Question about Air Tools & Compressors
Adjust trigger on a dti model 7000 brass nail gun
  • 1388 Answers
SOURCE: n80sb-1 stanley bostitch framing gun.
Yes your nailer will drive other sizes of nails. For info and parts go to www.bostitch.com and look for the support tab then select service parts. Here you will find parts list and manual. To remove the tva11 trigger valve remove the retainer pin (the pin is 3mm) for the trigger and remove trigger. Next remove roll pin/pins that retain trigger valve. Use heavy glove to catch trigger valve as you apply air pressure to gun. The valve could pop out with great force so try lowering the pressure to gun. Before installing the new valve, check the opening for sharp edges which will cut orings. Good Luck and email if you have more questions.
Posted on Mar 14, 2009
  • 24 Answers
SOURCE: Makita AF503 Brad Nailer won't fire nail
Take head off of tool. Clean and lube orings on the head valve . Do not use wd40 use air nailer oil.
Posted on Apr 14, 2009
Editor925
  • 285 Answers
SOURCE: How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
Posted on May 31, 2009
smjdragonfly
  • 79 Answers
SOURCE: air coming out the trigger of a stanley air gun
Go to the Stanley Bostitch website. Click on schematics & parts. Find your model number in the drop down list. There is a list of parts and pricing. Just above the parts is a link for the schematic. Honestly, I worked on these things for years. It is best to replace the entire trigger valve. It comes as a kit with instructions grease, and a little tool to hammer your pins out. Lemme know if this helps. Please rate me
Posted on Jun 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: air blows thru the trigger on both my finish nailer and staple gu
there is an o ring in the trigger valve referred to as a Purple o ring that is probably split. If you can find a air tool center that has them you will save a lot of money versus replacing the trigger valve. Let me know what you are going to do and I will help you with the removal of the valve.
Posted on Oct 06, 2009
With 90 # air and PC nails. When I pull the trigger nothing happens. No air noise, no nailing, no movement - just dead. It's been oiled every use.
Most likely stuck trigger valve. Easy to check. Remove nails, remove trigger to expose the firing pin of trigger valve. Connect air and very quickly depress the firing pin all the way in. If the gun fires , adjust the safety to depress the trigger valve completely. If the gun does not fire, replace firing valve, or remove and check /lube o-rings in valve. Good luck
Jul 11, 2015 | Air Tools & Compressors
NO NAIL IS COMING OUT WEN YOU PRES THE TRIKER
I presume the gun fires but no nail is ejected. A possibility is jammed nails in the magazine. Do you see a mark in your work piece of the driver blade? If yes then it is most likely jammed nails. If not could be a broken driver blade. If gun does not fire could be gas problem. (check in date, yes it does have a use by date), another cause of not firing is a broken wire particularly around trigger switch (switch is on trigger and hence the wires are flexing every time trigger is pressed). Another cause of not firing is a brass spring clip in handle assy if this breaks it stops the gun firing. Recently I have had more broken wires than anything else on these guns. Worth noting is that the Stanley Bostitch nail guns suffer the very same faults. Also note they are the same gun just different colours so you can fit Hitachi parts to the Bostitch and they are cheaper.
Feb 12, 2014 | Tools & Hardware - Others
Nail gun will not shoot a nail
Check the safety trip make sure it is pushing back far enough. If it doesn't then it won't do anything. When it was fine just moments earlier.
Feb 05, 2013 | Dewalt D51822 Clipped Head 2Inch to...
Why does my Hitachi nv45ab gun double fire nails?
This gun should be bump-fired only. Do not place the gun on the work and press trigger. Make sure that the safety spring is in place and has good tension. The spring helps to push the foot off the trigger so that it fires once. You could also adjust the screw that pushes on the firing valve. Turn in or out several turns till head of nail is correct when bump firing then lock the nut. The safety foot fits rather loose on the gun and should still work ok but can get so loose that it falls off the nose. Good luck
Jan 23, 2013 | Hitachi Air Tools & Compressors
Pull the trigger, no nail, only continuos air until I release tyhe trigger. not jammed, gun is clean, very new. acted that way right out of the box then it worked and then not and so on, worked...
Safety foot and lever inside of trigger are not pushing the trigger pin all the way in. To verifty that the gun will fire, remove the nails to allow for dry fire. Remove the trigger to reveal the trigger valve. Hold the gun against old coiled rubber hose or soft wood. Very quickly depress the trigger pin all the way in. If the gun fires, adjust safety foot and trigger so that the trigger pin is fully depressed when your bump fire. If the gun will not fire after adjustment, remove the head and lube headvalve/orings with silicone paste lube.
Sep 03, 2011 | Stanley Bostitch Mcn150 Strapshot Metal...
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
Fires 2 & 3 nails every so often.
Most all nail guns can be converted to single fire, however, usually parts must be changed. Some brands have two positions on the trigger, others have a button position near the trigger to accomplish same. Check with dealer or email your gun model # and I will explain your to fix. For now you can replace the spring on the safety with one slightly stiffer. Also try nailing with trigger depressed and quickly bump the gun to fire, this method usually works better than placing the gun in position then firing. Good luck with your repair.
Jun 24, 2010 | Hitachi 3 - 1/2" Full Roundhead Framing...
Nail Gun cost
A good-quality starter set, including both a compressor and a small nail gun, can be bought for around 200 US dollars (USD). More sophisticated models can reach 1000 USD or more. Optional features such as a hard-shell case, safety trigger, and depth adjustment can drive the price even higher. For one-time jobs, a nail gun can also be rented at hardware stores and home repair centers.
Sep 01, 2008 | Makita Brad Nailer Finish Nailer...
Nail Gun cost
Aug 27, 2008 | Bosch 18V Cordless Planer 53518
Nail Guns costs
Aug 27, 2008 | Arrow ET200 Electric Brad Nail Gun
Air Tools & Compressors Logo
48 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
