Question about Dishwashers
Hotpoint Dishwasher not working
My Hotpoint LFT 04 UK/TA Type LS12-DEA601 S2 has stopped working, my 5year old kept opening the the door in mid flow and now there are no lights lighting up. Iv checked the fuse but still not working. any advise would be appreciated.
3 Suggested Answers
SOURCE: Just installed Hotpoint Dishwasher model LFT 114 uk
I'm having exactly the same problem, was this ever resolved?
Posted on May 10, 2010
woobie dog
  • 1273 Answers
SOURCE: I have a Hotpoint dishwasher,
Hello, W/D here.
If the pump is working, and it sounds like it is, then the spray arms may be clogged. Here's an easy way to clean them.
If the arms will come off, take them off. Usually, one or more of them will have a screw on top, like a jar top. Remove those, one at a time to clean, so they don't get mixed up in reassembling.
Over the sink, use a regular paper clip, straightened into an "L" to rake out the debris clogging the slots on the edge of the arm, and pushing the debris stuck in the nozzles back into the arm. Use the sink faucet to back wash the debris as best as possible back towards the screw on connection point to flush the debris out. Sometimes, the debris is stubborn, and you may have to repeat the raking and poking a few times to get it all.
For the arms that will not unscrew, you'll have to clean them in place. If they are attached to the motor cover plate, it's usually more of a headache to pull all of this off to clean the spray arm, as gaskets can become displaced and very hard to get back in place properly. Just clean them as best you can, and re-clean them after you run a cycle.
This should help getting it cleaning well again.
Best regards, --W/D--
Posted on Feb 10, 2011
Can anyone tell me about the washing cycle symbols on my Ariston LS12.EV03. It came with the apartment with no manuals...
Best I could do for instructions in English: http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Ariston/Dishwashers/AF350X_034628gb.pdf
Here is a site with a lot of manuals for Ariston products, with other brand names: http://www.manuals.club/results_alpha.php?ctext=ARISTON+DISHWASHER+LS12-EVO3
Mar 05, 2015 | Dishwashers
I noticed just as going to bed last night that our dishwasher appeared to be making a strange noise (dull buzzing sound), opened door to check and the display has the number 3 flashing, several fault codes...
check the very bottom of washer; look for something jamming the garbage cutting blades. it can be something very small stock half way in the drain causing the blades to stop turning and therefore keeps it from draining water. just an idea
Dec 16, 2014 | Hotpoint-Ariston LFT 228A 23 in Builtin...
Hotpoint LFT 228 A dishwasher not making any sound
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Mar 11, 2012 | Hotpoint-Ariston LFT 228A 23 in Builtin...
Wiring diagram for indesit di 61 uk dishwasher
Indesit DI 61 UK Type LS12-2100
Element not heating water on programmes 1 and 2 and soap disoenser not opening but Ok
Jan 12, 2012 | Hotpoint Dishwashers
Hotpoint LFT 114 dishwasher......why is it suddenly not getting any water? the pipe connections seem fine and it's worked for years!
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Aug 19, 2010 | Hotpoint Dishwashers
Dishwasher starts to work but after 30 seconds stops and two lights start flashing on pannel
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.Service manual below, if the above doesn't help. http://appliancejunk.com/ge/dishwasher/31-9137.pdf
Jun 24, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
78 people viewed this question
Top Dishwashers Experts
Owen Barnes
