Question about Britax First Class Plus Group 0,1 Car Seat Elena
My child was sick and I had to take straps off to wash them unsure how to put them back on
  • Britax Master
  • 1,629 Answers
Hi Mary
We would recommend you contact Britax for assistance.
Posted on Jun 12, 2014
Crouch strap
Hi
Please contact Graco for assistance with correct use of the harness
Get news from Graco delivered right to you inbox
May 10, 2014 | Graco Nautilus 3-in 1 Car Seat
I took the straps off and can not put them back, can you help?
The Long strap goes under the seat and comes up thru 2 holes (each end goes up thru each side). The holes are on each side of where the child sits. They come up and weave into the latches that snap into the **** clasp. Upward toward where the child's head would be they go thru the chest clasp. Look at the writing on the clasp to make sure it is on right (letters read the name Cosco and arent upside down) and the belts should be behing the clasp (in at the bottom of the clasp and out at the top). Up thru the holes on the back of the chair at the height appropriate for the childs body. Out the back and down to the claw that is on a strap under the front that you can pull to tighten or press to release slack as the child gets bigger. There should be 1 or 2 (usually 2) slots for the ends of the straps to be slid on to. Sit the child in the car seat and adjust the belt system so that a finger can be slid between the belts and the child's shoulders. This should do the trick. Good luck and be safe.
Mar 18, 2011 | Cosco High Back Booster 22-200 /22-207
I took the straps off my Brevi Childs car seat to wash and can't get them back on!
Hi I am looking to buy a Brevi Universal car seat cover and the straps as well what web site should i be looking on???
Jun 11, 2009 | Safety 1st Designer 22-325
I need help putting my childs care seat back together
Bring the straps up through the holes on the bottom of the seat, one on each side. The metal plate on the end should pull in flat and snug against the plastic. Slide the buckle pieces back on, making sure they're facing the right direction to snap in. Slide the chest clip back onto both straps. Place the ends of the straps through the slots you want the harness at (at or below the child's shoulders for rear-facing, at or above the shoulder's for forward facing), making sure that they don't twist. Pull them down low behind the seat. The adjuster part of the strap has a kind of Y shaped metal plate - pull it up to meet the ends of your straps, making sure that it doesn't twist, either. There are loops at the end of the harness straps. Feed the curved part of the Y through the loop of the strap that's on the same side of the seat. Pull it all the way through, so that the fatter part on the ends of the metal plate are exposed and curve around a bit beyond the strap so that it doesn't slip back off. Do the same with the other side. Now adjust the harness to fit your child. When it's tightened properly, you should not be able to pinch up any slack, lengthwise, at the hips or shoulders, and it should lie in a straight line down the front, with no drooping. Also adjust the chest clip - it should lie even with your child's armpits - not up in the neck, and not over the belly, where it can't do it's job properly. (It's job is to hold the straps over the center of the shoulders...if it's over the belly, they're likely to slip down off of the shoulders in an accident or sudden stop and also poses the danger of internal injuries.) If you also took the **** buckle out, it goes back in from the top. Turn it so that you can slip the metal plate through the slot, slide it through, and then pull the plate flat underneath, so that it can't come back through. One other thing - car seat harnesses should never be submerged in water, as it can damage and weaken the webbing. They should only cleaned with a damp rag. If you put your harness in water when you washed the rest of the seat, I'd strongly recommend contacting Cosco (contact info here) to order a replacement harness.
Dec 30, 2008 | Cosco Juvenile Scenera Convertible Car...
Having trouble with straps in car seat
Clean the straps
The local group in our area told me to take the straps out and handwash them with warm water and mild soap then lay them somewhere flat to dry before putting them back where they dont twist hope this helps
Aug 27, 2008 | Evenflo Triumph 5 Comfort Touch
Reassembly of carseat
Here's something you can read... Please dont forget your rating...thanks.
http://www.coscojuvenile.com/instructions.asp
Jan 13, 2008 | Cosco Alpha Omega Elite - Hammer Print
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 | Baby Gear
Britax First Class Plus Group 0,1 Car Seat Elena Logo
112 people viewed this question
Top Britax Baby Gear Experts
thegtw
CheckitRight
CheckitRight
Jennifer Rock
Jennifer Rock
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
