Question about Tunturi T90 Treadmill
Error sequence data transfer error comes on display
Laserjet P3015 displaying error code 59.30 how to resolve
this issue is comes from data transfer error,please delete all print command
Jul 28, 2016 | HP LaserJet Enterprise P3015d BW laser...
Tip
Common FTP Error Codes
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy - mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
120 Service ready in nnn minutes.
125 Data connection already open; transfer starting.
150 File status okay; bout to open data connection.
200 Command okay.
202 Command not implemented, superfluous at this site.
211 System status, or system help reply.
212 File status.
213 File status.
214 Help message. On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type. where NAME is an official system name from the list in the Assigned Numbers document.
220 Service ready for new user.
221 Service closing control connection.
225 Data connection open; no transfer in progress.
226 Closing data connection. Requested file action successful (for example, file transfer or file abort).
227 Entering Passive Mode (h1, h2, h3, h4, p1, p2).
230 User logged in, proceed. Logged out is appropriate.
250 Requested file action okay, completed.
257 "PATHNAME" created.
331 User name okay, need password.
332 Need account for login.
350 Requested file action pending further information.
421 Service not available, closing control connection. This may be a replay to any commend if the service knows it must shut down.
425 Can't open data connection.
426 Connection closed; transfer aborted.
450 Requested file action not taken.
451 Requested action aborted. Local error in processing.
452 Requested action not taken. Insufficient storage space in system. File unavailable (e.g., file busy).
500 Syntax error, command unrecognized. This may include errors such as command line too long.
501 Syntax error in parameters or arguments.
502 Command not implemented.
503 Bad sequence of commands.
504 Command not implemented for that parameter.
530 Not logged in.
532 Need account for storing files.
550 Requested action not taken. File unavailable (e.g., file not found, no access).
551 Requested action aborted. Page type unknown.
552 Requested file action aborted. Exceeded storage allocation (for current directory or dataset).
553 Requested action not taken. File name not allowed.
on Jan 12, 2010 | Computers & Internet
Tip
COMMON FTP ERROR CODES
~~~~~~~~~COMMON FTP ERROR CODES~~~~~~~~~~
# Description
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy = mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
150 File status okay; about to open data connection.
200 Command okay.
212 Directory status.
213 File status.
214 Help message.On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type. Where NAME is an official system name from the list in the Assigned Numbers document.
227 Entering Passive Mode (h1,h2,h3,h4,p1,p2).
230 User logged in, proceed. Logged out if appropriate.
421 Service not available, closing control connection.This may be a reply to any command if the service knows it must shut down.
452 Requested action not taken. Insufficient storage space in system.File unavailable (e.g., file busy).
530 Not logged in.
on Dec 03, 2009 | Computers & Internet
TREADCLIMBER tc5000 error code e5_5
see the steps and fix it. God bless you
Error 5
Description
The power up test sequence has detected a key in the operated condition. The power up test
sequence is performed every time the unit is turned on (powered up). This test is performed
because a permanently stuck key will inhibit the correct operation of the unit.
Possible Causes
1. A key on the display housing is permanently stuck in the operated condition.
2. One of the upper PCA's keypad interface chips has failed.
3. Liquid (perhaps perspiration) is present on the surface of a touch sensitive display.
Possible Remedies
1. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is no longer present, the keypad is the cause. The keypad is typically part of
the display housing. Replace the display housing to correct the problem.
2. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is still present, the upper PCA is the cause. Replace the upper PCA to correct
Nov 18, 2012 | Exercise & Fitness
Data Transfer error
You need new lower power board some people say lower circuit board . This will cost around 280 but anyone looking to buy I have got one brand new.contact me on 07943858686
Mar 14, 2012 | Tunturi T85 Treadmill
I have a HP 5550 Color printer and I'm getting a Service Error 49.4C02 on my display and nothing will print. What should I do?
Printer error code "49.4c02" is one of them. It occurs when there is corrupted data. This may confuse the printer, and it stops functioning. In other cases, the data is corrupted while being transferred to the printer. Some printer models are naturally prone to this error because of their driver, while others can display this error while printing a specific font. http://www.fixya.com/support/t6031482-hp_laser
Aug 06, 2010 | HP LaserJet 5550 Printer
All of a sudden I am not able to hear people - they can hear me. This is intermittent.
First, Hello! Second.
VOIP means Voice over IP, naturally VOIP is a realtime communication and there fore is prone to error. Let me explain in more detail.
TCP/IP (Transfer Control Protocol/Internet Protocol) uses two communnication protocols, TCP(Transfer Control Protocol) and UDP (User Datagram Protocol).
The TCP uses sequencing and acknowledment in order to start the connection, transfer data, acknowledge data arrives in order to send the subsequent data segment. In order word is like mail delivery with confirmation.
The UDP is like besto effort delivery. "I sent the data and hope you get it". Because the data travel many different ways in many Packets TCP send the data, but on destination arrives the segments in different order, The TCP puts them together, on realtime it will imposible to understand the other party in this way. So, this is why you sometimes you see squares or "error" on video streaming, because video is in real time, if you have to wait for all the packet to get toghether take toooooo much time.
So you have to check for Qos or resuce you transfers over internet while sepaking. On Wikipedia are very good info on Qos. Theres router with Qos integrated to ensure some bandwith is dedicated to VOIP transmissions. I Hope It Helps! Good Day!
Jul 02, 2009 | Hitachi WIP-5000 IP Wireless Phone
Nokia 6233 mobile switch on but then hangup
Dear
When u connect to computer by data cable it shows three option, select data transfer option from it to transfer file like videos,music etc.
while in this process phone will not displays menu option it shows data transfering
if u want to display menu option u have to deattach usb data connection
Thanks
Feb 20, 2009 | Nokia 6233 Cellular Phone
Removing leading zeros from barcode???
Prefix/Suffix Dialogs
The Prefix/Suffix Dialogs allows configuration of DataWedge options.
Two data entry fields are used to display and allow entry or editing of prefix and
suffix strings. The prefix string, if present, is transmitted before the data for any
barcode scanned. The suffix string, if present, is transmitted after the data for any
barcode scanned.
The following checkboxes are used to display and allow modification of various
DataWedge options:
Allow escapes in prefix/suffix (default = disabled)
Enabling this option allows escape sequences to be embedded in prefix and
suffix strings. Escape sequences allow non-textual data to be transmitted as
part of the prefix or suffix string. All escape sequences begin with the backslash “\”
character. The supported escape sequences are:
\b Backspace
\f Form feed
\n New line (line feed)
\r Carriage return
Apr 14, 2008 | Symbol MC70
Tunturi T90 Treadmill Logo
27 people viewed this question
Top Tunturi Exercise & Fitness Experts
gbob59
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
