Hotpoint aquarius +WML720 tripping fuse box every time I switch it on any ideas please
  • john Jan 10, 2014
    if you have checked the motor then you should check the HEATER
    New Friend:
  • 60 Answers
You have a direct short in the wiring, if you open up the outer case and make sure its unplugged it should be very easy to visibly spot the burned wires or offending part. Most all of these parts can be had either locally or online and are usually straightforward to replace.
Posted on Jan 01, 2014
  • 1 more comment
  • Neil Frost
    Neil Frost Jan 01, 2014
    Hi I unplugged the motor it still tripped .I plugged the motor back in and took the carbon brushes out and it did not trip everything seems ok . the brushes are low but can this course it to trip out
    Best wishes
    Neil
  • quady Jan 14, 2014
    Yes but if your unplugged the motor and it still tripped it can't just be the brushes
    May be heater.
  • 10 Answers
SOURCE: Machine keeps tripping the fuse at the fuse box - WD61 Aquarius Hotpoint
it might be too small of a fuse for your machine
Posted on Feb 12, 2008
reddyanantha
  • 205 Answers
SOURCE: hotpoint aquarius wd440. Flashing lights
hello mam please check the timer switch.
Posted on Oct 04, 2009
  • 1531 Answers
SOURCE: Hotpoint Aquarius WD440 tripping out as soon as program is select
it sounds like you have a direct short in the wiring some where on your machine.the only other option is the main control board needs to be replaced
Posted on Sep 16, 2009
  • 209 Answers
SOURCE: Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Posted on Oct 03, 2007
rockfixya
  • 679 Answers
SOURCE: Hotpoint aquarius WF541 will not switch on
If the washer doesn’t operate or make any noise when set on any cycle, or if it stops suddenly when it should continue onto the next cycle, it may not be receiving electrical power, or, if the motor stopped mid-cycle, the machine’s overload protector may have tripped. In this case, take out some of the articles to reduce the load and let the protector reset itself. Then restart the machine. Otherwise:
1) Be sure the machine is plugged in and turned on. If necessary, check the receptacle it’s plugged into for power, using a working lamp, appliance, or voltage tester. Be sure the washer lid is closed completely.
2) If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit.
3) Unplug the washer, and check the power cord. If necessary, replace the cord.
4) Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch. If it doesn’t click when you do this, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call a repairperson.
5) If the washer still doesn’t work, the controls may be faulty. Call a service person.
Thanks for your question
Posted on Jan 03, 2009
Hotpoint tcl 770 aquarius tripping electrics
REMOVE TOP OF WASHER AND CHECK WIRING ON FRONT RIGHT SIDE AS IT IS PRONE TO CHAFFING CAUSING AN INSTANT TRIP.
Jul 27, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
My washing machine it tripping the mains board out, changes plugs and sockets and its still doing it - any ideas? perhaps the bushes?
sounds like water is getting into the electrics....or your trip circuit has became week...try switching the trip switch from another circuit.
Jul 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius SDW60 is tripping the mains power
is the circuit protected by an rcd/rcbo or a standard mcb as this may be a neutral to earth fault/insulation breaking down...try and get the machine portable appliance tested
Sep 05, 2009 | Hotpoint 24 in. FDW60 Free-standing...
I believe the problem is in the fus(breaker). I would say that it is the thermal fuse in the machine but it usually goes out before the breaker does. The breaker has gotten weak over the years. You have a hi limit on the machine as well but I doubt this is it. Let me know how you do.
Feb 07, 2009 | Hotpoint Dryers
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
355 people viewed this question
Top Washing Machines Experts
