Question about Gateway FPD2275W LCD Monitor
Lg warranty check - Gateway FPD2275W LCD Monitor
How can I check the warranty period of my newly purchased LG LCD Monitor
Your monitor box should contain a warranty receipt. You can find all the information there.
Feb 09, 2017 | LG Computers & Internet
I bought a LG through Walmart on the straight talk plan 3 months ago. It worked fine until now. It won't hold a charge. Can I get my money back?
check the warranty clauses for battery replacement under warranty
Take it back for a warranty exchange as it may not be the battery at all but an internal fault
Jan 04, 2016 | LG Cell Phones
Lg lcd monitor warranty check
you need to contact the LG service center to know the exact status as we public does not have access to all
Dec 04, 2013 | Computers & Internet
I want to check my warranty time
Hi ghostrider_t,
Usually the warranty which is being provided these days for monitors is 5 years, I too have the same model that you have described.
Please refer to the warrantly card that you have received along with the monitor so that you come to know the exact period of warranty , it would be in months or years.
hope this helps ...:)
May 09, 2011 | LG Flatron L1715S 17" LCD Monitor
My LG refrigeretor is not functioning since last 2 days. Where can I lodge complaint in ahmedabad
You should check if you've warranty or not. If it's within warranty period then call the shops from where you bought the refrigerator. They'll fix it without any charges.
If you don't have any warranty or documents to call, then it will be better to check with some A/C and Refrigerator mechanic at the area you lives.They'll come to your house,check properly and quote a service charge with any parts or gas if needed. If you agree with them they will fix your refrigerator definitely.
Nov 12, 2010 | LG Refrigerators
I have an LG HXD2 250GB external drive for back-up. My computer (vista) will not recognise the drive and the LG drive is beeping and a blue light has come on.
The disk-drive inside the enclosure has "died".
Check the warranty-status -- if the warranty is valid, then LG will replace it, at minimal cost to you.
If the warranty has expired, disassemble the enclosure, remove the disk-drive, buy a new, compatible, disk-drive, and install it, to "reconstitute" your external storage device.
Oct 29, 2010 | Computers & Internet
I like to know if my LG refrigerator has warranty with the company because it's not working. I bought it 3 years ago and it is not getting cold.
You only have by default, a one year manufacture warranty on your refrigerator. If you bought a a extended warranty, you may still be covered.
Compressors on LG's are either five or seven year manufacture warranty.
Mar 26, 2010 | LG LRSC-26922 Side by Side Refrigerator
LG stove F-1 display stays on. Burners or oven won't work.
Your control is faulty. Check your owners manual for a two year warranty on eletronics. If not under warranty you need to call an authorized LG service dealer.
Jan 16, 2010 | LG Kitchen Ranges
LG Dishwasher Model LDF6810ST Dishwasher won't turn on
your model probably has a coating of a black tar-like substance on the inside of the inner door, which, by design, reduces noise. However, LG failed to notice the corrosive properties of the black tar-like layer. Your wiring harness is probably corroded by the soundproofing, and you will need a new inner door, wiring harness, and circuit board. LG extended my parts warranty because they know it's their fault, Call them at 1-800-243-0000. They will recommend an LG warranty repair certified technician in your area to come out and confirm this. They probably won't extend the warranty until after the tech checks out ur unit. However, labor will be your responsibility.
Aug 17, 2008 | LG LDF6810ST Stainless Steel Built-in...
Gateway FPD2275W LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
