Question about Honda 3000 Watt Portable Generator
Starter wont engage,battery is good - Honda 3000 Watt Portable Generator
    Problem Solver:
  • 12 Answers
Remove the starter and bench test it with auto booster cables /put the black on the starter case and touch the stud on the rear of the starter. It should spin rapidly and the drive should advance if neither
happens the starter will need rebuilding or replacing. if the starter spins rapidly but the drive does not advance you may only need to replace the drive.
Posted on Mar 21, 2014
Everything works on the car but the starter wont engage and i just bought a new starter and battery
Take the starter back out but leave it connected. If it doesn't use a ground wire, make up a heavy wire and use that for ground.
When you hit the key, watch to see if the starter gear moves forward to engage an doesn't just spin. (it engages the flywheel when in place.) The engine isn't supposed to fire if it's not turning.
Aug 08, 2016 | 2001 Suzuki Grand Vitara
Starter motor wont engage checked brushes and movement small what i persume soleniod attached the side of starter just clicks
Alot of the time a clicking sound indicates a dead battery. It happens when there isn't enough power to fully engage the starter but just enough to engage solenoid. I would check your battery and all connections, including ground wires, battery wires and solenoid wires. Take a wire brush to them and clean them up and reinstall them. If that doesn't work, remove your starter and bench test it by hooking up a good battery to the lead that solenoid goes to and ground the other. If it passes the bench test your solenoid probably needs replaced. If it fails the problem is in your starter. Good luck! FYI, remove battery leads while removing starter and other wires for safety when cleaning.
Mar 16, 2014 | Garden
2002 yukon wont start drove it allday yesterday and last night .woke up headed to to work wouldn't start tried jumping it still kno start replace battery and still wont start
Is the starter engaging when you jump start it? You say you replaced the battery, is the cable ends clean? If the starter is engaging you have other problems, if its not then check out the starter/cables. Good luck!
Dec 04, 2013 | Cars & Trucks
Bulldozer quit running now it wont turn over or do anything
check your ground on your starter/starter relay/ground from battery, possibly even a bad start key/switch. Are all your "kill" switches engaged (clutch pedal/brake/seat/door, etc). Since I dont know the model of your bulldozer I am just suggesting the basics. Good Luck
Jun 07, 2012 | 1996 Chevrolet K1500
2003 dyna starter turns but wont engage, new battery fitted
Hi Anonymous, lift up rubber boot on positive cable to starter, unplug starter relay wire usually green, with a jumper wire connected to positive battery cable starter stud, touch blade connecter on starter where starter relay wire was removed. If starter engages and turns over engine then your starter relay is bad. If starter activates but does not engage then your starter drive/clutch is bad. Good luck
Jan 22, 2012 | Cars & Trucks
Brand new starter was installed in my 2003 nissan altima but when i try to start it sounds like its grindinding the sound is similisr to when you already have the car running and you try to start it...
you could have a bad flywheel, missing teeth, was that checked when the starter was out ? if not, your going to have to check it now, also , check the teeth on the starter and have it bench checked to see if it engages properly, Its not unusual for a rebuilt to have faults
Jul 15, 2011 | 2003 Nissan Altima
Turn key to start n nothing battery good starter wont engage
Could be loose connections on Battery. Check tham for tightness.
Loose connection on starter solenoid or bad solenoid.
Could be loose connections on starter.
Good Luck
Jun 30, 2011 | 2003 Chevrolet Silverado 1500
Car clicks but wont start...power is good with interior/dash lights.....
this is caused by a defective starter solenoid, the heavy contact that engage the starter get burned the solenoid engages (the click u hear) but the starter gets no power due to the contacts being burned away
Oct 26, 2010 | 2001 GMC Yukon XL
Starter relay connections
if your starter engages but wont spin check to make sure the starter housing is making good contact on the bell housing or it wont ground out
Jul 07, 2008 | 1993 Ford Explorer Limited
Starter
the most common problem would be the starter relay,
the contacts burn out so just replace the relay.
cheers
Jun 30, 2008 | 1984 Nissan 300ZX
Honda 3000 Watt  Portable Generator Logo
111 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
