Change password and encryption
How j can change password and encryption
  • 37 Answers
You have to have your routers address, try 192.168.01.02 to get into router, then follow instructions, on right side should explain details
Posted on Jan 03, 2014
Set usb password protection
1. Check the "Password protect my data" option and enter a password as well as the password confirmation and a password reminder, then click the "Apply" button.2. You can use "manage secret-zip data" only after selecting encryption item "My Folders & My Docs", the upper right window is the list of encrypted data, the lower window is the list of decrypted data. Please click "Refresh View" to update data list if you save or delete any files.3. Please select the data in decrypted area, and encrypt it by clicking "Secret-Zip Selected". You can also encrypt all data in Docs and Folders by clicking "Secret-Zip All".4. Please select the data in the encrypted area, and decrypt it by clicking "UnSecret-Zip Selected" or "UnSecret-Zip & Open".5. If you don't want to use the secret-zip function, select "No password protection required" in "Encryption Settings", and enter your password.6. If you want to change the password, select "Change password" and enter old and new passwords.
Jul 30, 2013 | Transcend Electronics - Others
Tip
PDF encryption, set PDF password and recover PDF password
PDF encryptionGenerally, PDF files are with a password called User Password, which is used to open the file and view the document. To encrypt a PDF password does not simply mean you can’t open and view the document, but PDF files have five to seven encryption ways to protect the file for office needs. Owner password, the other password of PDF files, is another crucial PDF password, which is to protect the file from maybe being copied (to Clipboard), printed, or modified, etc. So, in speaking of PDF password, it doesn’t necessary mean the one which you use to open the file.
PDF encryption largely relies on the sophisticated algorithm that hardly to be reversed. For example, you are easy to calculate that 1000 plus 1 is 1001, however, the reverse is seemed impossible, for 1001 can be an answer of countless calculations. PDF encryption works in the similar way. In this sense, given a password, it’s easy to deduce and decipher some data; however, the reverse PDF password recovery seems impossible.
Generally speaking PDF encryption with 128 bits key value is much more secure than that of 32 bits. PDF encryption is accomplished by a key value, either 128 or 32 bits in size. When using the key, all the bytes are changed (unless they are decoded back with the same key) into meaningless codes, and the file is impossible to be opened. Only the meaningless codes are calculated back using the correct value is it possible to get the correct password and open the file. 128 bits has a lot more possible values than the one with 32 bits, so it is much more secure. If your password is forgotten and intend to recover PDF password, PDF Password Unlocker software could be faster, for it supports 128 bits encryption, either 128 bits RC4 or 128 bits AES encryption.
PDF files are composed with objects, like image Objects, graphic Objects, and text Objects, etc. The key is calculated for each PDF Object in the PDF file using local data, which is much hard to crack, as the key keeps changing.
Set and remove PDF passwordsAdd a PDF Password1. Click the Secure button pdf-encryption-and-pdf-password-recovery_clip_image002.jpg in the Tasks toolbar, and choose Password Encrypt.
2. Click “Yes” to the prompt about changing the security, and if necessary, type the Permissions password that lets you change security settings. If you don’t know the password, contact the author of the PDF.
3. In the Password Security - Settings dialog box, set the security options as desired, confirm the password, click OK, and then click OK again.
4. Save the document to apply the security settings.
Note: You can also restrict editing capabilities when you certify a document, or when you apply a policy to a PDF.
Remove PDF passwords and security settingsYou can remove PDF passwords and security policies from an open PDF if you have the permissions to do so. If the PDF is secured with a security policy that resides on a server, the changes can be made only by the author of the policy or by a server administrator.
1. Do one of the following: Click the Secure button pdf-encryption-and-pdf-password-recovery_clip_image002_0000.jpg in the Tasks toolbar, and choose Remove Security.
Type your password, and click Yes to the prompt about removing the security.
In the Security tab of the Document Properties dialog box, choose No Security from the Security Method menu.
2. When prompted, specify the Permissions password, and then click OK. Recover PDF password in case you forgot it.Every coin has two sides. Even the PDF document is strongly encrypted with passwords, it is impossible to insure that it is secure. Once you forgot PDF password, the data in the encrypted PDF file are on the risk of unavailability. Unless fortunately the password knocks your memory again, you got the data lost or you have to give up the document eventually. With the ever-growing of strong encryption algorithms, decryption algorithms gradually come into existing, too. Though the cracking is far more difficulty than ever before, it is still of help to those expecting to recover PDF password and access the password protected PDF file. Take PDF Password Unlocker, a popular PDF password recovery software, for example, it has adopted the advanced decryption algorithms to crack 40-bit RC4, 128-bit RC4, 128-bit AES, and 256-bit AES encrypted passwords with 3 attack methods, Dictionary attack, Brute-force attack, and Brute-force with Mask attack
Reference: http://www.passwordunlocker.com/knowledge/pdf-encryption-and-pdf-password-recovery.html
on Apr 30, 2010 | Computers & Internet
When I start up Restaurant Pro Express this message immediately pops up: "It appears the credit card encryption key has been changed. You must now enter the same exact password (case-sensitive) that...
hi teriyakijet,
What have you gone and done now. By saying NO, you can run software as usual except, you can't process a credit card transaction thru the system. The only fix for this is the correct password or PCAmerica tech support. Keep in mind that this password is not the main password for your system. This password was entered at time of setup. It only looks for this password if you try connecting another POS to it. They have to match. Reinstalling will not help because it resides in the database and is encrypted. A fresh database would fix problem, but you would loose everything. Inventory, menu, company info, invoices, etc.
