Question about LG Shine KE970 Cellular Phone
Im having problems inserting the mic ro sd card in the lg shine
Hi there, i was wondering if anyone can help me how to insert my micro sd memory card in the lg shine.
I have only bought the mobile today, i know all the functions read all the manual but are still having difficulty inserting the card.
i would be gratefull for a reply asap.
thanks
  • zimsa Mar 13, 2009
    i have the same problem. It (micro sd) inserts into the phone just fine with the gold bits facing up. then i turn the phone on and chack the external memory and a warning comes up telling me to insert external memory. Is it supposed to go in with the gold bits down?? it doesnt really go in smoothly at all if the gold bits are down.
    Please help.
  • mozejko Apr 17, 2009
    i have tried everything but the phone still wont acknowledge the sd card i have 4 it. it is inserted properly but wen i go to my stuff, external memory it keeps saying to insert it? HELP!!
First of all, remove the back cover. The Micro SD slot is located underneath the SIM card slot. Hold the SD card with the metal connectors facing you and slide the card into the slot, metal connectors first, until it clicks in place. A logo of an SD card should then appear on the top of the screen.
Then to remove it, push it in and it will click and then pop back out
Posted on Oct 19, 2007
I can Confirm that the NZ version, which as far as im aware is only different to the us ones because it has a scroller instead of a multi dirrectional thingy on the front....IS ONLY COMPATIBLE WITH MicroSD cards, and not MicroSDHC.
For some reason the SDHC cards dont get read by the phone. And yes, the correct way to insert the card is with the gold bits facing towards you.
I checked this all with a Vodafone NZ saleperson in a store. We actually took his MicroSD card out of his Nokia and it worked perfectly. While my MicroSDHC want readable in his Nokia.
Hope this helps....
Now i have to find a buyer for a 4g SDHC card...lol
Byren
Posted on Mar 15, 2009
Ok YOU TAKE THE BACK OF THE PHONE OFF THEN UNDERNEATH THE SIMCARD THERE IS A HOLE PUT IT IN THERE WITH THE GOLD LINES FACING THE SIMCARD okaii
Posted on Mar 13, 2009
I couldnt get mine to come back out so i used a letter opener to push it and it popd rite out
Posted on Oct 11, 2008
For telus phones you have to take the back off, and then take out the battery and insert the micro sd card downwards
Posted on May 18, 2008
As from what I have read, the slot may be in either of two places, depending on the model of the Shine. Mine (AT&T) has a slot on the side, whereas others might have ones behind the back cover (under the SIM card apparently). For those with ones with slots on the side (with the little rubber microsd cover), if you're having a problem and think the cover is faulty, you're not pushing the card far down enough. It really needs to be pushed down farther than your finger can go, it's not broken (as I thought at first).
Posted on Mar 22, 2008
The microSD slot is on the side. You have to use a thin flat screw driver or something small like that in order to push the card in enough to catch. If you push it again, it will pop out.
Posted on Feb 20, 2008
Cheers Senchi i had the same problem with my sisters phone she wants an update of memory but i didnt know where it goes common sence really cheers again
Posted on Feb 12, 2008
When im inserting my micro SD memory card, it appears
It seems that the Card validating sensors are damaged. It doesn't seems to be a software problem. You will have to take the device to a repair center and get it fixed.
Nov 13, 2011 | Samsung Cell Phones
Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
Apr 16, 2010 | LG RUMOR Cellular Phone
It doesnt work when i insert the card with my micro memory card and asks for a disk
Hi likkle_miss_,
The Micro adapter has no memory in it. It is just an adapter to use so you can plug your Micro SD memory card into a larger (SD) slot. The SD Micro memory card needs to be inserted into the adapter.
Kingston Tech Support
Apr 22, 2009 | Kingston 1GB Secure Digital Memory Card
I want to down load music to my 720 lg shine want troubleshoot
use memory card reader.
and insert the Micro sd in it plugg it to computer and start dragging mp3 files to it.
Mar 28, 2009 | LG KE770 Shine Cellular Phone
I cant connect my lg shine with my pc
Yes you can. If you insert a Micro SD card in the LG Shine, you can access the memory card from your PC.
Jan 30, 2009 | LG Shine KE970 Cellular Phone
I cant load music to my lg shine from my computer.. HELP!!!!!!
The LG Shine is a nice phone, but it is very disappointing with the USB cable.
You may expect the cable would connect the phone to your PC for Calendar Sync, music, videos etc.
Obviously, this will not work.
It will only allow you to hook your LG Shine to your PC to copy music and video files ONLY if you have a Micro SD card in the phone inserted.
After you have copied the files to the Micro SD card from your PC, you can copy them to the phone memory.
There are nice websites with free management programs for also the LG phone, but the Shine is unfortunately NOT listed (yet).
http://www.bitpim.org
Jan 01, 2009 | LG Shine KE970 Cellular Phone
I just bought an LG shine but i don't know how to put my music on it.
You can only do that by using an additional Micro SD memory card that contains the music.
Once inserted in the LG Shine, you can play it from the memory card or copy/move it to the phone.
Dec 30, 2008 | LG Shine KE970 Cellular Phone
Memory card lg kc550
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
Nov 13, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Lg shine - downloading music from my laptop
If you want to put music files from your laptop onto your LG Shine, you can either use a LG USB cable or a Micro SD Card.The Micro SD card will probably need an additional adapter to have it big enough for your Laptop or PC slot. Once the music files are on the Micro SD card, insert the card into your LG Shine and go to My Stuff". Then, select "Audio and ringtones" and select the file on your memory card. Press the "Options" button and select the copy function and paste it into your phone.
Jul 28, 2008 | LG Shine KE970 Cellular Phone
Lg shine - cannot access micro SD card which i have inserted.
I just got a new LG shine CU720 to format the card you go to settings, reset settings, master clear, memory card, my security code was 0000. Hope this helps someone else looking.
Dec 26, 2007 | LG Shine KE970 Cellular Phone
LG Shine KE970 Cellular Phone Logo
1,643 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
