Brother MFC-J220 All-in-One Color Inkjet Printer - Black 2766220 Logo
Myrna Petran Posted on Jan 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Code 44 printer does not print more than 5 pages
Printer Help & Support
Level 3:
  • Brother Master 783 Answers
  • Posted on Feb 17, 2014
Brother Master
Level 3:
Answers
783
Questions
0
Helped
279943
Points
1637
Hi myrna,
Check each configuration tab in the FireFox or OpenOffice print dialog box.
Some settings can conflict with each other. Look for any alert icons or messages next to the drop down menus, then change the setting to correct the issue.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Brother Printer Support
I need to pull an 11" x 48" sheet through my printer
The widest paper to fit through is 8.5 inches. You can print up to 44" in length though.. from a Google search:
Automatic Document Feeder: 30 sheets. Paper Sizes: 3.5" x 5", 4" x 6", 5" x 7", 8" x 10", 8.5" x 11", 8.5" x 14", A4, B5, A5, A6, half letter, executive, user definable (3.5" - 44" in length) Maximum Paper Size: 8.5" x 44" Borderless Sizes: Photo: 4" x 6", 5" x 7", 8" x 10", 8.5" x 11", A4, 16:9 wide.
2helpful
3answers
UNABLE TO PRINT 44 - BROTHER MFC-J6510DW
User guide http://download.brother.com/welcome/doc002835/cv_mfc6710dw_use_busr_lx7144001_b.pdf says either a mechanical problem or could be foreign object like paper clip or torn paper inside the machine. Open the scanner cover to check for that.
1helpful
Cleaning inkjet nozzles
Here's what I found here:
http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
Cleaning the print cartridge nozzles
To improve print quality, you may need to clean the print cartridge nozzles.
Clean the nozzles when:
• Characters are not printing completely.
• White dashes appear in graphics or printed text.
• Print is smudged or too dark.
• Colors on print jobs are faded or they differ from the colors on the
screen.
• Vertical, straight lines are not smooth.
43
You can use the operator panel or the Lexmark X5100 Series Solution
Center to clean the nozzles.
Using the operator panel
1 Load paper in the All-In-One. For help, see page 16.
2 Press Options until Cartridges appears on the display.
3 Press the right arrow until Clean appears on the display.
4 Press Select.
A nozzle page prints forcing ink through the nozzles to clean the
clogged nozzles.
5 Print your document again to verify your print quality has improved.
6 To further improve print quality, try wiping the print cartridge nozzles
and contacts (see page 44), and then print your document again.
7 If print quality has not improved, try cleaning the print cartridge
nozzles up to two more times.
Using the Lexmark X5100 Series Solution Center
1 Load plain paper in the All-In-One. For help, see page 16.
2 Click Start Programs Lexmark X5100 Series Lexmark X5100
Series Solution Center.
3 Click the Maintenance tab.
4 From the Maintenance tab, click Clean to fix horizontal streaks.
5 Click Print.
clogged nozzles.
6 Print your document again to verify your print quality has improved.
44
7 To further improve print quality, try wiping the print cartridge nozzles
8 If print quality has not improved, try cleaning the print cartridge
Wiping the print cartridge nozzles and contacts
If the print quality does not improve after cleaning the print cartridge
nozzles, dried ink may be on the nozzles or contacts. To wipe the print
cartridge nozzles and contacts:
1 Remove the print cartridges. For help, see page 38.
2 Dampen a clean, lint-free cloth with water.
3 Hold the cloth against the gold nozzle area for about three seconds.
Gently blot and wipe dry in one direction (this prevents the colors in
the color cartridge from mixing).
4 Hold a clean, damp section of cloth against the contacts for about
three seconds. Gently blot and wipe dry in one direction.
Nozzles
Contacts
45
5 Let the nozzles and contacts dry completely.
6 Reinstall the print cartridges, and then print your document again.
7 If the print quality has not improved, try cleaning the print cartridge
8 If print quality is still unsatisfactory, replace your print cartridges. For
help, see page 38.
I was printing a downloaded document on my HP C5180 printer that contained 144 pages. The printer started at page 144 and stopped at page 44. How do I get it to print the remaining pages without reprinting...
You don't specify from which application are you printing, or even what operating system are we talking about.
If it's Windows, then you need to open your document, hit Ctrl+P or choose File->Print from the menu, and in the Print dialog that appears specify "1 - 44" in the Pages field. Finally confirm by clicking OK.
Please come back and leave a rating/testimonial if helped.
Have a Cannon C6800 When i print 5-6 pages it
this error is from one of the color drum unit most probably yellow drum unit(needs replacements)
I bought two new cartridges for my printer but the printer prints funny. there is no color and the black appears faded. my printer is about 2 years old. have any ideals?
Sounds like the jets may be clogged. You may have to run multiple times till they are good. Print a test after each clean and see if that helps.  You can use the operator panel or the Lexmark X5100 Series Solution Center to clean the nozzles. Using the operator panel 1 Load paper in the All-In-One. For help, see page 16. 2 Press Options until Cartridges appears on the display. 3 Press the right arrow until Clean appears on the display. 4 Press Select. A nozzle page prints forcing ink through the nozzles to clean the clogged nozzles. 5 Print your document again to verify your print quality has improved. 6 To further improve print quality, try wiping the print cartridge nozzles and contacts (see page 44), and then print your document again. 7 If print quality has not improved, try cleaning the print cartridge nozzles up to two more times. you can get the owners manual on line at this address:  http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
please rate this and good luck.
Lexmark Printer X6570 using Cartridge 44 XL - expected output 500 pages but got only 375 pages. 43 XL (colour) - expected 350 pages but printed less than 100 pages and printer cartridge indicates that...
The expected cartridge life that you are given is an estimate based on 5% coverage. If your pages have more than 5% coverage on them, you use more ink and therefore will get less pages than what they say you could get. For instance, if you are printing full page photos, you will get far less pages per cartridge than if you were only printing 3 x 5 photos. So there is nothing wrong with your printer, you are just using it more than the "standard".
Thanks and please take a moment to rate as fixya.
1helpful
2answers
Confirmation Page
Check the link -- if this is the correct device page 44 of the first english manual has the code for changing the confirmation page setting.
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Plain-Paper-Fax/Copier/model.KX-FG2451
Norman Weimar
Norman Weimar
k24674