B Mattern
sysadmin@ccybernet.com
Please return and give me a favorable rating if this helps or is of value to you.
Feb 26, 2011 | Pc America Restaurant Pro Express
How do we find the WEP key for my WGR614v9
Configuring WEP:
  1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar. n101675_image001.jpg
  5. Under Security Options, select WEP (Wired Equivalent Privacy).
  6. From Security Encryption (WEP) > Authentication Type, select Automatic.
  7. From Security Encryption (WEP) > Encryption Strength, select 64-bit or 128-bit. NOTE: You will need to configure your wireless computers with the same setting.
  8. From Security Encryption (WEP) Key, select Key 1 and enter a key.
    • Note: WEP keys are entered in hexadecimal digits, which are any combination of 0-9, A-F.
      • If you selected 64-bit under Security Encryption (WEP) > Encryption Strength, then enter 10 hexadecimal digits for your key.
      • If you selected 128-bit under Security Encryption (WEP) > Encryption Strength, then enter 26 hexadecimal digits for your key.
    • SAVE or KEEP NOTE of these values - they will be required to connect wirelessly to your network.
  9. Click Apply to save the settings.
Feb 21, 2011 | NetGear WGR614 Wireless Router
How to set a password?
  • Access the router's default configuration address through your Web browser by entering this address: http://192.168.1.1 (see Resources). Do not enter a user name. Enter "admin" for the password. That process works for all new Linksys routers. If you have changed the user name or password in the past, use the user name and password that you created.
  • 2
    When the configuration screen opens, click on the "Wireless" tab and select "Wireless Security" to view the router's current security password. The "Security Mode" field will say "Disabled" if you do not have a password to secure your network.
  • 3
    Select the appropriate encryption type from the "Security Mode" drop-down menu. Linksys routers offer WEP and WPA encryption. WPA encryption allows you to use a single password to access the network. WEP encryption creates 10- or 26-character keys that act as your password. Some of your wireless devices may only utilize a certain type of encryption. Determine which protocol is best for your network.
  • 4
    Enter a password that will be required to access the network. For WPA encryption, you can write your own password. For WEP encryption, click the "Generate" button to create passwords that can be used to access the network. Write down your passwords and keep them in a secure location.
  • 5
    Click "Save Settings" to confirm your changes. Your network will now be secured and will require a password for access.
  • 6
    Click the "Administration" tab to create a password to access the router configuration page itself. Be sure to change the password from the default "admin." Reenter the password for confirmation in the next field. Click "Save Settings" to confirm your new password.
  • Feb 16, 2011 | Linksys Wireless-G WRT54G Router
    I have a dell inspiron 1300 laptop with service tag: #CBWBD2J-595B and i need system/bios password for it.Any help is appreciated?
    To unlock your laptop using the easiest method available go to: http://dell-inspiron-1300-bios-password.biospwd.com
    Dell password authentication system explained :
    The BIOS of most modern computers also allow a password to be set for each of the connected hard drives. This password is stored in the service area of the hard disk. Because of this, moving the password protected hard drive to a new computer does not allow access to the hard drive unless the password that was assigned to the hard drive is provided.
    The ATA Security Mode Feature Set that is implemented in all modern hard drives actually provides for two passwords, a "Master Password" and a "User Password"
    The User Password locks the hard drive and the Master Password is only used to allow an administrator to reset the user password.
    The BIOS of many computers will not allow the master password for the hard drive to be changed from the default, so they rarely are. A quick search of Google.com for the specific model of hard drive with the phrase "ATA Master Password" will generally result in multiple web pages that contain the default master password . Hardware tools can recover, reset, or brute-force both the User and Master Passwords.
    Full Disk Encryption Methods:
    There are two major categories of full disk encryption (FDE)-software-based and hardware-based. Software-based encryption modifies the hard drive drivers and uses the CPU to encrypt all data as it is written to the drive and decrypt all data read from the hard drive. Hardware-based full disk encryption is built into the hard drive and is totally transparent to the user and does not impose a performance impact on the computer.
    Software-Based Full Disk Encryption
    Wikipedia maintains a lengthy list of disk encryption software The two most popular FDE software implementations are TrueCrypt and BitLocker. BitLocker is included as a feature in the Ultimate and Enterprise editions of Microsoft Windows Vista and Windows 7, but has to be enabled and configured to provide protection. TrueCrypt [18] is free open source software that is ideal for individual users, but lacks management features that make it attractive to enterprise-wide deployment.
