.
May 03, 2014 | Samsung BD-E5400 - Blu-ray disc player
Wont play 3d movies
Ensuring the Tv is a 3D tv, first .......wipe the disc and try again, usually the menu on the disk has the 3D selector if the blu ray is connected to a Tv that has 3D mode engaged it usually switches over to play in 3D automatically
Jan 02, 2014 | Samsung Bd-E6100 3D Blu-Ray Player
Region code for Samsung BD-E6100
Try this code I have got it with this code may be you will also get yourthe code is: BD-E6100/XU.Perfectly I don't know whether it is for all regions or not but try this.
Performance Chip
May 23, 2012 | Samsung BluRay Disc Player BDC7500 BluRay...
I get picture but no sound on my samsung blu ray
  1. Are you connecting through HDMI?
  2. Do you have another source to test the HDMI cable to make sure it is not faulty?
  3. Do you have a second HDMI Cable you could test and connect with?
  4. Does your TV have another HDMI Connection you can use to connect with instead?
Essentially we are looking to determine whether or not it is the TV's HDMI connector, the Blu-Ray's, or just the HDMI cable in general.
May 12, 2011 | Samsung BD-P1500 Blu-Ray Player
HDMI - no output Samsung P1600 BD
the hdmi output generally needs activating through the menu system. im assuming you havent already done this.
connect it with whatever cable works and navigate through to the menu system to select the hdmi output.
failing that it might be the hdmi cable is an older cable not capable of supporting ver1.3
Feb 07, 2010 | Samsung BD-P1600 Blu-ray Disc Player
No picture from Blu-ray
If the TV works fine with other sources the problem is the HDMI output is not enabled on the BD player.
Most BD players do not output both HDMI and composite formats simultaneously. Check to make sure the HDMI output is selected on the BD player and the TV. This information is in the manuals, read the book.
Cheers
Jan 15, 2010 | Hitachi 57F59 57" HDTV
No picture from samsung blu-ray to samsung TV
Put the blu ray player into the tv to see if you get a picture,if you do put it back into the amp then assign the hdmi input you have used in the amps set up menu,if you did not get a picture when hooked up to the tv run a cable from the video [yellow] out put to the video in put on the tv and then set the out put of the blu ray player.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | Electronics - Others
Televison & Video Logo
50 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
