Question about 1999 to 2003 Ford F150 Truck for Regular Cab Power Window Regulator
4 wheel drive does not work
When switch on dashboard is turned to 4x4 hi or low no clicking sound is heard and truck does not go into 4 wheel drive.(The actuator on the differential was changed last year) please help
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 52 Answers
It is most likely in the tranfer case. From experience in a trans shop the Ford was very bad to bust a shifting fork. First test the 4wheel drive shift motor by powering it up on the bench and see if it moves; if it does its the transfer case; if it does not,then its the shift motor.
Posted on Jan 01, 2014
My 1989 jeep cherokee will only drive in 4x
Check the soildnoid that engages 4x4 by switching it from 2 to 4 wheel drive and listen to it 27 dollar part if needed to be replaced
Feb 25, 2014 | 1999 Jeep Grand Cherokee
Stuck in 4 wheel lo, how do i get it back to 2 wheel hi ?
On these issue, there are few solved help links for troubleshooting the issue easily.-------
Click the link below: ---
No 4x4 light on dash?
http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Car will not go into 4WD high or 4WD low?
http://schematicsdiagram.blogspot.com/2011/12/car-will-not-go-into-4wd-high-or-4wd.html
4 wheel drive system will not disengage?
http://technoanswers.blogspot.com/2012/01/4-wheel-drive-system-will-not-disengage.html
4WD light is flashing and beeping? NO 4WD high?
http://schematicsdiagram.blogspot.in/2012/02/4wd-light-is-flashing-and-beeping-no.html
2002 Jeep Wrangler: 4WD Idiot Light is ON?
http://technoanswers.blogspot.in/2012/06/2002-jeep-wrangler-4wd-idiot-light-is.html
Traction control switch will not engage on 4WD High or Low
http://whoisbyme.blogspot.com/2012/10/traction-control-switch-will-not-engage.html
4WD light flashing and 4WD will engage after few minutes
http://repairhelpcenter.blogspot.com/2012/10/4wd-light-flashing-and-4wd-will-engage.html
2008 Toyota Tundra: 4x4 Wheel Drive Light is Flashing?
http://technoanswers.blogspot.in/2012/05/2008-toyota-tundra-4x4-wheel-drive.html
4x4 front differential will not engage the axle on ford?
http://technoanswers.blogspot.in/2012/02/4x4-front-differential-will-not-engage.html
4x4 will not engage on Ford F150?
http://technoanswers.blogspot.in/2012/02/4x4-will-not-engage-on-ford-f150.html
Dodge Ram 4x4 light keeps flashing
4X4 LOW LIGHT IS FLASHING ON DASH
http://technoanswers.blogspot.in/2012/09/dodge-ram-4x4-light-keeps-flashing.html
Ford 4x4 front wheels will not engage?
http://technoanswers.blogspot.in/2012/02/ford-4x4-front-wheels-will-not-engage.html
These details will help.
Thanks.
Dec 09, 2012 | 1999 Chevrolet Blazer
2004 chevy silverado 1500 4 wheel drive wont work..
try selecting from nutreul or less then 3km
Feb 02, 2010 | 2003 GMC Sierra
I have a 1996 ford ranger. my 4 wheel drive wont
If your sure it is acually going into gear than check the auto hubs, they go bad alot. also you can with help from a 2nd person jack the truck up all 4wheels put the truck in 4x4 and drive and see if both drive shafts spin if they do its the hubs if the front one doesnt, its the transfer case
Dec 14, 2009 | 1996 Ford F250 Crew Cab
2000 F350 Super Duty Will not go into 4 wheel drive
I have recently had this problem with a customer. It seems the 4x4 low will only engage in neutral with the brake applied. And also check fuse. Then select drive and you will feel it lock in. Don't "goose" the fuel when attempting this.
Jan 13, 2009 | 2003 Ford F350 Super Duty DRW SuperCab
4 wheel drive not working
Vacume lines or vacume switch on transfer case,or vacume pod to front axle.
Jan 05, 2009 | 1993 Chevrolet S-10 Blazer
Green indicator light on 1998 kia sportage
That light sounds like a differential lock or 4-wheel drive. This is usually found in 4-wheel drive and all-wheel drive vehicles. Being the light is "GREEN" and not amber or red tells me that it's not an abnormal problem.
Look around your dashboard or gearshifter for a button labeled 4x4 HI, 4x4 LO, 4x2 HI. sport/off road button, or a second, smaller shifter. Switch them around a little, and if it is a 4x4 selector, be sure when you drive on paved roads to have it set to 4x2 HI. 4x4 HI should only be used if you get stuck to help you get out (snow/mud) and 4x4 LO is only for off road driving (trail blazing/rock climbing/4-wheeling/mud bogging,etc.)
Also, check for any switches labled "DIFF LOCK" or 'AXLE LOCK". In most cars a green light is normal operations.
I hope I could help you find a solution to your problem.
Dec 04, 2008 | 2008 Kia Rio
4x4 will not engage,lights just blink,and you can here clicking
The 4x4 system has a controller,or computer,called the Body Control Module and there will be stored trouble codes.To work on a system that's electronically controlled,you have to get the codes from the system.Every trouble code has a diagnostic route to follow to resolve the faulty component.I have read about Explorers having faulty door open/closed sensors.These set a code in the Body Control Module,and in the process,the BCM inhibits 4x4 operation,causing a no 4 wheel drive complaint.There is also an electric motor on the transfer case that can fail electrically or mechanically,along with speed sensors and fork position sensors that can give trouble.
Sep 02, 2008 | 2000 Ford Ranger SuperCab
1999 to 2003 Ford F150 Truck for Regular Cab Power Window Regulator Logo
75 people viewed this question
Top AM Auto Parts Vehicle Parts & Accessories Experts
Todd Arndt
Todd Arndt
terry stevens
Speedracer70
Are you an AM Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
