Looking for operation maneul of a nextech hi scan-pro dianostic machine
When I CLICK THE SCAN OPTION ON MY PRINTER, THE APPLICATION LIST WILL NOT DOWNLOAD, HELP
not much I can look for with the information provided . my HP has a dianostics screen on my computer .
Mar 07, 2015 | Office Equipment & Supplies
Nextech Iphone 4 into a Staight talk phone
So do it. Why are you posting questions...?
Mar 27, 2014 | Computers & Internet
Nextech web cam 2516506 driver
nextech? Supply more info.
Nov 25, 2012 | Computers & Internet
Nextech 2.0 card reader not working
Make sure the drivers are installed and not corrupted. Better yet, you can download and install them again.
Get onlineand got to www.google.com In the google search box type: "NextechSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.If all fails, you can purchase a card reader for under $20 at a computer or retail store.
Apr 11, 2012 | Computers & Internet
Hi need to clear the memory on a minolta 751\601, we were doing alot of scanning to email and it shows 100% and we can't scan anymore but can print and copy
100% mean it is ready not full You may have memory chip go bad. does the machine have a hard drive. Mite want to have that looked at also, and reformatted. .
Jul 12, 2011 | Minolta EP4000/5000 CS/PRO Copier
Hi my computer is playing up when i turn it on it says PXE-E61: MEDIA TEST FALURE. CHECK CABLE, but all cables are good. also when i scanned it using the dianostic tool it says error code: BIOHD-8 AND...
Disconnect the Floppy, CD/DVD and any other Drive you have connected and boot the machine. If the machine boots shut it down and connect the disconnected devices 1 at a time until you have it isolated. If the Computer doesn't boot and you still get the same fault then your hard drive has faulted try a different drive.
Jul 12, 2010 | HP dx2250 Monitor Personal computer AMD...
Jeep 89 dianostic scanner
the renault designed (pre1991)jeep computer systems were very simple and diagnostic codes were non existant diagnosis is by scan data not codes common failuer parts were oxygen sensors and crank sensors throttle position sensors were failure prone also BUT need to be ajusted correctly to ork properly
Feb 16, 2010 | 1989 Jeep Cherokee
CODE 138
Hi..my name is Keith..and im assuming you have OBD II..and the code 138 means that...O2 sensor circuit,high voltage(cyclinder bank #1,sensor #2)..i hope this will help you
Nov 21, 2008 | 1996 Dodge Dakota
Nextech esdvd100 stoped recognise dvd/cd
I have the same problem with my esdvd100 were it stop recoginze my dvd or cd. msg: No Disk
Jan 04, 2008 | NexxTech ESDVD100 System
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
