Question about Gladiator Freezerator Top Freezer Refrigerator
Ice buildup in the freezer. dripping from above refrigerator area
I have a Gladiator garage top refrig/ bottom freezer. Water is dripping from above in the freezer and freezing at the bottom. Is it a auto defrost issue? thank you tj
  • wendy_music May 22, 2009
    I have exactly the same problem and have currently put a bowl in the freezer to catch the water. I am not looking forward to cleaning up this mess. The ice is very thick!
I have had water/ice down the back of a Gladiator as well. I just emptied it, disassembled the back wall of the upper portion of the unit. Just a few screws, and one has to disconnect a wire harness, and then after removing styrofoam and yet another panel, I was able to locate the drain hole. It was frozen solid. As I have hot water in the garage, I sprayed some in the drain hole area and then in the lower portion to get rid of some of the ice. After alternating several times (and removing the lower panel on the back of the unit), I was able to see a free flow of hot water from the drain tube at the lower back of the fridge. I have towel dried everything and have a fan on it now so that it is very dry before starting back up. I am guessing that the drain tube starts to freeze in the winter months (I am in Wisconsin), and then just has no way to thaw as it is sandwiched in the back wall of the unit. This winter I may try some extra insulation. Good Luck!
Posted on Jul 21, 2009
Had the same problem with my defrost drain hole as well. The problem is that the drip tray is situated too far down from the defrost elements, so it will ice up and clog. What I did was to disassemble the freezer, remove the insulation and expose the defrost elements and the drip tray. I gently pulled the lower defrost element down a bit, then I took a strip of basic household copper wiring, removed the sheath, then wrapped the copper around the lower defrost element about 10x in a tight spiral.
I then terminated the copper wire down into the drain hole itself. When the defrost kicks in, it heats the copper and transfers enough heat down the tube so ice will not form.
I did this trick over a year ago and no more problems for me.
One other thing I did when I reinstalled the foam core and back panel in the freezer, I sprayed some tough stuff around the panel cracks and sealed it up tight.
Pain but it now works well.
Posted on Dec 14, 2010
  • threerun Nov 17, 2013
    I thought I'd update this from 3 years ago. After doing this trick I have not experienced any additional ice buildups. Zero. I think the copper wire is doing it's thing- keeping that drain hole open to allow the automatic defrost feature to function properly.
  • threerun Jan 08, 2015
    Another update- My lower freezer started experiencing the same problem again, however it's the first time in 6 years. I'm going to disassemble the freezer and see what's going on. I'll try to take photo's of the trick/fix for reference.
Ice buildup in freezerator freezer section
If it is not a frost less freezer you'll have to remove perishables to another fridge/freezer; unplug and de-thaw the unit.
Nov 21, 2009 | Gladiator GAFZ21XXMK Bottom Freezer...
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water and ice slowly disapeared
When your refrig. is operating , The cool air is dehydrating the surrounding area inside. You will find if you leave a ice tray with water in the freezer for a month. There will be nothing left. This moisture ends up in drip tray on bottom refrigerator . Which evaporates into air outside the refrig..
May 13, 2009 | Whirlpool GS6NBEXR Side by Side...
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Water Pooling and freezing on floor of freezer
most likely you have a frozen drain in the freezer section so that whne your refrig defrosts the water runs out into the freezer compartment instead of the drain pan underneath. the fix is to flush the drain with warm water to clear the obstruction. the drain can be reached either by removing the cover in the freezer area or by back flushing the line from beneath the refrig.
Dec 10, 2007 | GALAXY Microsystems 25.4 cu. ft....
Build-up of a mountain of ice in freezer
replace the heater tube inside the freezer under the cooling fan good luck
Sep 22, 2007 | Whirlpool GAFZ21 Bottom Freezer...
Gladiator Freezerator Top Freezer Refrigerator Logo
2,113 people viewed this question
Top Gladiator Refrigerators Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Gladiator Refrigerator Expert? Answer questions, earn points and help others
