Question about Brother IntelliFax-2820 Laser Fax
White lines while sending/copying
2 white lines funning length of paper
    Sniper:
  • 86 Answers
'Dirty corona wire' would give black vertical lines, the white lines are more likely a result of a dirty laser window. Try to wipe the laser window with a (dry!) soft cloth. You can find the laser window if you remove toner/drum package and look on the "top" inside the machine, there should be a horizontal glass window there that should be cleaned.
Posted on Jun 02, 2009
  • 1,959 Answers
Everything seems to indicate a dirty 'corona wire'. This seems to be the most common cause of vertical white lines running the length of a page when copying/sending. Below is a link to the User's guide for your machine with instructions for cleaning the corona and other care when using your fax machine. Best of luck.
Greg
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_2820_2920_MFC_7220_7225N_EN_1344.PDF
Posted on May 20, 2009
When making copies, there's a line running through every copy-- along the entire length of the paper
If line appear on drum scratched change drum & cleaning blade.otherwise change only cleaning blade
Mar 24, 2013 | Canon PC-940 Black and White Copier
When I send a fax there is a white line down the center of the page. It does not do it when I make copies, How can I clean it or correct the problem.
Are you sure that there is no lines when you make copies?Because the scaner is used when you send faxes and when you copie, if sensor is bad or dirty lines would be wissible.
Clean it very well, with strong detergent, but in small amounts.Scratch the stains from corctour or similar...
Jun 14, 2010 | Canon FaxPhone L75 Plain Paper Laser
Copies leaves lines when put through the feeder,but not on the glass .......have cleaned and sprayed air can everywhere I can think of The Hp Printer is HP 3055 All in One printer
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | HP LaserJet 3055 All-In-One Printer
Getting a black strip in copy mode on X6575 lexmark printer. No line in print or test mode
Most likely a page was scanned with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
Mar 16, 2010 | Lexmark X6100 Flatbed Scanner
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
I get lines and can't read the right side of copies that I make with the 1270e. How do I fix this?
You have not specified why you can't read the right side of copies and I am assuming that the reason is because the 'lines' are covering the text. I can offer a solution to the lines issue.
Feb 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
My copier is making copies that have a big blank area
Hi, first if you mean length of the page, remove the ink cartridge and see if a piece of paper is stuck on the roller where the power comes onto the paper, in line with that white line on the copy.
Aug 11, 2009 | Ricoh Office Equipment & Supplies
Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Jan 23, 2009 | Canon NP 6551 Black and White Copier
Black line when making copies
A line down a paper on either a printer or scanner is classic sign of scratched drum. The certainty of it is in the fact the line is at the same place each time. Drum needs to be replaced.
Don't forget to 4 star this solution.
Jan 15, 2009 | HP LaserJet 2840 Printer
Brother IntelliFax-2820 Laser Fax Logo
465 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