    Deployment of software-based full disk encryption in any organization with more than just a few computers requires careful consideration of how the encryption keys will be managed. Great encryption without proper key management is like locking the doors to your house and leaving the key under your doormat. One study on the usage of encryption states that 54 percent of respondents had experienced either stolen or unaccounted for encryption keys and that 78 percent experienced system downtime due to encryption failures in the past twelve months [20]. Full Disk Encryption solutions that are targeted at the enterprise typically offer integration with Microsoft's Active Directory or other LDAP directories for secure key management.
    In 2008, security researchers created shockwaves by publishing a paper called Lest We Remember: Cold Boot Attacks on Encryption Keys [21]. This paper, and the accompanying YouTube video demonstrate how Software-Based FDE can be circumvented by rebooting a computer that has been left in a locked-screen or sleep state. The attack exploits the fact that Dynamic Random Access Memory
    Jan 14, 2011 | Dell Inspiron 6400 Notebook
    My pc has locked me out of the internet and i unfortunately didnt save the WEP key, the router is a NetgearWGT624 v3
    The WEP encryption key is stored in the wireless setting in the Netgear wireless router.
    Connect a LAN cable from the computer to the Netgear router and open IE browser and enter the Netgear configuration IP address (http://192.168.0.1) default login = admin default PW = password (type in the login password if you had changed it).
    In the wireless encryption setting note down the encryption key. Use this key to configure the wireless card in the computer.
    If you forgotten the PW then you can reset the router back to the factory configuration by using a sharp point and pressing the reset button at the back of the router until the LEDs flash, then release the Reset button.
    Then login as previously stated. You can then create a new encryption key. I suggest you use WPA2 or WPA encryption key because it is much stronger than WEP.
    I also suggest :-
    Change the default password
    Change the default SSID
    For additional wireless security - enable MAC address filtering (this allows only listed MAC addresses of wireless cards to connect to this router - add the MAC address of your wireless card to the MAC address table in the wireless router).
    Don't forget to configure the wireless card in the computer with the router's SSID and encryption key.
    Oct 25, 2009 | NetGear WGT624 Wireless Router
    I forgot the password for my motherboard dell inspiron 1100 is there a way to bypass it or crack it
    To unlock your laptop using the easiest method available go to: http://dell-inspiron-1100-bios-password.biospwd.com
    Apr 11, 2009 | Dell Inspiron 1000 Notebook
    My Blitz wireless router is working for my wired connections, but it will not work for my wireless connections? My ISP told me it might be the password key for my router? Can anyone tell me how to change...
    To change the password key - you need to be logged into the Administration of the router - the configuration. Inside the configuration is the way to change the encryption key (password). You should use WPA at least for your encryption.
    Mar 29, 2009 | Blitzz Technology BWA711 Router...
    Reposting my sign in.
    This will help, rate me fixya. thanks. Passwords
    • Remember passwords for sites: Firefox can securely save passwords you enter in web forms to make it easier to log on to websites. Clear this checkbox to prevent Firefox from remembering your passwords.
      • Even with this optionpreference checked, however, you'll still be asked whether to save passwords for a site when you first visit it. If you select Never for This Site, that site will be added to an exceptions list. To access that list or to remove sites from it, click the Exceptions... button.
    • Use a master password: Firefox can protect sensitive information such as saved passwords and certificates by encrypting them using a master password. If you create a master password, each time you start Firefox, it will ask you to enter the password the first time it needs to access a certificate or stored password. You can set, change, or remove the master password by checking or unchecking this optionpreference or by clicking the Change Master Password... button. If a master password is already set, you will need to enter it in order to change or remove the master password.
    2.0:
    • Show Passwords...: You can manage saved passwords and delete individual passwords by clicking the Show Passwords... button.
    2.0 3:
    • Saved Passwords...: You can manage saved passwords and delete individual passwords by clicking the Saved Passwords... button.
    Warning Messages Click the Settings… button to configure the security warnings Firefox displays while you browse the web.
    Security Warnings Dialog
    • I am about to view an encrypted page: When this optionpreference is enabled, Firefox will notify you every time you are about to view an encrypted page.
    • I am about to view a page that uses low-grade encryption: With this optionpreference enabled, Firefox will warn you when you visit a page which uses low-grade encryption.
    • I leave an encrypted page for one that isn't encrypted: With this optionpreference enabled, Firefox will warn you every time you move from an encrypted page to an unencrypted page either by selecting a link on the page, selecting a bookmark or typing a new address into the location bar.
    • I submit information that's not encrypted: When this optionpreference is enabled, Firefox will warn you when you submit data via a form that's not encrypted.
    • I'm about to view an encrypted page that contains some unencrypted information: With this optionpreference enabled, Firefox will warn you when the page you're viewing contains a mixture of encrypted and unencrypted content. If an encrypted page contains unencrypted data, you should verify the identity of the page you're viewing prior to entering sensitive data.
    Mar 26, 2009 | Mozilla Firefox
    Computers & Internet Logo
    David Payne
    David Payne
